Question about Whirlpool Duet GHW9150P Front Load Washer
Front door does not open
Drain pump continues to run... the front door does not open ..
  • Whirlpool Master
  • 8,220 Answers
Must be something in the pump. Take the bottom panel off and open the pump cleanout. Tech sheet for trouble shooting is just behind the motor control unit(white boX) to the left there.front door does not open - be0ff1b.jpgdb21830.jpg132e75c.jpg
Posted on May 08, 2010
Testimonial: "thank you.. i'll go home and try it out!"
2 Suggested Answers
  • 56 Answers
SOURCE: GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Posted on Feb 07, 2010
Door open wont washer
Possibly some foreign object has worked it's way down into the drain pump, preventing the washer from draining. all the way. (If the washer doesn't drain properly, the door will remain locked).
One way is to take the drain hose out of the wall connection, lower it to floor level & allow it to gravity drain. (Be sure to catch the water in a pan or something). Once the washer has drained, the lid should open.
If this fixed the problem, the pump still has something in it. You will need to remove the back of the washer and check to see what's blocking the discharge pump.
Remove the back of the washer, remove the hose running to the drain pump, remove the pump itself & remove and debris clogging the pump.
Otherwise a service call runs somewhere between $100 - $175.
Apr 16, 2014 | Washing Machines
Water does not drain
Is the drain line clear? Also sounds like time on water inlet is running to long. Front loaders don't use that much water.
Mar 21, 2014 | LG WM0642HW 4.0 cu. ft. Front Load Washer...
Bosch dishwasher shx46a06uc-30
the unit will try to complete the last command it was engage in before it went in the overfill safety mode. you must perform a cancel drain cycle to reset unit to default setting. Remember the drain cycle is 2 min and must be completed to reset main control. however if it went into a overfill status you have a leak and it generally comes from the pressure chamber on the lefthand side of unit where the water enters tub
Apr 17, 2012 | Bosch 24 in. SHX46A05UC Built-In...
When my Bosch classixx diswasher door is open the pump continues to run. I took off the bottom panel and there is a styrofoam disk sitting in the base. Is this responsible for the shut off? Initially there...
Hello
Have a look at your door switch that its not jam'd up or there is a wire off, this switch will shut the pump off when opening the door
Thanks
Jun 04, 2011 | Dishwashers
Bosch SHU runs even when the door is open, what do i need?
Hi Jeffrey,
This depends what you mean by "runs". If the dishwasher continues with a wash cycle - i.e. circulating water - with the door open, the simple answer is that you have a defective door microswitch.
However, I suspect what you perceive to be the dishwasher running, is actually the drain pump running continuously. This happens when the anti-flood protection system has been activated and continues even when the door is opened. The simplest way to check is to open the door (while it's "running") and pour some water into the tub. If the water drains away immediately, this shows the drain pump is running and the anti-flood protection has been activated.
This may be due to water having leaked into the base of the dishwasher, but it could be as simple as a stuck or defective float-switch.
Please try the simple test above then post back for further assistance. If you're planning to investigate or repair this yourself, you're going to need a Torx T20 screwdriver and a multi-meter would be useful as well.
Regards, BElectric
May 25, 2011 | Bosch SHU9915UC Dishwasher
Kenmore elite front loader washer:door locked after repair
If you have cleaned the drain pump and checked ALL the drain lines (this includes the drain line that runs from the bottom of the wash tub to the inlet side of the drain pump), then you may have to replace the pump.
Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and cannot pump at the correct volume to complete the drain cycle, the error code will continue to appear until the pump is replaced.
The following link explains how to replace the drain pump (if required):
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I hjave listed also have helpful exploded view parts illustrations to assist you in locating and properly identifying the parts you need.
If you are having problems with unlocking the washer, there is a manual release you can use to get the door open: http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_ The problem may just be a momentary glitch in programming related to the "F02" error code you are receiving. If there are any error codes present, the washer will not complete a cycle and will shut down. I would recommend double checking the drainage system one more time to ensure there's nothing caught in the pump impeller or any of the drain lines (you may have overlooked something), followed by replacement of the pump if the problem continues. This will hopefully cure any others issues you may be experiencing with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Feb 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Feb 07, 2010 | GE WBVH6240F Front Load Washer
Cannot get the door to unlock. The washer started displaying (F21) on the led panel. I looked up what the code mean and it said to check for kinks or other obstructions that would keep it from draining. It...
I don't know where you got your instructions from, but you do not have to remove the front panel on a Whirlpool Duet to access the drain pump. You just have to remove the toe panel directly below the door. If you are attempting to remove the bellow and door latch for this procedure, you're going about it the wrong way. The filter that is being referenced is in the drain pump. The following link explains how to access to clean:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
You may have something getting caught in the pump impeller and slowing it down. Or, you may have something clogging the drain lines. Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
NOTE: The "SUDS" error can also commonly occur with the F21 error code as this is can be generated when air is sensed in the drainage system.
If the door won't open it could be jammed due to the program being interrupted. There is a manual release you can use to retrieve anything left inside the drum. The following link explains:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
In most cases, simply resetting the door in this manner will restore normal operation.
If you have any questions, please let me know. I hope this helps you.
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE front load washer- error msg "door locked"
have you checked for any foreign objects in the drain pump itself this if the most likely problem.or the drain pump has completly stop.make sure you pull the drain hoses from the pump and check for foreign objects if there is still water in the unit use a shop vac and connect it to the drain hose to remove all the water before disconnecting the drain hoses. after the water is drain this may unlock the door as well
Sep 16, 2009 | GE WSXH208A Front Load Washer
My front load Tromm LG washer flashes OE message, won't drain or finish wash. Door does open
oe is an error code for pump problem disconnect power cord open small door on lower front of cabinet pull little tube out and plug from tube and drain water in to bucket after water is drained unscrew cap of pump to clear out any obstructions reinstall the cap and plug and give a test run
Dec 20, 2008 | LG WM-2277HW Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
