Question about Peavey PVM 22 Microphone
Got a knock now it wont work - Peavey PVM 22 Microphone
    Scholar:
  • 70 Answers
Hopefully the sensor in the mic is not damaged. if it is a new mic will be needed. I would sat that you may have broken a solder connection inside the unit and you will have to take it apart to see where the problem is. hope this helps.
Posted on May 08, 2010
Panasonic lumix camera was working and now it wont even power on
Make sure that you have a good battery in it. If confirmed then the electronics have died and you have the unenviable choice of repair or replace.
Jun 17, 2016 | Panasonic Lumix DMC-FZ72 Black Digital...
Engine knocking/rattling wont speed up smoking
sounds like a plugged cataliyc converter
Mar 20, 2014 | 2009 Toyota Camry
It wont start not even a sound i have lights
Check for power at the big cable on the starter motor. The little wire should have power when key held in start posision. If have power to them have someone hold key in start poss & give starter solinoid a knock with hamer if no go knock starter body. If go when knocked need new starter
Jul 05, 2012 | 1998 GMC Jimmy
I have a 1996 Toyota Avalon XLS V6. Engine light is on and im told i have a bad Knock Sensor. It has 2 and @ $150ea. Is there a cheaper or way to fix or bypass this problem? Ther isnt any knocking or...
i honestly have never seen a knock sensor go bad. a knock sensor detects spark knock,which is from low octane gas. if it hears this then the ecm retards the timing to stop the knock. you wont be able to hear the knock that its listening for. its like a little microphone stuck in the block. before you replace it you might want to check the plugs on the sensor itself. if they are corroded they could cause this problem.. ANYTIME you have engine codes ,always check your ground cables on the engine and the battery. i work in the marine industry and you would be amazed all the codes you can get just from having a corroded battery cable..like i said , i have never seen a knock sensor go bad..
Dec 10, 2010 | 1992 Toyota Camry V6
I start my truck an the robs are knocking and it
I believe there is a knock sensor on this engine causing it not to run. If the knock is too bad it wont run....It actually probably saved your engine....find out why the knock...out of timing?...clogged fuel filter? bad gas? thrown rod?
Aug 26, 2009 | 1996 Ford Explorer
1996 nissan quest. car wont start and just keeps trying to crank. it has a knock sensor code that i pulled out of the dtc. it has no injector pulse and we are trying to figure out if the knock sensor...
Have a bad knock sensor on my 06 villager and no problem driving it daily, most likely you may have a coil problem, fuel pump or MAF sensor problem. Hope this works
Jul 29, 2009 | 1996 Nissan Quest
Oil pump went out replaced it. now the truck wont turn over.
Usually a knocking noise means that a rod bearing is worn out. Since your oil pump was replaced, you may have spun a bearing. I would suggest that your engine needs to be replaced.
May 20, 2009 | 2000 Chevrolet S-10
Disposal wont work
The reset button might be around the back, depending on which side the outlet is located on. It takes quite a good push to reset it.
Feb 15, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My son knocked over his 360 and now it wont work
When the console was knocked over, the cd drive was knocked off center. Meaning that now whenever you put a cd in and power on the console, the cd will be "grinded" and desrtoyed. The console will need to be sent in for repair to Microsoft or another repair company. And please do not insert any more cd's into the drive.
Dec 30, 2008 | Microsoft Xbox 360 Console
Peavey PVM 22 Microphone Logo
64 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
