Thermostat no power/ fuses blown
I had no power to my thermostat.... there was a LED light blinking an error code that said secondary fuse open.... ichecked inside the panel area and there was a blown fuse on
the circuit board, after i replace the fuse...the LED light was on continuously which said the system was getting 24v...I set the thermostat to fan and it kicked fan on, i set it to auto and set the heat up but it would not kick on.. then i went back down and both the internal circuit board fuse and external circuit board fuse were blown???
  • 5 more comments
  • woockman1 May 09, 2010
    sorry i am somewhat of a novice... i have a multimeter but how do i check the continuity of the thermostat wires? my black prong(multitmeter) on common wire? red prong(from multimeter) on each of the others individually? with the AC setting? or ohms? 0.00 for good any reading for bad?
    I went down the furnace unit and jumped the green and red wire... then i went up to the thermostat and the ohms were 0.06 from green to red....also did this with common and green same thing...so i assume that means we have continuity for these wires..Does that mean no shorts in those wires?
    Also i shut off the thermostat and did ohms from green to red i got a reading and also got a reading from common to green...so no continuity while system off
    very possible....
    When i replace the fuses the fan alone will work and power is back to stat...as soon as i switch it too "auto heat" i hear it try to kick on and then it blows the fuse, does this make sense with a bad board?
    How do i test the element?/ where exactly is this. i have a multimeter...but explaining exactly where to test it would be appreciated
    my furnace is a payne model # pg9maa036080
    http://www.docs.hvacpartners.com/idc/gro...
    It is very similar to this...if not the same but older model...
  • woockman1 May 11, 2010
    Just wanted to thank the first solution guy he had it right a shorted wire i just didn't look close enough outside in the condensing unit. found the short...back in business
  • 12,061 Answers
This has happened because of an Overload, probably a short circuited element, you need to test the element. you should not just ever replace fuses without first finding out why. it happened. Any circuit, of any heater is pretty basic, usually, we have a switch, a thermostat, a thermal fuse, and an onboard fuse, terminating on the element, returning on the neutral. It works basically, by the switch puts power to unit, this powers the electronics, which monitors the thermostat,that has contacts in series in the Phase wire, before the element, when the thermostat's temperature is reached the Contacts, OPEN, and cut power OFF to the element, it cools down, and it turns ON again, over and over keeping the temperature constant. There is a Power fuse, in case of a short circuit, or overload, and generally an "Over heating" or "Thermal Fuse" too. All fuses are in the Phase Line, and break the circuit when activated.
Posted on May 09, 2010
    Guru:
  • 825 Answers
Replace the fuse after reading the fuse specification in thermostat manual....
If the fuse is heavy bonded, then it will not blow when there is a need.... It will make other components to blow....
So replace all the fuses only according to the specification...
fuses varies according to the thickness off the wire used in it...which is directly proportional to the resistance....
so use only recommended fuses with recommended value...
Posted on May 10, 2010
  • 8,220 Answers
You must have a shorted thermostat wire somewhere. Turn the thermostat off and check for continuty between the wires coming from the stat. You should have no continuity since that stat is off amigo. If you have continuity that would confirm bad thermostat wires.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
  • 7 more comments
  • Dan Webster
    Dan Webster May 09, 2010
    Here is multimeter directions.
    Basically set the meter on audible beep for continuity or the needle hops over whn the 2 leads are touched together thus proving a circuit right? Then remove the wires to the thermostat and check for a beep with the thermostat off. If you gt continuity then the wires are rubbing and shorting out the transformer.
  • Dan Webster
    Let me know
  • Dan Webster
    I would get a pro out there. You need a board change out most likely.
  • Dan Webster
    Is your furnace similar to this one PAYNE FURNACE
  • Dan Webster
    Check your transformer. It could be shorted out.
  • Dan Webster
    Look on the board for something shorting it.
  • Dan Webster
    Dan Webster May 11, 2010
    Thanks. Glad you got her done amigo!!!
  • Dan Webster
    Dan Webster May 12, 2010
    Thanks!
  • Dan Webster
    Thanks for the great rating and the rejection. Lovs dat.
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
No power to set no led lights blinking
Could be an open internal fuse or power supply failure
Sep 06, 2016 | Panasonic Viera TH-42PX80U Plasma TV
Phillips TV doesn't turn on. Short LED activity (400ms) if the cord is unplugged and plugged back into the outlet. The LED lights up for 400ms and goes dark. Read details for more.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Jul 13, 2016 | Televison & Video
Air conditioning wont turn of, error code at furnace appears to be 24 - secondary fuse open?
