Question about Sony Ericsson W760i Cellular Phone
The phone is "dying"
The "end call" and left buttons only work when the phone is closed. I have a green dot in the battery compartment of my phone. What does that mean? It also turns itself on and off randomly.
  • 343 Answers
Try to open and clean the cell phone look on youtube how to do it
Posted on May 08, 2010
Batery removal
Under the hood just unattache the battery cables if not under the hood look in your trunk
Dec 23, 2012 | 1997 Chrysler Sebring
I put new batteries in my camera-but doesnt do anything. I left camera on,I think and then thought batteries died so then replaced with new ones.now nothing works.
This happened to me as well. I took the batteries out and put new ones in three times (same batteries). The third time the camera started working again as soon as I closed the battery compartment and tried on "on" button.
Mar 20, 2011 | Kodak EasyShare C533 Digital Camera
My Dell Laptop syas that my battery is charged. But when I remove the ac power cord the computer immediately shuts down.
I repair laptops professionally and work on many Dells. Here are the possibilities.
1. The plugin connection where the battery meets the charging contacts in its bay where it seats are malfucntioning and the software is reading it incorrectly. To see if this is so, push the small round black button on the battery next to the 5 little dots at one end. If none of those dots light up green, the battery has no charge and the connection I spoke of above is damaged or malfunctioning beyond where you can see. If all the dots light up green, the battery is likely fine but the laptop can;t connect to its charge at the plugin.
2. The basic software (BIOS) is reading the charger/adapter incorrectly and although saying it is charging or charged, the actual charger is ruined inside in the compartment for charging the battery. Dell chargers can actually be incapable of charging the battery but still run the computer on direct current while plugged in.
3. The battery is no longer able to be charged, but is giving a false reading.
4. The DC Power Jack (into which you plug the charger) is only partially damaged and while able to power the laptop directky, cannot charge the battery. (Check to see if it is loose and woobly when you plug in the charger.
The easiest and least expensive way to troubleshoot and fix this yourself is to start with the charger. They can be had on eBay for about $20. Keep in mind that if no green lights show up on the battery, it might be your first choice and it's about the same price.
I hope I've given you enough info the help you determine your true problem.
Regards,
The Selkie
Aug 29, 2010 | Dell Inspiron 6000 Notebook
Unable to use scope because I lost the manual. Don't know how to install the batteries.
There should be a battery compartment on the left side, it holds one of those flat 2032 or other nickle size batteries. I think the battery scope is the one with the red and green dots in it. Hope this helps.
Mar 30, 2010 | Centerpoint Technologies CenterPoint...
My Nikon N2000 works great but it has one problem , on one side of the battery compartment the two aaa dies very quickly but not the other two aaa batterys
You may have some corrosion under the battery compartment causing a short that drains the batteries. You can safely remove the battery compartment with a small cross point screwdriver. Remove the batteries, there should be 5 screws, The only concern is that some models had wires soldered at the contact end, but most had only spring contacts. Check the backside and end of the compartment for a white or green build up.
Jan 25, 2010 | Nikon N2000 35mm SLR Camera
Phillips CD445 cordless phone - cuts out when pick up to answer
if you have had it a while chances r the batterys have had it even though they show full, try a new set, or even try standard batterys briefly while fone is not in charging mode to see if they work during a call.
Jul 30, 2017 | Philips CD4450 1-Line Cordless Expansion...
I put in a new battery thinking that might be the problem, after installing new one, it did not work, while fiddling with it the dot came on for a second then off and nothing I did could get it back on,...
take out the battery or batteries.
turn the scope on to full power.
place the battery or batteries in the scope.
just start the battery compartment cover onto the threads.
watch through scope as you slowly tighten cover.
If the dot lights up stop turning cover or experiment with continuing to thread on cover.
Apr 13, 2009 | Tasco ProPoint Red Dot Matte Red/Green Dot...
How do i replace internal battery on the minolta maxxum 7000? i replaced the AAA batteries, but it still just flashes ''film'' in window.I have no manual and dont know how to get the film out.HELP!
Unscrew battery compartment on the right grip, and remove the battery holder (AAA's in most Maxxum 7000's) In the compartment you should see a silver colored metal plate, held on by 6 small phillips screws. Unscrew these, and carefully lift the plate, and move it aside (there's a tiny wire soldered inside the plate, so don't break it off).
Inside there should be a CR2016 lithium button battery. Replace it, and reassemble in reverse order.
NOTE: This probably won't fix any issues regarding the removal of the film, as the 2016 is just a memory backup battery for when the main batteries are removed.
to remove the film, install fresh main batteries, turn on the camera via the "Lock" switch and rewind the film. on the back of the camera, just behind the LCD screen, above the film door, you will see a grey button marked "R". Push and hold it, while sliding the gray slide switch immediately to the left of it to the left. The film should now rewind.
When the film is done rewinding, open the back via the sliding latch on the left side of the body with the gray button in the middle. Push the button, while sliding the latch down.
To insert film, place the cartridge in the same place and orientation as the old roll, and pull the leader over to the red dot on the bottom right of the film compartment, and close the back. it should advance to the first frame if done correctly, or blink 0 if done wrong.
If you need anymore assistance, contact me via email cwrrailfan at yahoo dot com
Have Fun with your 7000!
Mar 11, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Wont turn off
First, take the battery out and put it back in to reset it. Then try again to see if you can manually turn it off.
This resets the phone and is the first step in troubleshooting.
Another thing I would do, is test to see if there is something wrong with the end button itself. With a flip phone, normally the end button is unneeded because you close it to hang up. Try ending a call using that button to see if it is a broken keypad issue.
I would also have the local store update the firmware, which should repair any files that may be corrupted, if that is the case.
Also, if the phone has any water damage (when you open the back of the phone, there will be a red dot instead of a white one), this can cause all sorts of crazy problems.
If none of the above solutions work, the only other way to power your phone off is just to remove the battery. You should be able to put the battery back in without the phone restarting, but if it does, just keep the battery out when you want the phone off.
Jan 21, 2008 | Motorola Mobility RAZR V3
Sony Ericsson W760i Cellular Phone Logo
110 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
