Question about GE Wireless Optical Mouse
Wireless mouse won't sync - GE Wireless Optical Mouse
How to sync an HP laptop to a wireless mouse
Hello, The new hp laptops with win 8 aren't compatiable with the old wireless mouse. Wireless mouse are cheap now. So, will have too buy one.
May 15, 2014 | Kensington Computers & Internet
Belkin wireless mouse won't connect on power up of PC
A Belkin Mini Wireless Optical Mouse frees you from the restriction imposed by the limit of the wire that your mouse uses to connect to your computer. The Belkin model works up to three feet away from the receiver and operates on a 27 MHz frequency. It's smaller than a regular mouse, making it easy to add it to a laptop case or desk drawer without losing much space in the process. Before you can use the Belkin Mini Wireless Optical mouse, you must install it. The receiver and the mouse should sync automatically; if they don't, you must perform the sync manually.
1 Press the bottom release tab on the top cover of the mouse. Insert the batteries included in the package and replace the cover.
2 Turn on your computer. Plug the Belkin USB receiver into a USB port on your computer. The drivers will install automatically.
3 Press the sync button on top of the USB receiver and then press the sync button on the bottom of the mouse to connect the two devices.
Warning
  • close Before you can install the Belkin mouse, remove drivers for other wireless mouse types on your computer.
Jul 17, 2017 | Belkin Mini Wireless Optical Mouse...
How do i get my wireless technika mouse wm110pk to connect to my laptop?
Insert the USB dongle that came with your technika wireless mouse into a USB computer port on your machine.
This dongle, which resembles a regular flash drive in appearance, can be plugged into any available USB port.
Once inserted, it immediately turns on.
Insert the required amount of batteries (typically two AA batteries, though it changes depending on the model) into the compartment on the bottom of your HP wireless mouse.
Flip the "ON" switch on the bottom of your technika wireless mouse.
Press the "Sync" button on the bottom of your technika wireless mouse.
The mouse will now sync with your computer and will be immediately usable.
hope this helps
i have read some good and bad reviews on this mouse one stated the wireles stopped working several times and it had to be replaced
Oct 12, 2012 | Computers & Internet
It won't sync
Click on the USB small button "after attach it to the computer" one click. While the red tiny led flashing - turn your mouse updown and hit the small button.
When the red flashing led stop - then you connected.
May 16, 2011 | Belkin Mini Wireless Optical Mouse...
Cant get my wireless mouse to work
1. Press the sync button on the reciever (the only button on the reciever)
2. When the light blinks, press the sync button on the mouse (the button you are talking about on the mouse is a sync button, not a reset button, there is no reset button on the mouse), after you press the sync button on the mouse, the blinking will stop and will remain steady
Please post your feedback and Vote if the proble resolved as per your satisfaction.
Aug 17, 2010 | HP Wireless Optical Mouse
I have a Logitech wireless mouse and it is not working with my laptop after about 6 months... the batteries have been changed
After replacing the new battery with new one have you press connect button from the mouse side and the receiver side also. It is necessary to sync with the sensor the after replacing the battery
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 02, 2010 | Logitech Cordless Mouse
What is the syncing process for a logiteck wireless mouse
Take your wireless receiver that is connected to your computer and turn it over. There should be a red button. Press it once (propably a led light will start flashing). After you do that, take your wireless mouse and do the same. Turn it over and press the red sync button.
Your mouse should now be synced.
Feb 07, 2010 | Computers & Internet
My hp wireless mouse does not work and i cannot sync it to my PC. the wireless keyboard works fine and i am able to sync it. how do i fix my mouse problem?
Remove the battery of the mouse and install new one and then press connect button from the mouse side and the receiver side also.
Nov 25, 2009 | HP Wireless Optical Mouse
I need to connect my mouse
There should be a tiny sync button on the mouse and the USB receiver that connects to your computer. Make sure your computer is on and loaded, then connect the USB receiver, and make sure the batteries are functional in the mouse. Once it's set up, simply press the sync button on the receiver, then press the sync button on the mouse and wait for it to sync up.
If your wireless adapter is bluetooth, you'll have to install the software that came with your mouse, and use the software to synch the mouse.
May 05, 2009 | Dynex Wireless Optical Mouse
Wireless optical mouse light does not blink
possible solution, is replacing the batteries. if the sync light blinks we round up with a battery problem but if not. its going to need a replacement i hope that helped. hit me back.
Apr 30, 2009 | GE Wireless Optical Mouse
GE Wireless Optical Mouse Logo
195 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
brian soufane
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
