Question about HP Photosmart D5360 Printer
Carraige jam. Screen says to clear carriage jam
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 08, 2010
  • 1,218 Answers
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • * Turn off the printer and open it to see where the paper is stuck.
  • * Manually move the carriage toward the opposite side.
  • * Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • * Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Posted on Sep 28, 2010
Clearing Code 3527 from Kodak Hero 9.1
Hi friends,
I was able to solve this problem (error code 3527 on Kodak hero 9.1) by opening the printer entirely (dis-assembled), Checking the cartridge carriage assembly, i discovered that the belt that drive carriage assembly had a locker that was broken as such, the carriage assembly could not move in the direction as the motor drives the belt on.
I simply inserted the belt in position and drop a little drop of super glue to it, let it dry off.
Assemble my printer, and it was ok and is working.
Aug 01, 2012 | Kodak HERO 9.1 All-in-One Printer with...
Whenever i try to print it does 1/2 page then the cartridge keeps getting stalled on one side. Error message on screen says print cartridge stalled, error message on printer says clear carraige jam. Cannot...
If there's a carriage jam. While the printer is turned on, Open the access door of you printer.
If the carriage is stuck at the left side, try moving it manually by hand to the right most part of the window. If it's stuck on the right, try moving it by hand to the left.
If you've already done that. While the printer is turned on, unplug the power cord from the back. Close the access door. And then plug it back in.
Make sure you restart the computer first just to avoid documents getting stuck in the print queue. Try printing again. Usually it does the trick.
Feb 03, 2011 | Office Equipment & Supplies
Carriage Jam
Carraige rod is the rod that holds the cartridges and moves while printing on the paper and spreads ink on the paper and if this rod is jammed it is known as carraige jam.
Please follow the below steps.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01423360&cc=us&lc=en&dlc=en&product=3204464
Please open this link and follow the steps.
If still the issue persists, please follow the below steps.
STEP 1.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 2.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Thanks Bye.
Please take care and KEEP SMILING.
Apr 10, 2010 | HP Photosmart C5280 Printer
It say carriage jam
Hi friend,
What probably happened is that paper jam caused the carraige alignment sensor to get out of place or to get covered, moved, etc and the printer doesn't know what to do...
What I would suggest trying is, unplug the printer, try pulling the carraige out to the center and then close it and plug it back in, see if this kicks it enough to reset itself.
Thanks,
Mar 20, 2010 | HP OfficeJet 7410 All-In-One InkJet...
A jam message that wont go away
Hello jmcmeeking
Open your printer like you are going to replace the ink, re- install ink cartridges close it up.
If that does not work, then open the printer ink department push the ink carriage all the way to the right it might be it can’t find the home position sensor. Turn it off and then on.
Good Luck
Oct 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Cartridge carraige jamming
plz send it for repair as it is due to hardware failure
May 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
Carriage jam
My wife had replaced bith ink cartridges and the carriage was also jammed! what she did was helped the cartridge carrier up some and it finally clicked in!!
Jan 23, 2008 | HP PSC 1610v All-in-One Printer
Carriage Jam
I FIXED MINE YES... open your thing.. and look,... do you notice..
theirs like a small black.. corner shaped thing, that stopped the carriage..
pop that thing like add force to push it back...
boo ya. :) and their you go...
this problem annoyed me for a month. and i went through numerous hp printers too.
but, just...... really open your eyes and try to find out whatsup..
:) woot woot woot imma print stuff now.
Nov 01, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Carraige Jam
maker sure the cleanout station is not stuck..it moves also...dont break it just see if it isn stuck...move the carriage back and forth. put paper in it and turn it back on.....if that does not work..take the paper out ..open the back and roll th big wheels a bit and try again.
Oct 13, 2007 | HP WanProbe V-Series Network Monitoring...
HP Photosmart D5360 Printer Logo
558 people viewed this question
Seeker5211
Seeker5211
