Question about Compaq Audio card Sound Card
I m having issues with my computer when I play a video the sound seems to be slowing down nd speeding up and it sounds like they are under water..what seems to be the problem and how do I fix it
Try updating your drivers
Posted on May 13, 2010
Sound does not match image and the sound is muffled
Perhaps, your Internet speed is too slow -- your computer "plays" the video FASTER than it can download it.
Or, your computer is too slow to be able to go into "full-screen" mode and keep updating the whole screen.
Jan 19, 2014 | YouTube Videos
My sound is real funny like chipmunk sounds
If the pitch of the sound being played by your computer speakers has changed dramatically or songs and videos are playing faster or slower than they typically should be, the problem is with the sound speed on your computer. This could mean a hardware issue with your speakers or sound card or a software issue with the program that you're using to play a digital media file.
Double-check your speaker connections. If one of the audio cables that runs off of your speakers isn't plugged correctly into your computer, this could cause the audio coming from them to speed up or slow down. Make sure all cables are properly connected to their proper inputs and try to play your audio again. Update the driver for your computer's sound card. Go to the website of the company that made your sound card and look for your unit's product page. Under the "Support" section, click on the download link for the latest device driver. Once the file is on your computer, double-click on it to install it. Then restart your computer and try to play your audio again. Make sure you haven't accidentally sped up or slowed down the media file you are trying to play. Many digital media programs like iTunes or Windows Media Player have features that allow you to play a song or video in slow or fast motion. If this becomes accidentally selected, the audio will also be in slow or fast motion. Click "Stop" to stop your media file from playing and then click "Play" again to allow it to play normally. Restart your computer. This will free up system memory when your computer restarts. If your sound was playing too slow or too fast due to an error with not having enough memory to play properly, that error will now be fixed and your sound should return to normal speed. Hope this helps.
Dec 28, 2012 | eMachines Computers & Internet
Slow playback after recording.
Quality is definitely a factor here. Set tape speed to SP. Standard Play. It uses the most tape, and use a newer tape if possible.
You can also try converting to a newer format like MP4. This is the new standard for web videos. Older codecs might be an issue.
Sep 30, 2012 | Diamond Multimedia VC500 One Touch VHS...
Slow sound on window xp
Change playback speed in Windows Media Player
Begin playing a file.
Click the arrow below the Now Playing tab, point to Enhancements, and then click Play Speed Settings.
Move the Play Speed slider to the speed at which you want to play the content, or click the Slow, Normal, or Fast link.
To select speeds between the labeled play speeds, in the Enhancements pane, clear the Snap slider to common speeds check box.
To hide the settings, click the Close button in the Enhancements pane.
hope this helps
Jul 30, 2012 | C-Media Electronics Computers & Internet
Canon PowerShot SD1100 IS Digital Camera I used this camera to take movies. When I play it back on the camera and after downloading to my computer, it plays as if it's set for fast forward and there's no...
Check your camera settings in movie mode for the correct settings for time lapse, normal, slow motion and fast motion. A slow recording memory card will not produce your problem but will take longer to save the file. If you shot the movie in PAL and played it on an NTSC TV, the picture would be in black and white with no sound and vice versa. ALWAYS format the memory card in the camera, never on a PC
Mar 11, 2017 | Canon PowerShot SD1100 IS Digital Camera
Playback is too fast using Pinnacle Quick start version 10
This sounds like a Frames per second setting issue.
Just a guess, but you recorded at 15 FPS & the player is regurgitating at 24 (or 30) fps.
Sep 04, 2009 | Pinnacle Dazzle Video Creator Platinum...
Quickplay on laptop plays everything slow motion and no sound, no sound for games most of time.
Are you running xp or Vista?
In XP go to device manager and expand list of IDE ATA ATAPI controllers. Right click on primary IDE controller and select properties. In advanced screen check primary IDE mode - that should be DMA.
IF that is in PIO mode - that is your problem.
Just click on driver tab in the same window and click uninstall.
REstart computer twice and problem should be solved.
Please leave your feedback if issue is solved
May 28, 2009 | Computers & Internet
My sound is all slow and warbled when I play itunes, tv shows, dv
this case generally you may consider:
1) check your ram, clean the ram and slot, or change new ram
2) check your internet speed, cause sound slow if the speed down too much, or there are more than one conputer using your router at the same time
3) virus attact maybe damage your system files cause sound problem
Feb 06, 2009 | Fujitsu Siemens LIFEBOOK N6110 PC Notebook
VIDEO ACCELERATOR NOT DETECTED
Sounds very much like a video driver issue. Most likely from the aspect that the video driver MAY not have compatibility with your reinstalled o/s. Look for the video driver option, under system then hardware configuration. You MAY need to remove that video from the list, then have the Plug and Play reinstall it. The driver is perhaps on the accessories disk you should have with your Dell.
Feb 02, 2008 | Dell Inspiron™ E1505 PC Notebook
Computers & Internet Logo
88 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
