Question about Whirlpool LSR5132PQ Top Load Washer
Leaking water ... need to take off cover. from underneath
Looking from underneath water appears to be leaking from pump jim.
  • Whirlpool Master
  • 8,220 Answers
Check it out
Posted on May 08, 2010
  • Stephen Potts Jan 22, 2014
    The problem is your water pump. They have a weep hole that leaks to tell you pump is bad. Just like on most cars
My 1994 sierra 1500 is leaking antifreeze right out. IS THIS MY WATER PUMP?
look in engine compartment from underneath- if water coming from directly over crank pulley(big one closest to ground) ,yes its the water pump- could also be lower hose(radiator hose closest to ground),if leaking up top - could be other radiator hose- if leaking near fire wall- heater hose- ?where is the water appearing?
May 18, 2011 | 1994 GMC Sierra
2004 YZ 250 is leaking fluid out of the hole just behind water pump underneath the crankcase. The gasket looks fine and its not leaking from the gasket its actually coming out of the hole. I started...
The hole is a weep hole, designed to drain coolant from water pump seal leakage or oil from bearing seal leakage from contaminating either system. So one of the seals is leaking, and you should rebuild the pump.
Looking at the parts diagram it appears the impeller is threaded onto the shaft on the YZ250....hope that helps, heres the parts diagram
http://www.mrcycles.com/fiche_section_detail.asp?section=50188&category=Motorcycles&make=YAMAHA&year=2004&fveh=1236
Mar 06, 2011 | 2004 Yamaha YZ 250
Hi My karcher k3.65 jubilee is leaking water when the pump is switched off from underneath
Hi This could be just the water inlet channel broken or split. You will need to remove the yellow cover via the screws at the back of the unit and then connect the water hose to see where the leak is coming from. If the water comes from underneath the pump then you will need a replacement pump seal kit of which you can purchase on the Internet.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
Leaking whirlpool washer
Probably the pump seal - you need to replace the pump, which is located at the front.
Apr 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
Power Flo Matrix pump, leaking from underneath?
Replace the pumps mechanical seal with a replacement seal #200. It's less than $10.
Jul 19, 2009 | Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP
Water leak at water pump rear cover
The use of silicon sealer on both the gaket and the threads of the bolts is important Not adding silicon sealer to bolt threads and shank sounds like the likliest cause of your fault unless it only appears to be coming from the bolt hole and in fact leaking from another source.
Dec 25, 2008 | 2002 Cadillac Deville
Whirlpool LSR5132PQ Top Load Washer Logo
674 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
