Question about Husqvarna Viking 1
Where do I GET the blank disk for this machine
    Genius:
  • 1,116 Answers
Does the machine use an ATA PC card, or a memory card and card reader.
ATA PC cards are sold with electronics and computer supplies.
The memory card has to be compatible with both the card reader and the format of the embroidery machine. These are sold at places such as Allbrands online or at the Viking dealer.
Posted on May 08, 2010
Machine will not sew its is looping under neath from top cotton
Remove the upper thread from your machine.
RAISE the presser foot and then rethread from the beginning. Raising the presser foot releases the tension disk so the thread will seat properly). Also, verify that the threading steps are correct (consult the threading instructions).
Check that the bobbin thread has been loaded in the bobbin case properly and threaded through the tension spring.
Test. If the upper thread is still showing under the fabric, tighten the upper tension disk until the upper and bobbin threads meet in the middle of the fabric.
Feb 03, 2016 | Janome Harmony 2041
MY lights come on but the LCD screen is blank and it is beeping. Please help
Check that the LCD screen adjustment has not been dimmed or darkened. If that is not the case, then a component is or has most likely failed.
Dec 30, 2015 | Brother Sewing Machines
Software for singer sew ware 1.0
Ask the dealer for the disk. If they don't give it to you, try the version 2.
As long as it isn't an upgrade from the old version, you shouldn't have a problem.
The read/write card should have come with the machine. Contact the dealer.
Any problems should be reported to the company.
Apr 10, 2013 | Singer Quantum XL-1000 Computerized Sewing...
My brother embroidery machine's lcd screen is blank
Hi.
On page 81 of your manual it says to adjust your LCD screen brightness.
If you can't find your manual... go here and download it.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PE_770%20%20%E2%80%93%20New!_EN_1819.PDF
Jul 13, 2012 | Brother Sewing Machines
Where to buy another creative blank pfaff 7570 card
try contacting pfaff customer & ask them if a pfaff dealer would carry them
also try
sewingpartsonline.com
May 02, 2012 | PfaFF Creative 7570
My D1 still runs designs from a floppy. I have the 4D software. What computer extension do I need to save my designs to, in order for the sewing machine to be able to stitch them. So far I'm having no luck...
Your Designer 1 will read none of the file formats you listed. It uses .shv which is a special file type created just for the Designer 1. Some embroidery sellers offer this format, but most do not. You don't need the .shv if you have the 4D software. When you purchase designs, you can buy almost any format you want and your software will deal with it. Most Husqvarna Designer owners purchase designs in .vp3 or .pes format. Avoid .art designs.
You need to set up your software using the Configure module. You can access this either by locating your 4D software folder on your hard drive - in that folder there should be an .exe called Configure - or use a link in your normal 4D screen once you open the program. Look for the icon along the top that looks like a screwdriver and pliers (or something like that). In Configure use the Send 1 tab to tell your software that you have a floppy disk Designer 1.
When you want to load designs for your sewing machine, open 4D Disk Manager (it will be in the drop-down Accessories box using the arrow beside the Configure button). You need to have the correctly formatted floppy disk in your computer's floppy disk drive. If you don't have one, you can format a blank one from within the Disk Manager module. Most importantly if you are using a floppy that already has been used in your Designer 1, you need to use the Read Disk icon along the top. The designs already on your floppy are read into the program. You can then add whatever designs you want by using the Open (icon showing an open manilla folder) or View (looks like a blue camera) buttons. Then you choose the Write Disk button to put not only your newly added designs on the floppy disk, but to also put back the ones that were already on it. Click "Yes" when asked if you want to erase designs already on the disk. It is quite safe provided you read the disk into Disk Manager first, as described above.
Jun 10, 2010 | Husqvarna Designer I
PC Designer disk not working
Your PC's floppy disk is not readable by the disk drive, probably because you don't use the drive as much, and it has gathered a layer of dust and dirt inside. It's necessary for you to clean the floppy drive using a special disk with a special cleaner liquid. However, with floppy drives going the way of the dinosaurs, it may be difficult to find such item nowadays.
Try getting one of those small compressed air canisters to clean your keyboard and try blowing the dirt off the mechanism of your drive.
If that fails, it's possible your floppy disk has gone bad. Data on these disks have only a certain life span measured in years.
If that also fails, then write to PFAFF and ask for a replacement disk of the same version of the software, sending them proof of purchase, etc, so that they will comply without any questioning.
Aug 03, 2009 | PfaFF Creative 7570
Viking D1 error message file not found
You need to use either Organizer or Disk Manager to put designs on the floppy disk. Both of these are Husqvarna programs, not part of your computers operating system. If you copy shv file directly, the machine does not have all of the information that it needs to read the files. If the folder containing your original shv files that you purchased contains additional files, you just need to copy EVERY file within that folder to the floppy disk and it might work. Don't attempt to move individual files to the floppy. You will need them all.
Apr 10, 2009 | Husqvarna Designer I
Designer 1 Sewing Machine
I think you might possibly need to save it to a disk, then use that disk when you want to print something out. I am speaking, of course of the older Designer 1. I realize there is a USB version, and for that I have no solution. I am still using the older one.
Apr 30, 2008 | Husqvarna Viking 1
Sewing Machines Logo
130 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
