Question about Cell Phones
I have a Samsung a790 with Verizon service. In certain areas (e.g., Morristown, TN; Cincinatti, OH) when I dial a number with 4 bar signal strength, after a few seconds the signal strength progressively drops to 0 bars and I get the notice "signal faded, call was lost". After ending that call the signal strength goes back to 4 bars. I have updated my programming and roaming. I have shut it down and removed the battery. I have this problem but others standing next to me (on Verizon) have no problems connecting.
  • 818 Answers
Http://downloadcenter.samsung.com/content/UM/200708/20070824010442906_verizon_wireless_a790_ug.pdf
go the page of the antenna. seems this the problem.
Sergio
Posted on Mar 27, 2008
    Genius:
  • 3,422 Answers
HI,
There are few troubleshooting steps you can try:
1)reset your cell phone by following the steps mentioned in the user manual which was provided with your phone.
2)Does this happen while you are stationary or driving? If while
driving it's possible you've pulled up beside a large building or
truck that may be temporarily blocking the signal.
Another thing you can try is putting your phone's roam setting on
any other option rather than Automatic so it won't attempt to roam when the signal becomes weak. I've found that this reduces dropped calls when I know I'm not going to be leaving a Sprint service area.
Goodluck,
Please don't forget to rate the solution.
  • Priya darshan Mar 27, 2008
    your phone sees a
    strong signal from one tower but then it decides to switch to a more
    distant tower with a weaker signal. Could also be a tower handoff
    problem. One tower doesn't have the other tower in it's neighbor list
    to handoff to so it drops the call instead. All very common problems
    on CDMA networks.
    You should consider switching to a superior carrier, friend.
    Novelist:
  • 142 Answers
I've read about this type of thing... Your phone uses CDMA as a technology. The US is much better known for GSM technology. CDMA is prone to drop-outs due to volume (ie: lots of people on the phone at the same time). Forget about tech support ever admitting to this. I've heard that for the CDMA technology, your drop-out rate will be noticeably different depending on what model of samsung phone you use.
The other people standing next to you are probably using a different model of Samsung phone or they're using a Nokia, which for some reason handles CDMA more successfully.
I know this probably didn't provide you with a solution... well maybe take note of the models of cell phones that seem to work better and consider switching cell phones. I hope this helps some. Good luck.
    Genius:
  • 1,913 Answers
Reset your cell phone.
then try
My phone goes to no network coverage area message without network bar in phone.I had reset to factory settings but its not resolved
there is not enough info to answer this question. is it att/tmob? or is it verizon/sprint? are you in a low signal area? are other people with the same service missing service too? have you recently changed your network settings? if you can answer this for me i can almost certainly tell you whats wrong. TIA
Nov 25, 2015 | Samsung Galaxy Note 2
Tip
How to boost cell signal when service is poor
If your cell signal is going down especially in an area you normally have good service in or if you never turn your phone off with cdma technology( verizon, alltel, tracfone, ...no sim card) if you dial *228 from your cell hit send like making a cal and press option 2 it will update the phones signal and roaming capability and any new updates that your phone may not received due to bad area travel or not powering the phone on and off. It usally increases by one to two bars and if you are unable to get it to go through drive into town near any verizon wireless store they all have cell towers near them and try again. this can be done any time any where there is cell service within the continental u.s. and I do it if I travel from my home to the town 30 miles away because the signal changes so dramatically between towns. just a tip if your bars are dwindling away to nowhere.
on Jun 05, 2010 | Cell Phones
My huawei h881c keep droping server connect how i fix it
Make sure you have at least two bars of signal strength before attempting calls or data transfer. You may have to sit near a window.
You responded that you have 3-4 bars of signal. I suggest you visit your carrier's place of business (AT&T, Verizon, etc.). Demonstrate the problem to the representative there.
Oct 02, 2015 | Huawei Cell Phones
What phone number can i call for tn lottery
Main Phone (General Inquiries) : 1-615-324-6500
Player Services Hotline is available Monday - Friday, 8:30 a.m. - 5:30 p.m. CT In the (615) area dial 254-4946 In the (901) area dial 466-4946 In the (865) area dial 512-4946 In the (423) area dial 939-7529 All other areas in Tennessee dial 877-786-7529 Outside Tennessee dial 615-254-4946 Retailer Services: 1-800-826-4311
HEADQUARTERS
Mailing Address
P. O. Box 291869
Nashville, TN 37229-1869
Physical Address
One Century Place
26 Century Blvd.
Suite 200
Nashville, 37214
(615) 324-6500
Feb 25, 2015 | Computers & Internet
How to increase connectivity and strength of 2G and 3G network
@Surendra
It's based on dBM and asu and not the bars you actually see. Even if you may see fewer bars you could have equal quality. The phones, based on different OS may be calibrated a little differently. It's best to contact your service provider and verify....
1. Your SIM is properly programmed.
2. Your PRL is updated
3. You have a recent SIM
Mark
Motorola Support
Nov 04, 2014 | Motorola Mobility XT912 Droid Razr Verizon...
How to increase my symbian mobile signal strength ??
I had same prob - after buying an LG Smartphone (SP) to replace my Samsung Mantra flip phone (FP), signal strength was so low that i couldn't use it except as a pc on wifi, so i had the FP reactivated. After ~ 6 mos sprint upgraded the tower and i had the SP reactivated. Now i get 1-4 bars, but if only 1-2 bars voice is sometimes nearly unintelligible... You CAN buy a signal booster and use it in your residence but the cost is hundreds of $. Or you can do research and try to find a SP which has high signal sensitivity. The Samsung Mantra FP has very good signal sensitivity and worked fine even before sprint upgraded the tower... the LG SP has much less inherent signal sensitivity and so needs a stronger signal to function. But there's more to the story...
If you have home WiFi you can switch to T-Mobile and use their WiFi option with your SP to send and receive cell calls via WiFi when your SP WiFi is enabled & connected. I suspect this is what I'll do myself when I get tired of the poor voice quality my sprint LG SP is now delivering. And my guess is that the WiFi option will be offered by all carriers evenually. T-Mobil is just ahead of the curve... IMO.
Dec 07, 2013 | Nokia 5800 XpressMusic Smartphone
Poor reception
select automatic network selection option from setting
May 20, 2012 | Samsung SCH-a930 Cellular Phone
I live in a rural area and can't get a signal
That is a common problem. I have had that issue myself. Motorola's pull a better signal in a rural area than LG. I would see if you can do a return exchange for another like phone that is a Motorola. It's the way the phones are made that makes the signal strength different.
Nov 12, 2009 | LG enV3 VX9200 Cell Phone
My O2 samsung phone has suddenly stopped receiving txts and calls.my friend tried to ring me and it just went to voicemail. my signal bar is full and so is my battery. i tried taking the battery out and...
if you can still dial someone, but can`t receive anything, try dial ##002# , then ask someone to call you. for the txt verify the sms center number, if you don`t know it call customer service
Nov 11, 2009 | Verizon Communications Samsung Alias Cell...
Cell Phones Logo
117 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
