Question about Kenmore 73952 Gas Dryer
Dryer does not heat
I replaced igniter, thermo sensor and still have same problem
  • Kenmore Master
  • 8,220 Answers
Clean it up and replace the fuse amigo Older models have the fuse to the reardryer does not heat - 39b9f91.jpgabf02b3.jpgnewer models have it on the blower housing. Post yer model number for a better answer friend.5d0f07f.jpg
Posted on May 08, 2010
DRYER WON'T HEAT
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
www.partselect.com/Repair/Dryer/Not-Enough-Heat/
When your gas or electric dryer is not producing any heat or not enough heat to ... If the sensor is defective, either the igniter won't glow or the gas valve won't ...‎How to test a dryer's heating ... - ‎How to open your dryer's cabinet
How To Troubleshoot A Dryer That Won't Heat ' PartSelect ...
? 4:23
www.youtube.com/watch?v=ahb5pt52drE
Oct 6, 2011 - Uploaded by PartSelect
How To Troubleshoot A Dryer That Won't Heat ' PartSelect.com ... If you're using an electric dryer check ...
Oct 30, 2015 | Dryers
Speed Queen gas dryer model #AGM499W. Replaced the igniter but did not fix the problem. Dryer will not heat.
burner may need to be vacuum out or blown out, also could be the thermo coupler. Hope this helps tim
Sep 02, 2010 | Speed Queen AGS28AWF Gas Dryer
Whirlpool dryer wont heat>replace igniter > no heat
Bad thermo switch located behind back cover in area of duct work. 1/4"x2" white in color, two wires connected to it. Stops ignition from firing.
Jun 06, 2010 | Whirlpool LGN2000LWH Gas Dryer
Gas dryer heat not going on. Vent is now
In duct area there is a thermo switch. 1/4"x2" white in color. two wires are connected to it. This goes bad from overheating due to dirty duct work. This stops dryer from firing to ignite gas. Replace and you should be good. You can check all other thermo switches with a tester. Some are silver and round some are what I stated.
Jun 06, 2010 | GE DCVH515GF Gas Dryer
My kenmore dryer series 70 is not heating, i replaced igniter, thermo sensor, and still does not heat....there is no glow from inside please help....
Check the fuse Note: Gas dryer thermofuse is linked to the gas assembly and blows whenever the temp exceeds 350f rapidly. Remove all air restrictions15f9d55.jpgbefore replacing that fuse or you will just need to keep buying em.f8e11bb.jpg65c991e.jpg
May 08, 2010 | Kenmore 62602 Electric Dryer
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Gas dryer no heat
There are many things it can be, does it ignite at all? do you get voltage to the igniter? whirlpoolpartssurplus.com open still give me a calll and we can talk for free..
Jun 24, 2009 | Kenmore 73952 Gas Dryer
Cycles but no heat
The igniter needs to be near the burner jet in order to get a flame started when gas is provided,, the thermo fuse should be situated on the heat duct. I do not have access to Kenmore service manuals to provide any specific darwing details.. my comments are based on other brands.. I hope this helps..
Aug 30, 2008 | Kenmore Dryers
Kenmore 73952 Gas Dryer Logo
93 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
