Question about Black & Decker TRO603 Toast-R-Oven Toaster Oven with Convection Cooking
Not working at all. When turning bake timer dial, on indicator light doesn't come on. (This is the Toaster-R-Oven TRO603)
  • abowie59 May 31, 2010
    Thanks for your advise!! How do you gain access to these parts?
  • 1,284 Answers
Hi, since it is not working at all, then you have to check the switch or thermal fuse.The switch may be faulty and needs replacement of the thermal fuse is burnt and needs replacement too.
Take care
Posted on May 08, 2010
ELECTRONICS SEEM TO WORK (ON/OFF; TIMER; CLOCK; OPERATION SELECTIONS [TOAST, BAKE, ETC]) BUT ELEMENTS DO NOT LIGHT UP
check the resistance of the plug by turning the timer and temperature switch, if there's no resistance, open your unit and check the resistance of thermal fuse which is connected to line wire. it is look like resistor..if the thermal fuse is ok then check the resistance of heating element..
Sep 30, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
Stopped Working!
check the switch or thermal fuse, if it has.
Aug 29, 2009 | Black & Decker TRO603 Toast-R-Oven Toaster...
Kitchenaid kco1005 toaster oven broken timer dial/knob
My kitchen aid toaster oven when set on baking the light is not coming on.
Aug 20, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
Oven just stopped working
1-usually it easy proplem
2- check your electricity voltage by testsrowdriver or another good device like radiocasset or voltmeter if you can
May 31, 2009 | DeLonghi XR450 Retro Toaster Oven with...
Never received the direction book.need one
Go here and download the pdf file. You'll need adobe.
http://personafile.com/Black-&-Decker-Toast-R-Oven-Broiler-TRO600-TRO603-TRO604-P0508755200417.htm
Dec 12, 2008 | Black & Decker TRO603 Toast-R-Oven Toaster...
Rotissere Toaster Oven Just Stopped Working
the problem is internal and it might be the fuse or the thermostat
Dec 05, 2008 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
Re: Used Unit
need adobe
Sep 14, 2008 | Black & Decker TRO603 Toast-R-Oven Toaster...
Delonghi Toaster Oven Color Select Dial does not turn off
This sounds like a defective timer switch that is not turning the oven off at the end of the time selected. You will need to replace the timer switch. The switches are available but unless you're able to do this kind of work you will need to take it to a repair shop. If you want to DIY you can find the switch at www.thegourmetdepotco.com or www.applianceparts.com. If you don't have a part # you will need the make and model # to get the correct switch.
Jun 19, 2008 | DeLonghi EO1258 - Stainless Steel Toaster...
Oven does not turn on
These ovens have a timer switch that lasts just about a year. Mine did the same thing and you cannot find the timer switch anywhere in the USA. The switch is likely a DKJ/1-60. There is a switch made by Delonghi that will work. The part # is 05XDE5218104600. You can get one at "The Gourmet Depot" website for $10 + shipping.
Jan 23, 2008 | Black & Decker CTO6300 Toaster Oven with...
Black & Decker TRO603 Toast-R-Oven Toaster Oven with Convection Cooking Logo
88 people viewed this question
Top Black & Decker Toaster Ovens Experts
Dave
Dave
Steve
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
