Question about Fedders D Chassis A6D24E7A Air Conditioner
COMPRESSOR RUNS FOR TEN MINUTES STOPS AND WILL NOT COME BACK ON
FEDDERS A6D24E7B-B
IT WILL NOT COOL TO SET TEMP
COMPRESSOR RUNS FOR ABOUT TEN MINUTES THEN THE FAN GOES TO MED FOR A WHILE THEN THE COMPRESOR STOPS AND WILL NOT COME BACK ON .
  • GSmythe Aug 21, 2013
    99% of the time you have to clean the outside coil. I have to do this every summer because pollen gets in and both ac's stop cooling. Just had it done yesterday. The inside surface of the outside coil gets loaded and caked up. You can buy a spray then hose it off or use compressed air.
    Guru:
  • 1,524 Answers
Check amperage while unit is running.
Posted on May 08, 2010
My fedders ac window unit turns on and gets cold for ten minutes then the compressor turns off and dont turn on until i turn it off for about 20 minutes
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The outdoor coil is plugged with ****....
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 03, 2010 | Fedders D Chassis A6D24E7A Air Conditioner
You can set the temp for the unit to come on and it comes on and runs and cools for a few minutes then the compressor cuts off then the fan a little later. After a few minutes it comes back on and does...
Is the AC set on an energy saving mode. Together with this program if the thermostat is defective the same symtoms can appear. So please check on the thermostat and replace.
Since the compressor is cutting off the cooling does not take place to the extend that is set.
Aug 30, 2010 | Whirlpool ACC184PS Thru-Wall/Window Air...
Maytag M6Y18F7A Air Conditioner troble light turns off
you have to open the unit up or atleast see if the fan is failing. The blower motor is usually a double shaft and cool the compressor and also blows the air across the evaporator. Look for the air to stop blowing then the compressor to shake from overheating.
Aug 12, 2009 | Fedders AEY08F2FCOM Wall/Window Air...
Samsung frig stopped cooling-
most new fridges have a self defrost mode once or twice a day because the coils ice up if it collects alot of moisture. it shuts the compressor down and turns on a heat coil to defrost (which can take up to a half an hour). usually on a timer that is adjustable.
Jul 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Unit Turns Off
Have you checked the breaker in the breaker box to see if it's tripped? Also check the amp rating on the air conditioner and the amp rating on the breaker the unit is plugged into, the breaker may be weak or not a high enough amps or rating for the unit it's trying to power.
Jul 01, 2009 | Friedrich QuietMaster RS10J10 Air...
Maytag side by side slowly getting warmer
YOU ARE BE GETTING A WEEK COMPRESSOR.
Jun 09, 2008 | Refrigerators
Fedders D Chassis A6D24E7A Air Conditioner Logo
390 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
