Question about Maytag Bravos 3.8 Cu. Ft. Washer
Water level in washer
I have a new bravos washing machine with a clear lid and when I look inside the water does not cover the clothes. Is the normal?
  • Maytag Master
  • 8,220 Answers
The basket floats. The washer relies on a circulation pump to wash the clothes. THEORY OF OPERATION PAGE 22
let me know
Posted on May 08, 2010
There is only enough water to cover the clothes in the washer on the wash cycle, is this normal
Hi Judy, This is quite normal for modern machines. It's an eco friendly thing.
Jul 12, 2015 | Washing Machines
How do i fix the Ld code on a whirlpool cabrio top load washer WTW6200SW2?
Troubleshooting Cabrio, Bravos, & Oasis Washer Problems Cabrio, Bravos, Oasis Washing Machine Overview
Washer Components
Diagnostic Mode & Tests ' Tips & Tricks Error Codes LF ' Ld ' uL ' oL ' Sd ' lid ' Po ' HC ' dL ' dU ' F1 ' F2 ' F30 ' F32 ' F40 ' F41 ' F50 ' F51 'F52 ' F53 ' F54 ' F70 ' F71 ' F72 ' F80 ' F81 ' F82 ' F83 ' F84 ' F85Always disconnect the washing machine's power supply before working on the appliance!Washing Machine Models That ApplyWhirlpool Cabrio Washing Machines
WTW6200SW0, WTW6200SW1, WTW6200SW2, WTW6200SW3, WTW6200VW0, WTW6200VW1, WTW6300SB0, WTW6300SB1, WTW6300SB2, WTW6300SG0, WTW6300SG1, WTW6300SG2, WTW6300SW0, WTW6300SW1, WTW6300SW2, WTW6300WW0, WTW6340WW0, WTW6400SW0, WTW6400SW1, WTW6400SW2, WTW6400SW3, WTW6500WW1, WTW6600SB0, WTW6600SB1, WTW6600SB2, WTW6600SB3, WTW6600SG0, WTW6600SG1, WTW6600SG2, WTW6600SG3, WTW6600SW0, WTW6600SW1, WTW6600SW2, WTW6600SW3, WTW6700TU1, WTW6700TU2, WTW6700TW0, WTW6700TW1, WTW6700TW2, WTW6800WB1, WTW6800WL1, WTW6800WW1 WTW7300XW0, WTW7340XW0, WTW7600XW0, WTW7800XW0
Maytag Bravos Washing Machines
MTW6300TQ0, MTW6300TQ1, MTW6400TQ0, MTW6500TQ0, MTW6600TB0, MTW6600TB1, MTW6600TQ0, MTW6600TQ1, MTW6700TQ0, MTW6700TQ1, MVWB300WQ0, MVWB300WQ1, MVWB400VQ0, MVWB450WQ0, MVWB450WQ1, MVWB700VQ0, MVWB750WB0, MVWB750WB1, MVWB750WL0, MVWB750WL1, MVWB750WQ0, MVWB750WQ1, MVWB750WR0, MVWB750WR1, MVWB800VB0, MVWB800VQ0, MVWB800VU0, MVWB850WB0, MVWB850WB1, MVWB850WL0, MVWB850WL1, MVWB850WQ0, MVWB850WQ1, MVWB850WR0, MVWB850WR1
Kenmore Oasis Washing Machines
110.27092603, 110.27092602, 110.27092601, 110.27092600, 110.27087605, 110.27087604, 110.27087603, 110.27087602, 110.27087601, 110.27087600, 110.27086605, 110.27086604, 110.27086603, 110.27086602, 110.27086601, 110.27082605, 110.27082604, 110.27082603, 110.27082602, 110.27082601, 110.27082600, 110.27072604, 110.27072603, 110.27072602, 110.27072601, 110.27072600, 110.27062604, 110.27062603, 110.27062602, 110.27062601, 110.27062600, 110.27052602, 110.27052600, 110.27042603, 110.27042602, 110.27042601, 110.27042600, 110.27032603, 110.27032602, 110.27032601, 110.27032600
NOTE: For All Error Codes
First press PAUSE/CANCEL once to clear the error code.
If code appears again put it through an automatic diagnostic cycle while you enjoy a nice soothing cup of tea. (Watch The Cabrio, Bravos, Oasis Diagnostics Video) This will reveal any stored error codes. Then you will be able to better use the repair guide to fix the major malfunction. Now put the tea down and get to work!
flood stop water supply hoses that may have closed internally?Is the drain hose sticking too far into your home's drain pipe (siphoning)?
Is the pressure transducer hose kinked, disconnected, or punctured?
Back to Top
Press PAUSE/CANCEL to clear display. pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests "Po" Pump Out (Lid Opened) Po flashes when the lid of the washing machine has been left open for more than 10 minutes. Close the lid to stop the drain pump.
"HC" Hot & Cold Hoses Switched This code will appear at the end of the wash cycle to indicate that the hot and cold-water inlet hoses are reversed.
"dL" Door/Lid Cannot Lock (Stored Error Codes F80, F82, F84, F85) Indicates the lid cannot lock.
Check for items caught in the lid keeping it from closing completely.
Is soap, fabric softener, or anything else keeping the lock from extending into the lid?
The control detects an open lid switch, or cannot determine if the lid is locked. Test the lid lock connection to the washer's control board and lid lock resistance levels.
