Question about Rheem 266K to 399K BTU Swimming Pool Natural Gas Heater ()
I have a Rheem Raypack pool heater and cannot locate my manual. The model is pr266a-ep-c. Is there a way to get the manual?
  • 990 Answers
If you run a search for Rheem or RayPak the site should bring you to a menu that will have most manuals.
www.raypak.com/uploads/6000.52AG.pdf
This link may help but I think it goes to an older heater, but it will give you a start.
Posted on May 09, 2010
My rheem pool heater has no power to face display, what can i do?
Posted on Jul 17, 2011
My heater raypack 407A is giving the message lonox tap default
PDF]raypak replacement instructions - Pool Supply Unlimited
https://www.poolsupplyunlimited.com/.../136118_20111116132043.pdf
type of heating equipment and related system components. Installation and .... Low NOx MODELS 207A, 267A, 337A & 407A ONLY: PREPARE ... Locate Low Nox taband P-10 air switch terminal on the board as shown in Fig. ... The latest fault code will be displayed ... Resets board to factory default settings. Resets faults in ...
Nov 08, 2015 | Pool & Spa
Water switch open , heater heats up for short period and cuts out
ensure pump is running at full prime. clean the filter out as well. disconnect both connections from pressure switch in raypack heater. check continuity. if switch opens at any point and you have no flow restrictions then replace the pressure switch
Mar 11, 2014 | Solar Rheem Gas Fired Pool & Spa Heater...
Rheem pool heater
The display can be decieving when the remote function is turned off it will be in all caps like REM OFF but when it is on it will look like REM oFF. In the on mode the "off" is actually reading the heater mode is off (not pool or spa).
Feb 11, 2012 | Rheem Pool & Spa
Blows thermal fuse on raypack heater?
If you are talking about the "Roll out sensor" located on the lower left hand side, you have a problem with ventilation..Soot,debris, or possibly a rodent nest on the heat exchanger (Located just under the top cover of the heater). If it is electrical, you may have a bare wire touching the heaters housing (somewhere inside) causing a short. Rodents love to chew the insulation off low voltage wiring.
Oct 08, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a Rheem raypack pool and spa heater. I have an error message in the display: "ROL". Can you please describe the issue and possible solutions. Thanks, Stan.
Error Code ROL is "HEAT ROLL-OUT SAFETY SWITCH OPEN". The heater is equipped with a cutoff device to prevent flame roll-out in the event the heat exchanger becomes blocked. This is either a "manual reset", or "Single-use" type fusible link/thermal fuse, that must be replaced or reset after any over temperature conditions have been fixed. Excessive restriction in the heat exchanger flue passage may cause the switch to disable the heater. I don't know your exact model so I'm just generalizing. If you reset or replace the switch, and it trips/burns out again, then you need to address what is causing it. make sure the heater is cleaned out well and no debris is blocking the flue. I fthis doesn't help you can always try calling Raypak Service department at (805) 278-5300.
Sep 20, 2010 | Rheem 266K to 399K BTU Swimming Pool...
I just purchased a home that has a Rheem Digital Gas Heater for my pool / spa (Model P-M406A-EN-C) 399k BTU. I cannot find a manual on the Rheem company website. Any idea how I can obtain one?
They have good listings on their web site.
http://www.rheem.com/product.aspx?id=8B064EC5-B708-4821-9F2B-DEF3A2243F90
That link should be to your model. When you click on the link for your manual (installation instructions)l, if it doesn't download. Right click on the link, and select download
So what is the problem?
Aug 12, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
Pool heater
This is an old, but good heater. Power is either stopping thru the safety loop, high limits or pressure switch, or the pilot generator is tiring out and not sending enough power to keep the gas valve open.
May 06, 2010 | Pool & Spa
Raypack RP 2100 The heater doesn't turn on, is there a reset
the electronic heater has an on off switch on the side on older models on the front on newer.the power goes to a transformer this in turn is converted to low power .
Jul 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Rheem 266K to 399K BTU Swimming Pool Natural Gas Heater () Logo
1,172 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Scott Corey-reid
David Spradling
David Spradling
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
