Question about Ricoh Aficio 450 Copier
Enhanced image My copies are coming out too dark - I tried to turn off the "enhanced image" button w/user tools, but was unsuccessful. The toner is actually rubbing off the paper.
  • BIntl Mar 31, 2008
    Thank you
  • 87 Answers
You have a problem in the fuser. Most likely the fuser roller is bad.
Posted on Mar 28, 2008
SOURCE:
I have a Xerox XC820. I am getting dark copies with residual images from previous copies. Toner appears to be adhering to the drum cartridge. Do I need a new drum cartridge?
I have a Xerox xc820. The drum kit needed to be replaced, which I did as well as put in a new toner cartridge. The pages are now coming out very dark. Prior to putting in the new drum kit and new toner cartridge, the machine ran fine. I have tried all I know how to do and to no avail. Have cleaned the "wire", all the parts I can get to and cleaned the plate. Any help would be appreciated.
Apr 21, 2012 | Xerox Office Equipment & Supplies
Its me again,after the user changed a new toner cartridge after few copies there is a dark back ground in copy.before replacing the toner the copy was perfect pls help me in this problem
Hi, After a few copies, the toner supply unit pulls more toner, which results in dark copies. To fix this, you have to reduce the contrast (to minimum). Also, make sure that there is no excess toner within the toner supply unit.
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
Sep 27, 2011 | Panasonic Workio DP-4530 Copier
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Jul 25, 2010 | Canon imageRUNNER 2870 Copier
CAN'T GET SET UP
reinstall cd and follow what it sees and try turning off modem for 10 sec and turning back on
May 20, 2009 | Computers & Internet
On the konica 2223 when printing it leaves a dark thick line down the center of the paper.
Konica 2223 copiers are analog meaning the image that comes out on copies is a direct reflection off of the copy. Dirty mirrors in the optic section can cause a dark band, but it is more of a shading effect. Drum assembly's can be removed.The image drum has a cleaning section that uses a urethane blade to clean excess toner off of the drum after the copy passes through.It is simply called a "Cleaning Blade" these blades can be ordered through most online copier part stores. Last but not least is the "Upper Fuser Roller". this is the hot roller the paper passes through to "set" the toner to the paper. These are coated with teflon to prevent toner from sticking to them. They have "seperator claws" that keep the paper from adhereing to the roller, and they sometimes gouge the teflon. this exposes bare metal, and the toner can come off of the copies and stick to the roller.
Jan 16, 2009 | Office Equipment & Supplies
Cartridge dumping toner? dark copies.
Check the drum- if there is any lines or ghost images replace it if not its problem with fixing unit.
Be sure that you cleaned your copy glass.
Pls. send the model of your machine.The G3 is fax protocol
Nov 25, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
New scx-4521-FG/ too much fad
The darkest copy setting is obtained when the contrast is set to dark and the toner save is turned off. If the originals being copied are too light, this unit has trouble seeing the image and the copies are extremely light as well. If the originals are good and dark, try using original toner cartridges.
Be blessed.
Oct 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Interrupt
Hello Pali. May you stay healthy and happy forever! ;-] I am glad that your question is more of a curiosity than a dilemma. But I would ask the same question.I reviewed the OP manual using "interrupt" as a key word. There were 8 hits and none of the addressed this oddity. I can merely speculate the interrupt function may have been programmed to anticipate that whomever thought they needed to "interrupt" {read BOSS LOL} may need there "special and extremely URGENT copy " be treated in a manner that requires "enhanced image" priority.The service manual does not even address this, if I recall from training ,enhanced image causes the reader(scanner) to reproduce the document @ 600 dpi instead of 400 dpi. This might cause the device to slow down slightly, but HEY, if the "BIG GUY" needs his special emergency copy then WTF!! Now of course you could enter "USER TOOLS" and change the settings for interrupt . That is of course in the op manual. I am sorry I could not "nail" your question down as well as we would have liked, but I truly mean to help. Please be kind if you decide to vote on my response to your question. May the copier be the least of your problems and may the "BIG GUY" (lol) stay out of you stuff . Take care.........SPINAL
Jan 27, 2008 | Ricoh Aficio 450 Copier
New dvd movie will not play
I rented Rush Hour 3 from blockbuster along with Woodcock and both did not play on my Sylvania DVD player. I did take them and put them on my computer and their was a page that came up INTERACTUAL
ENHANCED FEATURES
This DVD is enhanced with interactive features designed exclusively for use on a computer.
PLAY DVD with enhanced features (that prompted a download)
or PLAY DVD without enhanced features and you can play the DVD movie on your small home computer screen.
I believe that the DVD producers have added the ENHANCED FEATURES to be used on a computer and in so doing they do not work at least not on the Sylvania DVD players.
Jan 18, 2008 | Sylvania DVC850C DVD Player/VCR
Ricoh Aficio 450 Copier Logo
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
