Question about Brother SE-270D Computerized Sewing Machine
My machine went into safe mode after sewing heavy fabric. I have cleaned it according to book directions, but the upper thread and lower bobbin are still messed up. Do I need a new needle plate to fix this? Replaced needle and made sure tension is adjusted correctly before my last attempt to sew. Please help. Kim
    Genius:
  • 1,116 Answers
The timing needs to be adjusted and this is best done by a sewing machine repair person.
You can get directions at the website for sewusa under repairs.
Posted on May 08, 2010
I sewed a support seam on neck line. got the bumpy stitches from bobbin. rewound bobbin, threaded machine. went to sew and now nothing works. it wont sew.
Not quite sure since the symptoms are not clear. "Bumpy stitches from bobbin"--does that mean there were thread nests on the bobbin side of the fabric? That is thread nesting or bird nesting resulting usually from mis-threading, upper thread not completely seated in tension disk, or upper tension too loose. Remove the upper thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning--verify the thread path is correct. Set the upper tension to the midway point between high & low number and retest the machine. (Upper tension may need to be tweaked because fabric, thread, and age of the machine will have an affect.)
Check that the bobbin is wound smoothly--no lumps, bumps, or thread ends/pieces sticking out of the bobbin. Check that the bobbin is installed in the bobbin case correctly (turning the proper direction) and the bobbin tension is threaded completely.
If the upper thread is not picking up the bobbin thread, make sure to install a brand new needle. If it still won't pick up the bobbin thread, then the machine's timing has probably been knocked out of alignment. Search for sewing machine timing or take it for service.
Jan 14, 2017 | Sewing Machines
Try sewing but bottom thread on fabric is crumpING UP
needle thread tension is not adjusted up properly tighten the setting until you have resistance when you pull the thread to thread the needle
Oct 02, 2016 | Sewing Machines
How to clean and oil machine
Depends on the make/model of your machine. Different machines require different care. It is important to clean and oil frequently as directed in the owner's manual. Be sure to use the correct oil--no 3-in-1, WD-40, cooking oil, or old and stinky sewing machine oil. (If it is brown, throw it out!!!) Also, one or two drops each spot is sufficient--do not over-oil!
Problems with tension? Install a brand new needle.
Remove the upper thread completely from the machine. Raise the presser foot and rethread from the beginning. Confirm that the thread path is correct.
Set the upper tension to the midway point between high & low numbers (this is a good beginning point, but may need some tweaking, especially when dealing with different threads and fabrics).
Confirm the bobbin is loaded in the bobbin case correctly and threaded properly.
Test your machine. If the upper thread is showing under the fabric, the upper tension is too loose. If the bobbin thread is pulling to the top of the fabric, the upper tension is too tight.
Tension is correct when the upper and bobbin threads meet in the middle of the fabric.
May 16, 2016 | Sewing Machines
How do I adjust the tension for straight sewing?
First, be sure you are using a brand-new needle and that the needle, thread, and fabric are compatible.
All About Needles
When you thread the upper thread, be sure the presser foot is ALWAYS RAISED so the thread will seat properly in the tension disk. Also, confirm that the machine thread pathway is correct.
Remember that when fabric types/weights are changed, the needle/thread should be changed accordingly. (Needles should be changed often to attain the best sewing experience and minimize unnecessary frustration.) The tension may also need to adjusted. Tension is not static. It should be adjusted to fit the project being sewn. Unless one continuously sews with the same fabric, thread, and needle type would the tension adjustment remain at the same setting, but machines do change over time so a tension setting that worked last year may not look the same this year.
The factory standard tension setting is the midway point between the high & low numbers. However, please understand that machines vary and that sometimes this standard setting may change with time and use. The midway point should only be the beginning point and is most likely suitable for medium-weight fabric. Also, usually the bobbin tension does not require frequent adjustments unless a particularly heavy- or light-weight thread is used in the bobbin--sometimes the bobbin tension will get out of whack requiring adjustment (consult the owner's manual or search the internet for instructions for adjusting bobbin tension). In the majority of cases, the tension adjustment is made to the top thread.
Test your straight stitch on your fabric (may be helpful to use a different color thread in the bobbin so it is easier to see any tension issues). If the bobbin thread is popping up to the top of the fabric, loosen the upper thread tension. If the upper thread is looping or showing on the bottom of the fabric, tighten the upper tension. Keep adjusting until the upper and bobbin threads meet in the middle of the fabric.
FWIW, the same process would be used for zig-zag stitching. Just make sure that the tension is not too tight or it will cause the fabric to pucker (or tunnel).
Mar 07, 2016 | Sewing Machines
Why isnt my bobbin thread being caught by the upper thread?
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever?
May 24, 2015 | Sewing Machines
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
Apr 26, 2015 | Singer 4423 Sewing Machine
The upper and lower thread are not locking together in the fabric
The easiest possible option is that the bobbin is not threaded correctly. This happens to my students and 99% of the time the bobbin thread is going the wrong direction, ex: it's flipped to go counter clockwise instead of clockwise.
Apr 14, 2014 | Singer Pixie Plus Sewing Machine
My bobbin thread keeps looping and the top looks fine but pulls out easily. I tried adjusting the top tension, but it didn't help. What can I do?
There could be several things that could cause the machine not to pick up the bobbin thread.
1. The upper thread could be tangled. Remove the thread completely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine according to the directions in the manual.
2. Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
3. You could be holding the needle thread too tight. Hold the thread lightly to keep the end from going down into the shuttle.
4. The needle could be thread incorrectly. Thread the needle eye from the front to the back.
5. The needle could be bent or improperly inserted. Install a new needle with the flat side of the needle facing the back.
If the problem persists, your machine may require service.
The bobbin thread tension has already been adjusted at the factory for general use. For most applications, no adjustment is needed.
When sewing with then thread on thin fabrics, the thread tension may not be adjusted adequately with the upper tension control dial. Therefore, the thread tension must be adjusted according to the procedure described below.
If bobbin tension is too loose and locks appear on the surface of the fabric, decrease the thread tension by turning the dial to a lower number.
If the result is still not satisfactory, then adjust the bobbin thread tension.
Increase the tension in the bobbin by turning the screw with a small screwdriver in a clockwise direction. However, do not turn the screw more than one full turn.
Jun 19, 2011 | Brother XL-5340 Mechanical Sewing Machine
I place the fabric on the machine, lower the foot and apply pressure to the foot peddle, when the machine begins to sew fabric is pulled down and the lower thread tangles, the machine make a crunching...
This is easily solved. Before you start sewing make sure your upper and lower threads are long enough for you to hold before lowering the presser foot. If these threads are too short they both get carried down into the bobbin along with the fabric and cause a big tangled mess. Always hold your threads at the back of your work with your left hand then lower your pressure foot and don't release the threads untill you have taken several stitches. Keep holding these threads during backstitching at the beggining of a seam too. Works like magic.
Dec 21, 2010 | Brother XL-3500
Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Dec 28, 2008 | Baby Lock Ellure
Brother SE-270D Computerized Sewing Machine Logo
211 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
