Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
It is currently saying it has 1333 bad blocks when i tested it in tech tool pro. This drive has hardly done anywork. Where do i go from here?
    Scholar:
  • 193 Answers
If u dnt need the data inside the drive, you can try to make a low level format....it will fix the drive, **** it will take a while.
for that you can google for availble softwares that can suite your running operating system, **** its much better using dos tools, like winpe mini cd, there is hirens boot disk inside the cd, and there u can find many tools for low level format or recoveries.
google for winpe mini cd, burn the downoaded iso, unplug any existing internal hard drives, plug the external drive and boot the cd.
gd luck
Posted on May 12, 2010
Need Good & Free test and read/write surface scan tool for a Fujitsu MHT2040AH.
Try the ultimate boot CD, there you can use may hard drive diagnostic utilities, perhaps Test Disk will suit your needs, here;s a link
http://www.ultimatebootcd.com/download.html
Hope that helps
Christopher
May 17, 2012 | SimpleTech Simpledrive Computers &...
I installed window xp but its too slow. what should i do.
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive)))
then click start all programs accessories system tools defragment your hard drive
you might have to install more RAM random access memory to check how much ram you have
to check the details on your computer
click start all programs accessories system tools system imformation you will see all of your computers imformation from there another way of doing this
click start right click on my computer select properties you will see all imformation about your computer including installed ram
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer if you see something running that you don
Jun 03, 2011 | ASUS P5GC-MX/1333 Motherboard
No output to monitor. Monitor tested with good PC and is OK. No alarm beep code
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
one bad lead will end with a computer error
hope this will help
Mar 27, 2011 | ASUS P5GC-MX/1333 Motherboard
Reloading windows on a p5 mx 1333 mb with a 20gb hard drive it only loads a little and than stops saying insinigant memory
you are hitting a dead spot in the drive when cridical information is stored on the drive try a larger drive
May 05, 2010 | ASUS P5GC-MX/1333 Motherboard
1st Gen Macbook Pro Hard Drive Clicking
store.westerndigital.com or http://www.seagate.com/www/en-us/products/external/
Nov 08, 2009 | Apple MacBook Pro Laptop Computer with...
Toshiba splash screen freeze
sounds like a bad hard drive to me. I would suggest testing the hard drive using a bootable testing program like pc check and if it is bad replace the hard drive and restore the operating system
Jun 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Computer wont pick up hard drive tonight- have checked all cables - they are all good but the computer wont pick it up. light is still on on hard drive ...
Hi, Try the drive on another system, if it works there then there is either a driver or registry setting stopping it from working on the current computer. If it doesn't work on the other computer then the failure is likely in the drive. In this case you can take it to a PC shop and have the techs move the HDD into a new enclosure to test it, if that works you're done, if it doesn't the HDD itself has failed and you will need the help of a pro. If it shows on the other computer, or, if it doesn't and fails to work in a new shell, comment back here with either the specifics of the computer it's not working on including specs, windows version. If it's failing to work in the new shell and you need a pro comment back with that info and your location, country/state/city and I will recommend an appropriate facility to assist you. Chris
Jun 05, 2009 | Buffalo Technology Computers & Internet
Western Digital 500GB
http://docs.info.apple.com/article.html?artnum=9805
That drive is not suitable for pro-tools. Look for something that has the Oxford 911 or 924 chipset. HFS is the format. Did you format that drive after you bought it? Are you using both windows and os X with either boot camp or parallels?
Oct 13, 2007 | Western Digital My Book Essential Edition...
Error E602-001
The hard drive does need to be replaced and must be done by an authorized Canon service tech (like me) who has access to the system software. The system software ( or firmware) is installed on the new hard drive using Canon's Service Support Tool. Check here to find your local authorized Canon dealer.
http://www.usa.canon.com/opd/controller?act=OPDSupportDetailAct&fcategoryid=2275&modelid=889
Apr 23, 2007 | Canon imageRUNNER 3300i Printer
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
81 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
