Question about Sony Playstation 3 (PS3) Console
For the ps3 if i change to HD settings, how could i change back?
For the ps3 if i change to HD settings, how could i change it back to the orginal settings to play on the old analog tv? Because right now i cant.
  • Sony Expert
  • 311 Answers
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3for the ps3 if i change to HD settings, how could  - 2_bing.gif will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all
Posted on May 08, 2010
Playstation 3 reset
Go into your setting and there is a setting for factory restore it will wipe everything on your PS3 back to how it was when you orginally bought it! It's located in your settings section near the bottom, it will walk you through the process after you click yes to reset your PS3.
Jan 06, 2014 | Sony Playstation 3 (PS3) Console
Hey guys i gave my ps3 to a shop in st neots to get my hd working and he blew out all the dust with a air gun and changed the settings and said the ps3 is set up for hd now and it worked on the shop tv but...
When changing the display mode of the PS3 you must be in the correct mode and be using the correct wire. If in the shop it was last set up in HD mode, then you must be using an HD cable (component cable(wire with red/yellow/white) will not work. Also, make sure that your TV can handle the resolution it is set in. If your TV at best handles 720p and the PS3 is set in 1080, then you will have to hook it up to a TV with 1080 to change it back or you will not get a picture.
Aug 27, 2010 | Sony Playstation 3 (PS3) Console
Every time i turn on my playstation nothing shows up on the screen whats the problem
If you bought the ps3 used then the person before you probably had an HD TV and didn't change the settings back to AVI. You need to find a HD TV and change the settings back to AVI then you can play your PS3....or vice versa.
Dec 26, 2009 | Sony Playstation 3 (PS3) Console
Ps3 starts and the green light is on but no image omes up on my
Try connecting the PS3 to your TV with a scart cable first and go to the appropriate channel. The problem you are facing is probably because the default output is not HD. So you must change it to HD you can do this by going on your PS3 display settings, whilst your operating on standard definition, AV1 or something like that. When the you are on display settings plug the HD cable in the PS3 while still being on AV1 and then plug the cable in, this may prompt a message saying that a HDMI device has been detected and you can change to HD, if this message appears switch to the HDMI output and then select yes and automatic on the PS3 for optimal settings in HD. If the message does not appear then select the HD output yourself after plugging the HDMI cable in and then change to the channel and do the same.
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
PS3 not working on reg tv's after HDMI use on LCD HD tv
Shelley,  the fix for this is simple! Hold down the power button for about 5 seconds and the system will beep. This resets the video setting for your ps3 from HD too whatever the current cables are that you are using too hook up too the tv. This works on my PS3 which I just bought about 3 months ago and should work with the older ones.
Jun 05, 2009 | LG 37LC2D Television
How do we change PS3 settings from HDMI back to non HD?
switch it to standby then hold the power button for three beeps(not including the first power on beep)this should open a troubleshooting menu,pick option 2.If it doesnt give you the menu first time,switch it off at the back and repeat the steps again.Good luck.
Apr 21, 2009 | Sony Playstation 3 (PS3) Console
Played ps3 on my brothers hd tv
do u have hd?
if not u need to change ur settings to video instead of hd! but when i had to i needed it hooked up to hd first then went through settings to change it or it will be blank screen!
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
PS3 wont show up on TV
you will have to find an hdtv to change it back.
Mar 08, 2008 | Sony Playstation 3 (PS3) Console
Unhooked ps3 from an hd tv and plugged it into an sd tv and it shows no picture.
when in standby mode(redlight) push and hold the power power button until you hear the second beep. This should reset your PS3 to it's standard 480i resolution.
Sep 21, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