There is a 3 or 5 amp fuse on the control board inside the air handler.
Disconnect power to the air handler,locate the fuse and replace it with a good fuse.
The fuse is the same type used in automobiles.
You can purchase them at a auto parts store.
After replacing and turning on the power there will be a 5 minute delay before the board and thermostat energize.
After 5 minutes set the thermostat for you heat or ac function.
If the new fuse blows a complete diagnostic must be done to the system.
Apr 24, 2011 | Carrier Heating & Cooling
Turn on furnace and nothing happen
Ok, go to the furnace and look for a small viewing port. In it you should see an LED light. If it is blinking you may have an error code. If so, look on the reverse side of the front panel for a wiring diagram and error code diagnostic chart. If no LED, look for an Emergency switch that may have been turned off, blown fuse or circuit breaker or there may be a fuse on the PC board that may be bad.
Mar 13, 2011 | Ruud UBHC Air Conditioner
My thermostat has no power
It sounds like you have a short or a ground in the control circuit. Somtimes you can spot a bad component with your eyes. Look at the different relays to see if any looked burned. You might also look for a wire that has came off and is touching ground. You mentioned you put it in auto heat. This could narrow your search to components for heating. The problem could be in the coil on your reversing valve. I don't know if you have any trouble shooting experience, but if you have a multimeter you could do some resistance checks to find the problem.
May 02, 2010 | Heating & Cooling
Tv turned off while watching it and wont come back on, this has happened for a second time after having repaired it for the same thing 27 days ago, the tv is but 2 years old and has always been hooked up...
What was the previous problem and solution? is this a different problem than before?
Sounds to me like power isnt getting to the components.. at least to operational voltage where it will illuminate the pdp modual.(screen)
To fix this alot of troubleshooting is required because of the various things that can cause this.
Knowing plasma's pretty well , i am prone to blame this on heat. The lack of engineering prowess has flooded the market with disposable junk without any cooling whatsoever..i can heat a room with my plasma.
So lets see here.. power board could have blown a fuse, a peko hardwired fuse but this will cut all power to the rest of the set. Do you get sound? do you get a series of blinks from the tv's front panel? if so count them..its a error code... if you dont even get power lights..you pwb ( power supply) is dead.. either the secondary side or primary of the board..it has 2 phases to it. primare and secondary.
if the tv doesnt even fire and its completely dead...pwb.
need to know what functions the tv can do right now.
Dec 14, 2009 | Sanyo DP50747 50 in. Plasma TV
TV won't turn onthe red light just blinks when I push the power button.
I think this might be bad/swollen capacitors, or something odd in the +5VDC circuits of the power supply, but I am posting all of the things I have found so far with these TVs.
Here are few possible solutions:
If you have no red light and you have a Megmeet MLT386 power supply, check these parts:
1) Swollen caps on the secondary circuit (may cause the red light blink problem).
2) Blown fuse F1 (5A/250V) this is caused by a shorted FET at QA1 (20N60), you may also find that SMT cap CX23 is burned up (.001uf) which is in parallel with diode DA2 which may be damaged/shorted, replace these components.
If the power LED goes from red to green when powered up but no picture, then it might be lost +24VDC from the power supply:
3)Check fuse F2 (3.15A/250V, I put a 5A in), if it is blown, replace FET at QA2A (9N50C), replace QA2 as well (9N50C). Check SMT resistors at R233,R234,R235,R236 (.47 ohm). If open, replace with .1 ohm 1W or 2W resistor (easier to source). Also replace SMT transistor QF1 (2X4 or 2N4401 NPN transistor). And replace diodes at DS2 and DS1 (HER207), DS2 was shorted, DS1 was ok but I replaced it anyway.
I dont know as much about the Megmeet MLT169A, but it has similar problems and similar components.
4) I had to replace all of the capacitors in the secondary circuit (there are six in a 3x3 row marked EC9 (1000uf35V),EC10(1000uf35V),EC14(470uf35V) and EC18,EC19,EC20 (all 1000uf35V).
Aug 10, 2009 | Akai LCT3201TD 32 in. LCD Television
BenQ FP767 17" LCD Monitor Problem - Power LED Blinks
Look for small power transistors 2SC5707 near yellow invertor transformers which go to backlight connectors.
But if problem is blinking power LED powersupply capacitors maybe an issue,check visualy and/or replacement.
Also fuse that maybe blown is not glass fuse near mains socket,It is semiconductor black or yellow colour labeled PFxxx near heatsinks of power supply secondary.
Please rate the solution and provide feedback.
Samir
May 25, 2008 | BenQ FP767 17" LCD Monitor
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
406 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
