Hello- There is no fuse. Unplug. Start by checking cord connection at bus block on back of range. If connections are tight and look good, move up to control panel and check plugs and wires. Inspect board for any hot spots. Best case loose connection, worst case 140$ control. Let me know if this info helps -have more if needed. -Thanks- ED
f 2 code states that oven has exccded 590 deg w/door in unlocked position or 990 f in locked . either the themp prop is bad or the relay in the EOC ( clock ) is welded closed . I would replace the prob first ( less expensive ) then the clock if needed .. **** ..
