Question about Dell Inspiron 1000 Notebook
My dell inspiron 1000 powers up for a short time then shuts down. Even when windows starts up it shuts down.How do I fix this problem.
    Scholar:
  • 145 Answers
Hi dabrow72
Sounds like an overheating issue but there are other possible causes. Make sure the fans are free from dust and debris. A can of compressed air usually does the trick but sometimes opening the laptop to manually clear the fans is required. Laptops/computers cut off by default if the cpu becomes too hot. If your fans are not spinning then it's surprising how quickly this happens. A sure sign of it being clogged fans would be having to wait a short period before the power will turn back on. You may well notice a strange noise from the fan as it trys to spin or maybe it won't be turning at all.
Does this help?
Posted on May 08, 2010
My Dell Inspiron 1720 works with the battery, but shuts down when the ac is plugged in. Is there a simple fix?
Will the Notebook work with the ac plugged in and the battery out. Most of the time it will be a faulty charger or even the port the charger plugs into. The port is soldered to the main board and would be something that a repair shop would need to replace. If you search the www you can find Dell compatible power supplies for Dell at less cost than direct from Dell
Dec 12, 2010 | Dell Inspiron 1720 17" Widescreen...
Randomly shuts down. Dell Inspiron 1000 with battery removed it will usually get past login and stay up for a while all hibernation options have been turned off.
check that it is not heated up Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Aug 31, 2010 | Dell Inspiron 1000 Notebook
Dell Inspiron 531 keeps shutting itself off. After a few moments, tries to restart. and shuts down, almost like it's hibernating, or overheating. New PSU and re-thermal'd the processor/fan
Try removing every single thing in the box you are comfortable with removing - reinstalling.
Take each piece starting with one stick of ram - clean the connectors -[ shiny copper or gold looking area] with a clean pencil eraser.
Install each one - one at a time.
First one stick of ram.
Then another - then a removed card - one at a time.
If this problem continues after reinstalling only the first stick of ram - you may have to re-seat the processor - jell- fan. It takes some doing sometimes to hunt this down - so do not eliminate the power supply either - think about removing it and trying another if all of the above fails to fix the problem.
One last thing - if you have Windows 7 and didn't buy it retail - Windows 7 is shutting down because it is not a legit copy.
Best of it
Gary
May 04, 2010 | Dell Inspiron 531s Desktop Computer
Dell Inspiron 1420 blackened screen when turning on problem
Go back into Safe Mode, and try to run a system restore to a date where this issue did not exist.
Jan 10, 2010 | Dell Inspiron 1420 Notebook
When i push the power button, inspiron 1525, it turns
try this.... go to start | run | control
go to power options
on the advanced tab there will be a option called
"when i press the power button on my computer"
select the "shutdown" option
click apply and ok
then try shutdown your machine using the power button
Dec 22, 2009 | Dell Inspiron 1525 Notebook
When I close my Dell Inspiron 1545 laptop, it always shuts down, even when I set it to sleep mode. This causes Windows to shut down incorrectly among other problems.
Check your computer bios settings. There is a power managment section. Turn off power managment or set it to os controled. Check dells support site for any acpi drivers that you may need. These are needed for suspending controls.
Hope this helps.
Aug 30, 2009 | Dell Inspiron 1545 Notebook
Dell Inspiron 530 randomly shuts down and restarts
Sounds like it could be a virus. Or, a heat buildup problem - are all fans inside machine working? Is the fan inside the power supply operating? Was there any work done inside the computer recently?
If the hdw is all ok, go out and buy yourself a copy of Norton Internet Security 2009 - 1 user lic - $49.99 @ Staples. Do *not* buy any earlier vers. of this software! Install, update it, run computer computer scan - probably will find/remove some/many viruses.
If this helps, please take the time to rate my response to you.
Thanks and good luck.
gurutim
Mar 22, 2009 | Dell Inspiron 530 Desktop Computer
Dell Inspirion 1000 power short circuit
Good Evening:
Hope that you are wellJ
  • There appears to be a shortage in one of your lines to you computer. But, before you replace anything, try these methods.
  • Shut down the computer.
  • Remove any CDs, DVDs or external storage devices (like USB keys or external hard drives) from the computer, if any are present, then press the power button to turn the computer on.
  • Press and hold the <F8> key as your computer starts. You need to press <F8> before the Windows logo appears.
  • If the Windows logo appears, and the system still fails to boot to Windows, shut down the computer and try again.
  • From the Advanced Boot Options menu, use the arrow keys to highlight Repair Your Computer, then press <ENTER>.
  • Click to select your language, and then click NEXT.
  • Log in as a user with administrative rights, and click OK.
  • From the Choose a recovery tool menu, click Startup Repair .
  • Once completed, click FINISH.
  • Click RESTART.
If I can be of further assistance, please let me know
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful weekend.
Oct 03, 2008 | Dell Inspiron 1000 Notebook
Dell laptop mo.1000 inspriron
There could be several things that could cause this actually.
1. the power supply could be bad and is not giving the correct voltage to the system board and thus it shuts off.
2. The voltage on the system board is overloading the Computers Processor so it shuts down
3. The Processor has or is going bad.
If you have another power supply or can borrow one, that would be the first thing I would try. If that doesn't fix the issue, you will need to have it serviced by a professional who can trouble shoot the problem with the proper equipment.
Apr 13, 2008 | Dell Inspiron 1000 Notebook
Dell Inspiron 1000 Notebook Logo
261 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
