Question about Garden
Homelite UT 10522B Chainsaw fuel line routing
I need to know where all of the fuel lines go. I thought I remembered correctly but I don't think so. Some please just tell me the routing start with the line that has the filter in the tank and end with the larger line in the tank. Explain where each line connects or provide a drawing or diagram.
Thanks,
  • 384 Answers
SOURCE: mcculloch 4600 chainsaw fuel line routing
Shouldn't be that hard to do. Possible paths 1) Run hose from tank fitting to Carb fitting. 2) Run hose from tank to shut-off vale to Carb 3) Run hose from tank to shut-off to prime to carb 4) run hose from tank to shut-off to prime to filter to carb. Omit any item not on your saw.
Posted on Jun 12, 2009
  • 508 Answers
SOURCE: Primer bulb is part of the fuel cap.
http://www.upstateoutdoorpowerequipment.com/?gclid=CJrT2dXno5sCFQk_agodVn7zAg
GoodLuck!!!!
Posted on Jun 24, 2009
  • 4088 Answers
SOURCE: Homelite ut No. 10748 textron New sitting long
Is there bar oil in the tank? Oil pump and/or pickup tube in oil tank are usual suspects.
Posted on Jul 04, 2009
dontbother10
  • 2220 Answers
SOURCE: fuel line diagram for 358.352160
It is most likely a Poulan almost all are. The IPL is the only manufacturer supplied fuel system detail, it lists components, part numbers and very little routing detail. and is usually spread over multiple illustrations.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
I think you'll find the short video, a few notes and a typical system most helpful. Any local saw shop can provide replacement hose.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
HTH
Lou
Posted on Nov 19, 2009
Mentorcase
  • 5 Answers
SOURCE: i have a walbro hdc 39 carb. thats need to be
This place has the kit you are looking for
NEW Walbro Carburetor Kit OEM K10-HDC http://stores.ebay.com.au/Bartz-Mower-Service
Posted on Dec 08, 2009
Testimonial: "thank you "
How do the fuel lines rout on a homelite 45 including from tank, primer bubble to the carbeurator
Without the UT number from the saw won't be able to give more detail carburetor hookup. Here is a generalize fuel hook-up diagram.
Depending on the carburetor both of the fuel lines can be on one side only. The suction line connection for the primer is usually closest the the metering diaphragm.25331542-pzxv2dmyt02yqunciumgycfv-5-0.png
Dec 21, 2014 | Homelite Garden
Fuel line routing
i took the homelite 330apart in doing so the lines broke no problem i needed to replace them any way so now im confused to where they all go
Oct 01, 2013 | Homelite Zama Rb3 Carb Kit 330 Chainsaw...
I have a homlite chainsaw with a zama c1q h17d carburetor and need the correct fuel line routing including the oil pressurising line
One fitting on the Carb is a bit higher than the other.
The Upper one is for the Gas return when you press the Primer bulb. The Lower one is for the Gas intake...the gas line with the Filter on the end.
Is thee a small fitting for the Pressurizer on the small spacer??
Oct 01, 2013 | Homelite Garden
Fuel line routing for craftsman chainsaw 358.350370
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Jan 11, 2012 | Garden
How to replace the fuel primer bulb and fuel lines in McCulloch 3516 chainsaw? the fuel primer bulb broke and the plastic lines have crumbled. i need to know how to run the lines from the fuel tank to...
I just did a primer bulb not too long ago, but I don't remember what equipment it was on. They are generally easy to replace. First, remove anything that is retaining the bulb assembly, such as cover plate. On my Homelite chainsaw, I simply pried it out with a small screwdriver.
The replacement part itself has two barbed stubs that the two fuel line hoses push onto.
Make sure that you keep the fuel line tubes above the fuel level at all times to prevent leakage.
Dec 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How do I access the carb. to attach a new gas line from the tank on a Homelite Chainsaw 150 UT 10400A
Remove the air cleaner and the carburetor itself. Replace the fuel line and bring the upper end past where the carburetor connects to it. Reinstall the carburetor, cut the line to fit, and push it onto the carburetor nib. Make sure the other lines are in good condition. Be sure to check the fuel filter for plugging while there. Hope this helps!
Oct 23, 2010 | Garden
My homelite chainsaw model# ut10520 has aoil leak from the flexible line at the base of the oil tank.
I input your model number and found 3 possible matches, "42cc/46cc Chain Saw UT-10520; SUPER 2 Chain Saw UT-10520 or SUPER 2 Chain Saw UT-10520-A".
I opened the first "Ref # 3" on "Figure A" I suspect is what you say is leaking. It is very inexpensive and available. I would order one and inspect it once recieved to determine an installation method. It does not appear overly difficult without the part in hand. Good Luck.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 07, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Feb 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
244 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
