May I get the make and model # of the item to help you more.
Ok please give me a moment to get you the info.
Try this.. Press select and then choose delete code then enter 7444, now you should be able to enter a new one.
You do not need the remote to do this.
Ok the only other way to reset it is to open the unit up and pull the bios battery for 30 mins to erase the memory.
Press yes when it asks first, then press select, enter 7444 and it will ask you for a new code. If you want to get rid of it completly after doing that go to settings then security, change the level to OFF.
There, no more code.
Sense I told you to reset the bios can you please rerate me.
Also thank you for letting someone else get my pay for helping you
sony ps2 model #SCPH7700 serial #AU2524281 ALSO DO NOT HAVE REMOTE CAN IT BE DONE WITH CONTROLER?
I ALREADY TRIED THAT SEVERAL TIMES, DID NOT WORK!
I HAVE A PS2 model #SCPH-77001 SONY.I do not remember the password for th parental control. I have tried several times going to settings entering 7744 7444 0000 it wont unlock or change passcode, is there anyway tooverride it or change it?
YES!!!! thank you it worked! removing the bios did it thank you soooooo much!!!
