http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=1811&modelDesc=DRYER&modelNumber=NVLR333ET0WB&documentID=E2136683&documentTypeID=PLDM&documentClassCode=PV&titleType=DRUM%2C%20BLOWER%20%26%20DRIVE%20ASSEMBLY&titleID=00004&
This is a diagram of your particuliar unit. These Hotpoints are manufactured by GE. The heating element is right behind the drum itself. First is to unplug the unit. Open the door, and look at the top edge of the top of the door. You will see two screws that hold the top down. Remove these screws, then lift the top off. You will have to reach your hand under the drum (and really reach around) and unhook the belt from the idler pully and motor pully. The drum is now free to pull out, directly forward. Your heating elements are now right in front of you. Be sure you check both for drooping, touching each other or the sides, broken wires, etc. Also, these elements are very, VERY expensive. They make a rewire kit that will save you a TON of money. Instructions are included with the kit, Be sure when you put the drum back in, you grease the rear bearing slide and plug.
Heater Assembly (whole unit) Part Number WE11X103 $90.00
Restring Kit: WE11X203 Part Number $35.00
Also, both of these parts are usually found on E-Bay in groves. Do yourself a favor, do not buy them from Sears, they have too high a mark-up, shipping is also way to high, and takes forever to get there. Let me know if you need further help. Thanks and good luck!!!!
