Question about Pool & Spa
We built a large (55ft long) concrete pool with a 30 foot infinity edge less than 3 years ago. There are 3 Hayward pumps, one for the filter and two for the infinity edge. The filter has been showing too high pressure, up to 60psi (when first turned on it is at 28psi but after 5-6 hours it goes to 40psi). It has burnt up two pumps because we didn't know there was a problem. Instead of continuing to replace motors and have the potential for the filter exploding what do I do to solve and find my blockage. I have just had the brick wall that hides the equipment torn down because I and my pool maintenance company felt that the slowly sinking wall may have been the culprit. All plumbing is exposed and there are no visible leaks, crushed or flatten pipes and the pressure is still there, just today the pump I replaced 3 weeks ago has burnt up. How or who do I go to to help me find and solve this problem. Also, both infinity pumps won't hold a siphon, if turned them off for more than a few hours they both have to be primed again to run, obviously there is an air leak. Hopefully, with some tests a leak detector company can find the problem. The pool company I used won't return phone calls (they may be out of business). I have a fortune tied up in this beautiful pool and don't know who to turn to. Please help! Sincerely, Frank Arey, Charlotte,NC
  • Pete May 11, 2010
    what kind of filter is it?
    Guru:
  • 351 Answers
Hi .. with the pumps loosing prime, yes, there is obviously a leak ,, if the pumps were sicking air into the leaf trap just before the pump , then I would look for the leak in the sucking lines, skimmer, bottom, cleaner. BUT you say it leaks out after shut down ,, could be a seal or gasket at the pump or filter .. or a blockage and pipe separation in a return line. If there is a blockage you may burn out pumps, blow the filter or blow a return line apart. Check the flow at the pool return nozzles, make sure all return valves are full open. Try selectively opening and closing selector valves to see what return line makes the pressure increase the most. IF the presure problem persists I would temporarilly add a 2inch line to the return side of the filter and run it to the pool on the ground, so I could have unrestricted circulation and save the water condition and pumps and be able to troubleshoot the pressure problem .. IF this bypass pipe does not relieve the pressure situation ,, maybe you need to evaluate the size of the pump for the application .. thoughts?
Posted on May 09, 2010
When to replace sand filter medium
This is sort of a two-fold answer, as I am not exactly certain if you are referring to replacing the sand filter media itself or the sand.
Most manufacturers will tell you that the sand filter media itself is a permanent media filter. The only reason to throw the filter away would be after the sand calcifies into a solid block of concrete. The industry has spent 40 years telling the professional industry that sand is forever. Sand media is forever and you never have to change it.
However... this is what Hayward Pools is telling their customers:
On average, sand should be replaced every 3-5 years. The jagged edges of the sand wear down and become smooth as the sand ages. When this happens the sand can no longer trap debris particles and dirt can pass through the sand and back into the pool. As the sand ages, it may start to clump and the water flow can form channels in the sand, allowing the debris to pass through.
I have also talked with several others who believe what Hayward is saying, that basically every 3-5 years it should be changed. We have a strong belief in what Hayward says.
Hope that helps.
Mark
Bath & Spa Parts Online
http://www.bathandspaparts.com
Aug 07, 2016 | Pool & Spa
Old Intex pool and 03f filter system. Where can I get filter covers for inside the pool?
Intex makes 3 main types of cartridge filters. Types A,B, and C. Stores usually have atlest 2 of the 3 and amazon would have all 3. You just need to find out what one you need.
Jul 30, 2015 | Intex Pool & Spa
Wish to upgrade cartridge filter pump to sand filter pump. Pool size 15' X 48" / pump 1000 gph - 637R /Item no 56945 Which intex sand filter is the best one?
First, understand that sand doesn't filter as finely as cartridges, so "upgrade" may be the wrong word. Cartridges filter down to about 10 microns, sand filters to 25-30 microns. (i.e.the cartridge will catch particles up to 3X smaller than sand will.)
If you still want to change, get the biggest sand filter available that you can comfortably afford. For superior results look at above ground pump/filter packages built by Hayward or Pentair. Intex products are just built to margin and are not designed for long term usage.
Aug 31, 2013 | Intex "" Metal Frame Pool Set (56998e)...
My Hayward superpump has a crack in the pump filter basket housing. I cannot afford to replace my pump at this time. Is there a patch or epoxy that will seal the crack? Hopeful!!
I would recommend a product called "Pool Putty". We use it all the time for quick repairs at my pool company. It is a 2-part epoxy that hardens like concrete. It might get you through the rest of the season.
Jun 15, 2011 | Hayward EC-40 DE Pool Filter with pump
We have a Hayward Pro Series sand filter S244T. It was installed 3 years ago. There is no indication of flow through the glass bulb on the back of the valve when the valve is in normal operating...
The sightglass is designed for backwash only, it allows you to see the degree of clarity in the effluent water. There should not be flow through the sightglass when the filter is in normal operation. Sometimes the pump will be alot louder when you backwash because there is alot less back pressure and it sometimes causes pump cavitation. The pump should quiet down when in normal filter mode. If not, there may be problems with the bearings and/or cavitation.
Aug 15, 2010 | Hayward SAND FILTER, PRO SERIES
Every time i vacum it blows back into pool
Check your sand ... when was it new? more than 4 or 5 years ago? Replace the top one foot of the sand. You may have channels dut in the worn out sane, you may have a broken lateral (I doubt it but will not rule it out)
Jul 26, 2010 | Hayward SAND FILTER, PRO SERIES
My pump is 3 years old. I replaced the shaft seal assembly and now the motor is making a strange sound (much quieter than normal) and shutting off every minute or so. There is no pressure on the filter and...
Sounds like the motor is not turning. Check your impeller and motor to see if it spins freely by hand.
If not then you either have something stuck in the pump or the bearings are bad. If it is freely spinning, check your start capacitor
Apr 16, 2010 | Hayward Pool Products HAYWARD 1.5 HP 2...
NOT FILTERING, NO SUCTION, CHANGE SAND,,,SINCE DAY ONE..WRONG HP?
You are correct. Your lines are extremely small for this system and the pump is to small for this system. You are going to have to do a total upgrade. from the pump to all the lines. I know this is bad news, but it is a common problem for system that where put in more then 10 years ago
Jun 01, 2009 | Hayward SAND FILTER, PRO SERIES
Pool & Spa Logo
99 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
