Screen very dim ..how do i turn up the contrast /brightness
    President:
  • 3,278 Answers
Hello !
Test with an external monitor. If it works, there is a problem with the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
Posted on May 08, 2010
Construction master pro screen is dim / contrast is low
It uses batteries. So if contrast is dim, it may be time to replace the batteries.
Jan 30, 2014 | Calculated Industries 4065 Construction...
Hitachi 50V710 The picture is dim, then the bulb went out. I replaced the bulb. all works but the picture is still dim. You can barely see the screen durring the day. And can only use it in a dark room...
I've seen this in two scenarios.
First: The housing of the bulb is dirty (the lens the bulb lights onto) and the internal screen is dirty also.
The second: The bulb is wired reversely of the proper way to wire it. This will light the bulb, but will not light as bright as when it is wired correctly!
Thank you and please rate!
Apr 08, 2011 | Hitachi Televison & Video
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
My Garmin nuvi 1300 brightness problems
I spoke to Garmin Support about this issue. There are 2 settings for contrast on the nuvi 1300. You need to set the contrast while it is plugged into the vehicle, and also while it is unplugged from the vehicle. The reason for the 2 settings is to save the charge of the battery while it is not plugged into the vehicle or power source.
Sep 14, 2009 | Garmin nuvi 1300 Car GPS Receiver
Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Apr 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Cannon NP 6551 (Danka A50) Touch Screen Lost Brightness
SOMEONE TURNED THE CONTRAST BUTTON ON YOUR DISPLAY, YOU JUST NEED TO READJUST BY PRESSING AND TURNING TO DESIRED CONTRAST
Apr 03, 2009 | Canon NP 6551 Black and White Copier
The screen comes on fine but then dims????
Hi there, I have the same monitor, but mine has a broken screen. It's probably the inverter chip, that makes your contrast bright.
Jan 03, 2009 | Westinghouse L2410NM 24 in. LCD TV
Acer Aspire 5610 Laptop - dim screem
Holding Fn key down and press up arrow toturn up the brightness.
Nov 07, 2008 | Acer Aspire 5610-4648 Notebook
Compaq Presario R3000 dimmed LCD screen
If your inverter is good I,de say your backlight is going bad, I just replaced mine in a sony vaio and now it seams to bright.
Oct 20, 2008 | Compaq Presario Notebook
Dark screen
If you are unable to change the contrast with the 'fn' key and the brightness controls, usually represented in the top row of keys as a sun icons, one brightens, one dims. You may have a bad brightness/contrast inverter in your display. It's a small circuit board in the display that controls the brightness. They do fail. You can find them for most models but depending on your technical ability, they can be a little tricky to change.
Jul 26, 2008 | Compaq Presario V4000 Notebook
Computers & Internet Logo
377 people viewed this question
David Payne
David Payne
