Question about D-Link RangeBooster G DPR-1260 (DPR1260) Print Server
Print server not locating INF file
I have the Printer Cd but DPR-1260 still won't install...says it can't find INF file
  • 3 more comments
  • Anonymous Mar 30, 2008
    I'm have the same problem with my laptop. All other computers on net are working fine.
  • mspaeth May 17, 2008
    the installation run well, scanning is working, but the printer wizzard can't find the *.inf file of the HP officejet 7130 I am using. Neither the CD nor the hard disk has been accepted as "vaild files". The same problem came up when I tried the laptop of my wife.
  • MRHINC Feb 14, 2009
    Same Problem here and no apparent solution from Dlink Support
  • Anonymous Mar 08, 2009
    Same thing, the damn device won't accept any .inf files...
  • Anonymous May 07, 2009
    Same issue
    Can not found the *.INF file - He says!
Jkjjkk
Posted on Apr 06, 2008
SOURCE:
D-Link DPR-1260 print server setup problem
Try admin for logon & password.
Sometimes it is user ......
Feb 01, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
When trying to set up Samsung CLP 310 I cannot get the software loaded. Sony notebook VGN SR220J. Server works fine from 2 network connected PC's I've tried it from the disc and the loaction on the HD.
download latest drivers and install with printer unplugged...it will install software to c:\program files\samsung\ and then 2 more folders in you will get the drivers folder - add printer and just do have disk and browse to that folder.
Aug 01, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
D-LINK DPR 1260 NOT DETECTED
did you install the software that comes with the print server? if so, did you configure the software to recognize the printer?
Apr 30, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
HP laserjet P1005
Go to the printer properties, you can go from Start-->Printers and Faxes. Select the printer (it should say something like, HP LaserJet P1005 on DPR1260 ..... make a double click on there. Then select Printer -----> Properties. Then go to Ports, and DE-SELECT the box that says: Enable bydirectional compatibility. IT SHOULD BE NOT SELECTED. Then Select Apply, and then Acept. After doing this, the printer should start working.
Mar 04, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Can't find HP Photosmart 7150 driver during setup
check here.
Answer number 7 helped me when i had the same issues with the samsung ML-2010.
I installed the printer localy and then followed the sugestions at this link.
changed the server to a static ip
activated the required windows uttilities
changed the printer settings
http://www.fixya.com/support/t299506-issues_printing_dpr_1260
hope this helps.
Jan 13, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Printer eventually loses connection...
Try to upgrade the firmware revision to the last one (1.21).
I had similar problem with the dpr-1260 firmware rev 1.00.
Now after the firmware upgrade the problem seems solved
Nov 06, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Canon Pixma MP530 multifunction printer comes up as a fax
This is absolutely the right solution. I used this for my Canon MP780 printer under Vista, as well. I want to include all of the keywords here. It is important to note that the DPR-1260 shipped with Firmware Version 1.12 cannot be seen by Visa until it is upgraded with the Version 1.21 firmware, but after downgrading back to the Version 1.12 firmware, the DPR-1260 is still visible and it now recognizes my Canon MP780 multifunction printer as a printer and not as a fax machine. I plan to post this same solution to other sites, so that hopefully others can get their DPRs working again. Whew!
Sep 10, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
D-Link RangeBooster G  DPR-1260 (DPR1260) Print Server Logo
702 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
