Question about Whirlpool Dryers
My gas dryer only burns for 15 seconds. which
My whirlpool roper gas dryer only burns for 15 seconds. which sensor do I replace?
  • Whirlpool Master
  • 8,220 Answers
Its only supposed to burn 15 seconds. That is normal. It cycles on and off all during the cycle. If it stayed on the thing would burn up. If you mean it works and quits or takes a long long time to come back on then you need to replace the control solenoids. Fell them after a burn. The hot one is the problem. my gas dryer only burns for 15 seconds. which - 58a72fb.jpgpart number 279834
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 08, 2010
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
Roper Super Capacity natural gas dryer works but doesn't heat up
Hi
If your dryer is not heating, then check if the power cord is plugged into the wall. It may be loose or disconnected. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working. Now, check whether the heating element in your gas dryer is burned out by using an ohm meter to check for continuity. If the continuity is not there then you would need to replace the element. After checking the element, check out the thermal fuse to see if it's burned out. The thermal fuse is attached to the exhaust duct on the back panel of the gas dryer. It's usually surrounded by a black resin material situated in a housing made of white plastic. If the fuse looks like it's blown, then it needs to be replaced.
Now, check the igniter, there is a plastic connector attaching the igniter to the burner. Disconnect this and place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance. If the reading is above 100 ohms then igniter is bad. If the igniter passes the test then you need to test continuity on the flame sensor. You should have continuity between the two contacts. If not, then you need to replace the flame sensor. The sensors are usually located close by the igniter so are easily visible. Hope this helps...
Daniel
Sep 15, 2010 | Roper REX4634KQ Electric Dryer
ROPER GAS DRYER IGNITER LIGHTS THE GAS BUT GOES OUT AFTER 30 SECONDS
The gas valve coils are weak and dropping out. Replace the gas valve coils.
Jun 17, 2010 | Roper RGX4634KQ Gas Dryer
The flame goes out after 15 seconds, then 1 minute later comes on for 6 seconds. Replaced the coils and the problem continues. Replace the flame sensor?
Pull the 2 wires going to each thermostat and tape them together until you find the defective t-stat...I beleive you have 2 of them plus 1 white one in the rear of the dryer..
Oct 20, 2009 | Whirlpool LGV4634JQ Gas Dryer
Not heating up
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. igniter igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor) Replace the sensor (located near the igniter) if found defective.
Sep 24, 2009 | Roper RGX4634KQ Gas Dryer
Dryer runs, but does not heat
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
2. Thermal fuse
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Jul 17, 2009 | Roper RGX4634KQ Gas Dryer
Gas Dryer does not continue to heat.
Check the Following to address this issue--
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 02, 2009 | Whirlpool Dryers
Dryer's flame cycles but will not burn
Check the following to address this issue..
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 01, 2009 | Dryers
Roper gas dryer mdl RGS7646KQ2
hi keith. yes replace the 2 coils on the gas valve. it will solve the problem. thanks the appliance doc.
Oct 16, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
102 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
