Question about Maytag Washing Machines
I have a maytag neptune front loader coin operated washer. There is no readout on the display board( Nothing ) If I take off the service door an erroe code d-5 appears which according to my manual is a blocked coin mechanism. I checked the unit and it appears O.K. and even changed the optic sensor (wiring harness).Nothing works so far. I can run a test run of a few minuits ny removing the service door and the the whole display lites up if I push delicates. The I can push any other button and a test run will work. After the test run the reverts back to being blank.Model # is MAH21PDDWW
  • 1 more comment
  • bmc2 May 08, 2010
    The motors work fine once I get them to go. The problem is electrical. When I open the service cover ( coin operated ) error code d-5 appears whick is a jammed coin . I pulled the unit and it is clear alsochanged the optic harness that connects to the coin mechanism. I can run a test run for a few min by opening service door and pushing the delicate button and the another on ie.colors etc. but after that the display goes blank again
  • bmc2 May 08, 2010
    That sounds a little more like it may be the problem but the fact still remains that there is no displays on the circuit board. It is supposed to read $2.00 and then flash to $2.50 for a super wash, but the display is blank except if I run a test cycle. If I put coins in the machine they go right to the coin box without registering.
  • bmc2 May 08, 2010
    I'm not sure if your solution is correct or not but it does appear to be the most reasonable,
    Thank You
  • Maytag Master
  • 19,396 Answers
Hi.
The fault is obvoiusly in the control center. The problem is likely a part causing a shor or a contact. This jams the electronic and may be the cause for the blank display.
If you are a tech doing the repair for a customer better to replace the whole control centre, which cost is about $100.
If you are in no hurry you can replace parts bit by bit, starting from door, then optical assembly etc.
Here the parts.
Regards.
Posted on May 08, 2010
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
My maytag neptune washer has black residue on the seal. I have tried everything & nothing seems to take it off. I am now concerned that it is mold. Has anyone experienced this same problem?
Hi just read your posting.The black residue is most likely mould.I have seen it on a few front loaders.Have you tried the product called Mould off ?It helps on some machines.Worse case you might have to replace the door seal.Please reply for further help.Looking forward to your reply.
Jun 24, 2012 | Maytag Neptune MAH6500A Front Load Washer
I have a maytag front loader and the start button does on stay on, therefore door button will not stay on to lock door. I have to hold button in so that washer will start filling up with water but then...
This sounds like a motor control or a main control board problem. If this is a older washer, but less than 10 years old,that hasn't been updated with a new motor and control board assembly, the parts may be covered under the motor warranty. You need to call a qualified service tech to determine if this is the case.
Feb 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Neptune - has Lr displayed where time remaining for wash usually displays. Doesn't finish.
Hello there
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Burn Spot on a Maytag Neptune Washer Motor Control Board (click to enlarge)
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge) Either way, it means just one thang: a new motor and motor control board kit are in your future.
Dec 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
We have a maytag neptune washer and on evey setting, it's telling us d5 - what does it mean?
D5 means blocked coin 1 or coin drop control circuit failure, coin recognition and price display disabled while blockage persists.
Nov 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load washer ??? Is there a filter ???
I was having that problem with smell too and I was told not to completely close the door when the washer is not in use to allow for air flow. When the door is always closed it does not allow for air flow and a mildew smell will develop. I keep mine open when it is not in use now and I do not have that problem anymore.
Apr 19, 2009 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune Washer Door Locked
INSIDE THE SOAP LOADER THERE IS A LIME COLOR STRING PULL IT WILL UNLOCK LATCH
Apr 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