Press PAUSE/CANCEL once to clear the code. "Ld" Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Jun 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag Bravos MVwX500XW0 Top Load Washer is not spinning
Check the inbalance/lid switch for continuity.Ck speed selector switch (if any)the water level and water temperture switches for proper opreation.NOTE:If any of the selector switches on the console are only poartially pushed in,it may cause improper function.I do not know how old your washer is.TEST LID SWITCH FIRST.If above does not solve,ck timer circuits for continuity.Get ready for this:there is to much to ck with out been there.is motor buzzing,test capacitor,washer spins but does not agitate,ck the agitator splines if they are not rhe problerm,the transmission might be the problem.GOOD LUCK.FYI I own Whirlpool washer and dryer and I repair my own,I prefer KENMORE/WHIRLPOOL/ROPER PRODUCTS because they are easy to repair and parts are not as high priced.
Sep 15, 2012 | Maytag Bravos X MVWX500X 4.3 cu. ft....
The plastic lid lock from my bravos washer broke off any thing i can do to fix it so i can wash cloths?
You may be able to use super glue to reattach the pin that broke off otherwise go to a parts dealer and purchase a new lid pin.
Jul 31, 2011 | Maytag Bravos MTW6600T Top Load Washer
Not enough water stays in machine to cover clothes We know this is an econosaver but wife likes to saok whites in total water Tried adding water by the bucket while washer is stopped but it automatically...
Hello, Thank You for using FixYa. I will be helping you today.There is no way to change the water level. It washes by spraying the water over the cloths as it moves around.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
Why the fan is not working , the fan not move
1.Check to see if the washer is overloaded. Modern washing machines have automatic shut-off devices for out-of-balance loads. Try removing some of the clothes out of the washer and restart it. Check to make sure the lid closes properly and that the lid switch clicks when the lid is closed. If the lid switch does not click, then the switch may need to be replaced or the lid may be bent. If the washing machine still does not spin, go to Step 2. Make sure the water is draining properly. If the water does not drain out, then it could cause the washing machine not to spin. Check all the drain hoses for any clogs or kinks. This is easily done by disconnecting the drain hoses and doing a visual check for clogs or kinks
3.Check to see if any belts have came off or are loose. Unplug the washer and pull it away from the wall. Use the screwdrivers to remove the back panel. Visually check for any broken or loose belts. Replace any loose or broken belts.
4. While the back panel is off, visually check for any loose or missing bolts on the motor or drum. If any are missing or loose, tighten them and replace the ones that are missing.
5. If everything has checked out to this point, then the water level switch could be bad or the water level hose could be clogged. Remove the front panel of the washer and locate the clear tube going from the tub to the water level switch. If lint or debris has gotten into the water level hose, then the washer may not spin fast. Clean the debris from the hose by blowing on the hose or tapping it on the side. To check the water level switch, go to the back of the washer and locate the back end of the water level hose. Use the voltmeter to check to see if the water level switch is getting any power.
6.If the washing machine still doesn't spin fast enough or doesn't spin at all, then it is time to call in a professional washing machine repairman.
  • 1
    Checkto see if the washer is overloaded. Modern washing machines haveautomatic shut-off devices for out-of-balance loads. Try removing someof the clothes out of the washer and restart it. Check to make sure thelid closes properly and that the lid switch clicks when the lid isclosed. If the lid switch does not click, then the switch may need tobe replaced or the lid may be bent. If the washing machine still doesnot spin, go to Step 2.
  • 2
    Makesure the water is draining properly. If the water does not drain out,then it could cause the washing machine not to spin. Check all thedrain hoses for any clogs or kinks. This is easily done bydisconnecting the drain hoses and doing a visual check for clogs orkinks
  • 3
    Checkto see if any belts have came off or are loose. Unplug the washer andpull it away from the wall. Use the screwdrivers to remove the backpanel. Visually check for any broken or loose belts. Replace any looseor broken belts.
  • 4
    Whilethe back panel is off, visually check for any loose or missing bolts onthe motor or drum. If any are missing or loose, tighten them andreplace the ones that are missing.
  • 5
    Ifeverything has checked out to this point, then the water level switchcould be bad or the water level hose could be clogged. Remove the frontpanel of the washer and locate the clear tube going from the tub to thewater level switch. If lint or debris has gotten into the water levelhose, then the washer may not spin fast. Clean the debris from the hoseby blowing on the hose or tapping it on the side. To check the waterlevel switch, go to the back of the washer and locate the back end ofthe water level hose. Use the voltmeter to check to see if the waterlevel switch is getting any power.
  • 6
    Ifthe washing machine still doesn't spin fast enough or doesn't spin atall, then it is time to call in a professional washing machinerepairman.
  • Read more: How to Repair a Washing Machine That is Not Spinning Fast Enough ' eHow.com http://www.ehow.com/how_5025687_repair-not-spinning-fast-enough.html#ixzz1CKKbvlyA
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
    Jan 28, 2011 | Magic Chef CAV2000 Top Load Washer
    Clothes stuck inbetween basket on Maytag Bravos washer
    This is for several brands ... not just the Bravos.
    Based on your description, it looked like you needed to take the center agitator out first .... to then access the inner basket bolts ... remove the inner basket to then get to where the clothes are ... not a real easy task
    capture-ce5c5tqeeiqfekdpzmvievq3-1-0_0.png Good luck on your troubleshooting
    Jan 25, 2018 | Maytag Bravos 3.8 Cu. Ft. Washer
    I have Model WF-S6607?WF-S6607TC. Washing Machine. Loaded the clothes, pressed the POWER button, pressed the WATER LEVEL button, pressed the PROCESS button, and pressed the START/PAUSE button, But few...
    This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
    If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
    Apr 04, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
    Washer fills with water but wont continue washing cycle
    Your lid switch is bad or loose.. open and close your lid and see if you can hear clicking noises.. if not.. then your lid switch is broken.. good luck
    Jan 21, 2009 | Washing Machines
    Kenmore Elite HE3 washer
    set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
    Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
    Maytag Bravos 3.8 Cu. Ft. Washer Logo
    359 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
