Question about Karcher 2500 PSI Pressure Washer
Pressure washer Honda Craftsman pressure washer 2400 PSI that runs for a little bit and then shuts off for no reason.
  • rappahannock Mar 28, 2008
    I have a Karcher K2400HH pressure w/Honda engine. After I start the motor then pull the trigger it will not engauge to start with pressure. I have to take the degree nozzel off, pull the trigger a conple of times, quickly put the degree nozzel back on & then sometimes it will build pressure. quick note I am using a 3/4" garden hose Thank You
  • Anonymous May 15, 2008
    same problem the others describe. Pull the trigger, gets pressure for a few seconds and then shuts down. I can remove the nozzle,pull the trigger and wait untill the pressure builds, insert the nozzle and repeat the proceedure. I can never run for more than a few seconds.
SOURCE:
  • 3 Answers
SOURCE: Karcher 2400 psi blaster When you
To determine if your problem is due to an easily replaceable part, follow these steps:
1. Connect the water supply hose, the pressure hose, and the wand WITHOUT any nozzle tip.
2. Turn on the water supply, and press the trigger until water is smoothly running out of the nozzle
after any air is all purged out. Release the nozzle trigger.
3. Start the engine, and let it warm up for about 30 seconds.
4. With the engine running smoothly, press the nozzle trigger. The water should flow out of the nozzle (without the tip installed) at a faster rate, while the engine noticeably loads down as it used to do before your "no pressure" problem. If it does not load down, turn it OFF, and disconnect everything, and contact a Karcher repair facility.
5. If the engine does load down, release the trigger, and install one of the nozzle tips (not the black one).
6. Press the trigger, and the engine should load down, and you should have normal pressure from the wand. After you release the trigger and press it again, you will probably again have no pressure, and the engine will not load down. Removing the nozzle tip, pressing & releasing the trigger, and re-installing the tip should give you normal pressure again, but releasing the trigger will cause no pressure until you again remove the tip, press the trigger, and re-install the tip.
This is caused by a bad UNLOADER VALVE, which is located under a black cap with a metal button on it located on the top front of the pump. I don't know if you can purchase the replaceable parts from a Karcher repair shop, but when a neighbor & I took his washer to a repair place, it looked pretty simple to do this repair, and he was charged about $60 to replace a $5 (maybe) part, and it took about 5 minutes.
Posted on Sep 17, 2008
stug_57u
  • 99 Answers
SOURCE: No pressure in the pressure washer
Leaving the hose on shouldn't cause a problem so don't panic. It sounds like you could just have a dirty nozzle. Try sticking a pin or something in the end of the nozzle (machine not running) and giving it a clear out. also if it is a two peice gun, split it and tap the squirting part on something clean like a workbench to clear any debris that might have got in there.
Posted on Nov 01, 2008
SOURCE: pressure washer wont run unless choke is on
I have a Karcher pressure washer w/ a 5hp Honda engine. It only will run while the choke is pulled out and only runs at about half the rpm's. When the choke is pushed in.. it coughs, sputters and shuts off. Can you tell me how to fix this....
Posted on Nov 05, 2008
  • 14 Answers
SOURCE: craftsman 4 hp 2150 psi pressure washer wont start
Go to www.karcher.com ,click on your region and then click international. Enter the model of the machine or the type number . That is is the first 8 digits of the number under the barcode. This will take you to the parts listing for your machine.
Posted on Mar 11, 2009
  • 33 Answers
SOURCE: pump on my pressure washer will not pressuerize
there is a loader and unloader valve on your pump bolted to it. if it frozen in the open position it will never build press. most of the time this is caused by leaving cleaning solutions in system after use and let set up for a long period. it causes the aluminum case to corrode.;you will have to dissassemble and clean if not to bad. if not your going to have to replace.
Posted on Apr 21, 2009
My Honda 4.0 1800PSI Power washer only has hose pressure when it should have 1800 PSI
hi spray some silicon oil in inlet and outlet then run attach hose back do this everytime you store the washer away it is because the seals dry up always lube when storing.
Jan 15, 2011 | ALL POWER AMERICA LLC AllPower America...
Karcher 2400 psi with honda motor started up big puff of white smoke from exaust it shut off noiw wont start whats going on
I have a john deere 3000psi pressure washer with similar problem. Running fine then a puff of smoke and it shut down. I checked the oil and found it full of water. Not only that but since I still had the water turned on, the water was flowing out of the dip stick tube. I'm trying to find a solution online and will pass any information on.
Nov 13, 2010 | Karcher 2500 PSI Pressure Washer
Pressure washer worked fine and suddenly no
If you remove the tip, will it work? If so, unloader valve is sticking and needs to be removed and lubed with lithium grease.
Jun 29, 2010 | Honda 2500 PSI Gas Pressure Washer
Hi, My question involves a:Honda GCV160 5.5Chore Master 2400 psi Model CV-2400=4MHC I have very little use on it. I broke the sprayer hose on it the other day and ordered a new one for this model. I...
  1. put in your garden hose
  2. turn on the water
  3. leave it to run for one min.
  4. kink the garden hoes
  5. connect the hi pressure hose "the one you ordered"
pull the trigger then start
if this don't work start the machine without the hi pressure hose.
no pressure machine needs valves.
Jul 31, 2009 | Garden
Husky 2400 psi honda engine ran fine all day
It sounds like the bypass valve is stuck. Do you have a parts diagram?
Jun 27, 2009 | Honda Garden
Pressure washer wont run unless choke is on
May 12, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
274 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
