Question about Nintendo Wii Console
I lost the main remote and can't get any of the others to sync
  • 32 Answers
You should buy another 2 remote from http://www.gamestop.com or at the store game stop located in chicago south holland and more
Posted on May 08, 2010
My samsung tv remote is flashing "cable" and cannot access sources
It sounds like it has lost sync with your cable box. Call your provider for a new remote.
Sep 27, 2017 | Samsung Televison & Video
Sync wii controller tmart
t is possible that your Wii remote has "lost" its sync. You can clear all previous synced Wii remotes with your console and reconnect the ones you are using. Power off the console and unplug the power cord for a few seconds. Plug the power cord back in and turn the Wii back on. At the "Health and Safety" screen, open the small door on the faceplate of the console. Hold the red sync button for at least 15 seconds. All previous syncs have been removed from your console at this point. This process does not need to be repeated to re-sync each remote. Take the first Wii remote you wish to sync and remove the door to the battery compartment. Press and release the red sync button near the batteries. Quickly press and release the red sync button on the console. The lights on the remote will flash and then illuminate the light that corresponds to that remote's position (1, 2, 3, or 4). Repeat this process for each Wii remote in any desired order.
fix it. God bless you
Apr 05, 2013 | Tmart Nunchuk Game Controller for Nintendo...
Want to reset my garage remote control to sync with garage base
Garage doors will either have a manual sync. On the side of the main unit where the lights are you may see a bunch of toggle switches. These are the manual switches to configure your doors "code" Otherwise the door will be digital sync. In this type you will usually press and release the sync button on the garage door unit then press and release the sync button on the remote.
Dec 18, 2012 | Televison & Video
I have a 433MHz cable free indoor/outdoor thermometer. It has worked perfectly for years. Just changed the batteries in the main unit and the remote. The main unit will not pick up the outside temp. I...
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Sep 17, 2011 | Oregon Scientific Wireless IndoorOutdoor...
I lost the main remote how can i set my other remote to start game
click on the red button on the bottom of the remote under the battery cover then click on the red button beside the sd card slot on the front of the console. then they should sync up and be ready to go. you may have to turn the console off and back on if this does not work the first time then try again.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 30, 2011 | Nintendo Wii Console
Programming a remote
    Programming a Living Solutions Universal Remote
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  2. Step 2 Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  3. Step 3 Push the power button on the remote. This should turn on the device that you are syncing.
  4. Step 4 Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  5. Step 5 Press "OK" or "Enter" on the remote once the synced device turns off.
  6. Step 6 Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
Sep 01, 2009 | Televison & Video
Lost manual for rca remote transmitter.
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
May 26, 2009 | RCA Universal Remote Control
Lost wii remote and need to know howtogetotherwiiremotestowork
When the Wii is on, you should be able to go into the menu to reset the remotes. Otherwise when you power them on press the home button and it should give you the option of resetting them as well.
Mar 28, 2009 | Nintendo Wii Console
Universal remote
The MX-500 has a learning mode that you can use. Press MAIN and ENT together for 3 seconds, then press the P-PRO button. Select the device then button you wish to program on your remote and then with both remotes facing each other (IR ports must be able to communicate) press the button on your other remote.
You can also download a copy of the book here...
http://www.universalremote.com/resources/pdfs/MX500manual.pdf
Jan 13, 2009 | Universal Remote Control MX-500 LCD Remote...
Make Wii remote#2 remote#1!
You need to sync it . . . under the flap on the console where you insert memory cards, there is a red sync button, press that on the console, then on the remote, under the battery cover, there is also a red sync button, press that just after you done it on the console and it should sync.
Dec 27, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
53 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
