Question about Disney Princess TV/DVD Combo
DVD player will only play in black and white
The TV channel is in colour but as soon as I swap the TV mode to DVD, the channel goes into black and white
  • 2 more comments
  • beach21 May 16, 2008
    How come the dvd player only plays in black and white?
  • kimvi Sep 20, 2008
    We have the Pirates of the Caribbean version on the the tv and it does the same thing.
  • Anonymous Dec 23, 2008
    same
  • delapa4 Mar 07, 2009
    I have the same problem as Helen C's when it comes to a dvd playing black and white instead of color. I tried the solution mentioned, but when I went to the menu I found nothing that said PAL or NTSC, who exactly to I get there? Help, my daughter and I need help :(
  • 3 Answers
Ok, our daughter's tv was doing this same thing it only played black and white on the dvd channel. we finally figured out that she had changed a setting in the menu. when you go to the menu, you will see something that says either PAL or NTSC...set it on auto. that should fix it...good luck
Posted on Jan 11, 2009
    Sergeant:
    Champion:
  • 375 Answers
Are you using a/v inputs or composite inputs .
Posted on Mar 27, 2008
SOURCE:
Dvd plays black and white tv is colour
be sure to check all your input/output connections & cables
Nov 26, 2013 | Digihome LCD TV
Our Emerson EWD7003 now only plays in black and white after DISH hookup
Does the Tv channels show colour? if yes! I would try another audio/video cable connection from the DVD player to the Tv and try another input to the set, to see if that will help.
Apr 25, 2012 | Emerson EWD7003 DVD Player
Koss dvd player kd305a plays black and white.
Check the av channel on the tv,the av is normaly av2,if it say`s any different then press the av button on the tv r/c until it plays in colour
Oct 15, 2009 | Televison & Video
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Connect Philips DVD to Sansung TV
the red and black are the same as the red and white, these are the audio left and right channels. the yellow plug is the video plug. the next thing you have to check is wheather your tv has video 1 and 2 channels
May 09, 2009 | Samsung Televison & Video
DVD player only plays DVD in black and white - what's wrong?
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
Jan 11, 2009 | Sony DVP-NS330 DVD Player
Sansui SAN1880 80g dvd recorder no colour
Hi, I have a Sansui Model San1880, after I have manually program the TV channels, I don't get no sound at all only on the TV channels its got good pictures but no sound, would you please tell me what to do.
Thanks
Rod
Mar 01, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Dvd tv
you need to check if the dvd is in svhs mode on the dvd channel as that is normaly the problem or could be a scart lead problem try another one
Feb 08, 2008 | Televison & Video
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Disney Princess TV/DVD Combo Logo
257 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Dalynn Turner
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
