Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos lines threw the picture
I have a sharp aquos tv its about 2 yrs old. recently 1 thin blueish pixel line showed up, a couple days later another, now i have a thick one that runs across the top. is there anyway i can fix this?? someone told me i would have to get a new mother board?
thanks
  • 1 more comment
  • Anonymous Mar 27, 2008
    We have a Sharp Aquos LC46D62U, it is 13 months old (one month out of warranty). We have blinkings stripes and bands throughout the screen regardless of the input (cable, DVD, or just plugged into to power). Sharp will do nothing for us, and has been a huge waste of our time. Anyone else with similiar problems? HELP?
  • Anonymous Mar 26, 2014
    A thin white line across the top of the picture. This a brand new TV
  • Anonymous Mar 29, 2014
    Thin blue line fixed on sharp aquos 32m400x lcd stil have great picture on through every channel and menu picture quality still great just annoying thin line 4 or so inches from left of screen...thinking not panel problem not pixelated Component problem?Loose Wire?Capacitor? Please help Find repair option Vs cost Great Tv Still Thankyou....
    Sniper:
  • 53 Answers
I've seen this problem before and if caught early (usually only a few pixels), its fixable. But if it has already started forming a "line" it might be too late and you might have a defective LCD panel. Most of the time, doing the factory initialization helps with this problem.
(WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
  1. unplug tv
  2. press and hold at the same time “Vol –“ and “input” button on the TV set.
  3. while holding those buttons, plug the tv back in
  4. the tv should turn on by itself, keep holding the buttons until the letter “K” appears. Then let go
  5. then at the same time press “Vol –“ and “Ch. Down”, you should see the service menu appear (if it does not appear, try pressing the two buttons again, it needs to be exactly at the same time)
  6. Then use the “Ch. Down” button to navigate down the service menu until you see “Industry Init” (NOT Industry Init +cause)
  7. Then press “Vol +” to toggle it to “ON”
  8. Then “/////////////////” should appear.
  9. when the screen turns GREEN, unplug the TV. Wait about 30 seconds, then plug the TV back in.
  10. Then continue on with the initial setup again.
Posted on Mar 28, 2008
The above procedure will turn your televison into a paper weight!
Posted on Aug 10, 2010
Is there a step missing in the above directions? I followed them and at step 7, toggled the Industry Init to on, but then nothing happens.
Posted on Apr 04, 2010
4 Suggested Answers
  • 103 Answers
SOURCE: Sharp Aquos LC-32D41U
The unit has bad drive ic's,which is part of the lcd panel.It is not cheap to fix.
Posted on Mar 05, 2008
rulds2008
  • 3866 Answers
SOURCE: Two red vertical lines down 32" Sharp Aquos LC-32P50E LCD TV
There are solutions for stuck "and not dead pixels" Here are a couple idea's to try and please do not rate me bad if don't work!! That would not be nice as i do not get compensated showing your solutions I get them by your "good ratings" Hence do not use "Thanks for Trying" rather helpful or fixya will do now here are the websites:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
http://www.jscreenfix.com/basic.php
If you TV can hook up to a computer witch it can through servral means then you can use this information. But However do not rate me Thanks for trying if the darn thing just dont unstick the pixels... Thank You for using Fixya.com
"were we can save you hundreds of dollars on repairs" It has been my pleasure assisting you today. Rulds2008- Expert Top 10 Fixya.com
Posted on May 15, 2009
  • 7 Answers
SOURCE: line accross top of the screen with flashing black and white boxes
Go to menu and settings and look for OVERSCAN and set this to on and hey presto no more white lines no matter what ratio your in.
Posted on Dec 31, 2009
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
My tv has thin black horizontal lines on screen while showing picture. this is not caused by cable since it happens while using ps2 or dvd player. I recently moved, but it was working fine after the...
that could be a sign of a bad panel. my experience is that these panels are more expensive than the tv itself, but might be worth looking into since I've heard about prices coming down
Mar 27, 2010 | Philips 42FD9954 42 in. Plasma HDTV
May 15, 2009 | Sharp LC-52D62U 52 in. LCD HDTV
I have a sharp aquos 52" with a thin vertical red line in center
If you have a thin line running down the screen, you may be looking at a service issue right off of the bat. Here is a few things I want you to try before calling sharp, 1. Reset the unit from the setup menu
2. Unplug the unit for 2 minutes then plug back in. If that does not work. Take digital pictures of the line and call sharp immediately. Make sure you tell the rep you want to sign up for the aquos advantage program that they have(extends your warranty 3 months free of charge!) because that will get you priority service on with your issue. If they cant resolve that line ,9 times out of 10 they will replace the unit. hope this helps you
Feb 15, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Sharp Aquos
Burnt out pixel line. Usually the panel needs replacing
Jul 13, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Westinghouse LTV-27w7 HD TV, two yrs old, blueish square flashing on & off, no picture.
if you have warranty work they will direct you to the service center you will need, I do not know of any bb that service tv's.
May 08, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Thin blue line
I am a Sharp Servicing Technician. You posted this before. Ive got the same model TV as you do LC46D62U. I think the line you are experiencing is simply the broadcast. I notice it on some HD shows that broadcast the side bars. (Always on the Ellen Degeneres Show). Ive taken some picture.
1) Here's the line on the left that i experience
2) Later on in the broadcast, it goes away.
One way to check if its a TV problem or not. When the line shows up again, hit the MENU button on the remote. If the line appears to be "behind" the menu, then it is simply the broadcast.
If the line appears to be "on top" of the menu or shows right through the menu, then it is a TV problem.
Im thinking the reason it takes hours for hte line to appear is because it only shows up on certain shows or certain HD broadcasts.
Mar 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Feb 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Line across screen
I have the same problem with my 42 in. The line started to show up randomly about 1 month after i got my tv. The line isn't a line of dead pixels since when i change the aspect ratio or the tv the line moves up or down. I called sharp about the problem and they said it had something to do with my computer but i don't think that can explain why the problem shows up on all my tv inputs.
Dec 17, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
2,436 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
