Question about Kenmore 64802 Top Freezer Refrigerator
There is water collecting in the bottom of refrigerator inside. What causes this and how do I fix it?
    President:
  • 949 Answers
This is most likely due to a drain issue. Follow the link below for instructions on how to resolve this.
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
Posted on May 08, 2010
How do fix water inside refrigerator under bottom drawers
It may be your drain hole at the back of the fridge has become blocked.
There will be a channel at the back (or side) of the fridge that collects condensation with a drain hole out of the back of the fridge. The drain hole becomes blocked with mould / gunge causing the excess water to overflow and puddle in the bottom of the fridge.
The hole may be gently cleared with a small diameter rod or stick.
Mar 08, 2015 | Frigidaire Refrigerators
I have a whirlpool designer 20 refrigerator, it is collecting water at the bottom. What is going on? How can I fix it?
In the freezer, under the cooling coil, is a drain pan that collects water after the coil defrosts. The drain opening from this pan is probably plugged with debris. If you can find the drain line under neath the refrigerator and blow through it, this will usually clear it.
Oct 09, 2014 | Whirlpool Refrigerators
Ed25rf
Water collecting in the bottom of the freezer is usually caused form a condensate drain blockage. Remove the back panel and there should be no ice around the drain. if there is pour hot water in and around the drain to clear it and flush it out. This should get things fixed.
Jul 23, 2014 | Whirlpool Refrigerators
Water collecting in bottom of fridge
Good Afternoon Friend,
I understand that you are receiving water at the bottom of your Frigidaire refrigerator, model# FPUI2188LF. What can cause this is either humidity coming from outside your refrigerator or maybe from the crisper drawers. Make sure your crisper drawers are set for a high humidity. Another thing that can cause moisture build-up at the bottom of your appliance is not covering your foods. Make sure that all foods and drinks are covered to cut down on moisture floating around inside your appliance. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Fpui2188lf 21 Cf Top Mount...
FREEZER AT BOTTOM OF REF. COLLECTS ABOUT ONE INCH OF ICE. THAN CANT OPEN BOTTOM DOOR SEEMS TO BE LEAKING DROPLETS OF WATER FROM REF. AT TOP WHAT COULD BE WRONG?
Defrost condensate line behind the rear panel is clogged up. The watter is flooding over the condensate collection tray and and through the cabinet. Click below.
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
Watch the short movie on how to get to the tray behind rear panel in freezer and if you have trouble or questions let e know, Thanks, Sea Breeze
Nov 14, 2009 | Amana ABB1927DE Bottom Freezer...
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Water collects on the bottom of the refrigerator
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 11, 2009 | Refrigerators
Water is collecting in veggie bins in
I can solve your problem for you.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
Water/liquid collects at bottom of refrigerator under vegetable drawers
For water collecting inside of a refrigerator, there is usually something leaking inside, or perhaps the door seal is letting moist air into it.
Jul 08, 2009 | Kenmore Refrigerators
Water leaks under veg bins.. Cannot tell where it is coming from. Accumulates slowly
This refrigerator look like mine (Picture).
Mine did the same thing. If it is the same then this is what I did.
Look under the there is a collection tray.
This tray collect the water.
At the bottom of the refrigerator (Inside where the water collect) is a cap.
The cap has cap would have holes or a slot that allow the little water to fall to the collection tray.
Mine has slots and was block up.
clean it out and that should do it.
The water should be able to fall to the tray at the bottom.
I do hope this help you.
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 64802 Top Freezer Refrigerator Logo
113 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
