Question about Xerox XC356 Copier
Does my copier have a drum cartridge and toner cartridge or is it all the same
    New Friend:
  • 44 Answers
It has separate drum and toner cartridges.Toner cartridge is located at the front (small dor on the right side).Drum cartridge is located at the bottom side of the mashine.
Posted on May 14, 2010
How to clean the magenta toner sensor on a canon imagerunner c5255 copier
Step 1Turn off and unplug your Canon copier. Put on a pair of latex or work gloves to keep toner and debris off of your hands. Cover a table, desk or other surface with three to four sheets of newspaper to protect the surface from spilled toner Step 2Open your copier's toner cartridge door on the front or top of the device and remove the toner cartridge. The cartridge contains the drum as part of its unit. Lay a flannel cloth onto the newspaper-covered table, desk or other surface and then shake the toner cartridge gently above the cloth to coat the cloth lightly with ton
Place the cartridge upside down on the newspaper-covered surface and open the drum's shutter door, which contains hinges. Rotate the drum using the spindle on the side and wipe the drum's surface with the toner-covered flannel cloth to remove any dust, dirt and caked-on debris. The drum only rotates in one direction. Work quickly so as not to expose the drum to light. Artificial and natural light can damage the drum's surfac Step 4Continue rotating and wiping the drum's surface until it is free of any debris and dirt. Close the drum's shutter door and reinstall the cartridge back in your Canon copier.
Sep 28, 2016 | Canon Office Equipment & Supplies
I changed the cartridge in my oce fx3000 copier and I still get the message "change drum" and it won't work
The toner cartridge is a completely different unit from the drum unit. The drum unit is replaced separately, and is good for about 25,000 pages. The toner cartridge contains the toner powder. The drum actually fuses the toner powder to the paper.
Feb 26, 2015 | Office Equipment & Supplies
Toner cartridge spreads toner all over inside
If the toner cartridge is dumping toner it is defective and needs to be replaced.
Dec 08, 2014 | Sharp AL-1631 Drum Unit - 18000 Pages...
How to change the drum cartdrige.
Remove the imaging unit ,remove the charge corona assy,remove the OPC drum,remove 2 screw and dump the developer out.Reinstall the imaging unit ,pull out the toner cartridge and push in toner cartride ocation the developer cartridge.Turn on the copier and wait then the copier perform the new developer initialization.Whwn the Start button in ready(green light),change the developer cartridge to toner cartridge.
Mar 05, 2013 | Minolta EP1031/1031F CS/PRO Copier
Spots in middle of paper and there are horizotal streaks in the printing
The light sensitive drum in the toner cartridge is dirty.
remove the toner cartridge, move the cover over to reveal the drum and use a soft cloth to wipe the old toner off the drum.
If you cannot remove the toner or the drum is scratched, then purchase a new toner cartridge.
A new toner cartridge will fix your problem.
Sep 09, 2010 | Dell 2130cn Laser Printer
My MF8180C is asking to replace the K cartridge, and I have bought a 301 toner cartridge but the printer has a drum cartridge instead. How do I replace the black toner into the drum cartridge or do I have...
the toner crg is located in front of copier, the drum is separated from toner and it removes if you open upper cover.
If the copier ask you for toner open front cover and replace toner.
You do not have to replace drum if the copier doesnt tell you to replace.
Jul 11, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
Do you get a new drum with a toner replacement cartidge or is it a separate thing you have to buy
Hello.
The drum and toner cartridge are separate items. Both are replaced by the user.
The toner cartridge holds toner/ink. The drum does the work. You will need to replace the drum for every 4-5 toner cartridges used.
I've seen toner cartridges for your printer at $36 vs $60 for a drum.
Hope this helps.
Jun 13, 2010 | Brother MFC-7440N Laser Printer
The problem is the drum unit & toner catridge the paper stock inside the drum unit & toner catridge..
I understand the paper is stuck inside the drum unit and toner cartridge. Great. Take the drum unit out, separate the toner cartridge, and since you see paper, pull it out carefully with the tweezers. Do not touch the drum or the toner cartridge part.
Oct 12, 2009 | Office Equipment & Supplies
How do I add toner to machine? Also, is this copier do color copies?
1 Open the front cover and pull out the
drum unit and toner cartridge assembly.
2 Hold down the lock lever on the left and
pull the toner cartridge out of the drum
unit.
3 Unpack the new toner cartridge. Place
the used toner cartridge into the
aluminum bag and discard it according
to local regulations.
4 Gently rock the toner cartridge from side
to side five or six times to distribute the
toner evenly inside the cartridge.
5 Remove the protective cover.
6 Insert the new toner cartridge in the
drum unit until it clicks into place. If you
put it in properly, the lock lever will lift
automatically.
7 Clean the primary corona wire inside the
drum unit by gently sliding the blue tab
from right to left several times. Return
the blue tab to the Home position (▼)
before reinstalling the drum unit and
8 Install the drum unit and toner cartridge
assembly in the MFC.
9 Close the front cover.
If you need illustration for this, click on the link below and turn to page 112
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_7420_7820N_EN_1156.PDF
Jun 02, 2009 | Brother MFC-7820N All-In-One Laser Printer
Sharp COPIERS - AR-5316
The cleaning blade is in the drum cartridge.
There is no developrer change in that product.
There are 2 cartridges.
The toner and drum.
Toner contains all you need as far as ink. And also the waste sump is on the toner cartridge.
The Drum is a self containted unit that has the cleaning blade and auger built in.
Jan 10, 2008 | Sharp AR-5316 Advanced Digital Imager...
Xerox XC356 Copier Logo
319 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
