Question about One For All URC-3021 Remote Control
Need codes 4 t.v!
Need 2 know how to program, and get codes for my t.v?
  • 2,335 Answers
I can help you with your URC-3021 Universal Remote Control issues.
Without knowing what brand of TV you would like to control, may I recommend using the URC-3021 One For All URC-3021 Code Search, or refer you to the Urc-3021 Code List?
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
One For All URC-3021 Code Entry
Urc-3021 Code List Download
Posted on May 09, 2010
How to program 4 Device Universal Remote Control to sharp tv
programming procedure it too much to type in here, and is not practical. If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 11, 2014 | Deluxe 4 Device Universal Remote Control
I have an One For All URC-4700B00 Acess 4 remote control which I have lost the codes for! I need to program a Sharp television but I need the 4 digit codes.
I recently came across this link that has the codes for many manufacturer's remote controls. I don't know if it will help you, but give it a shot and let me know. Here it is.
Best Regards,
Mark
http://www.hifi-remote.com/ofa/codes.shtml
Jan 24, 2011 | Televison & Video
I have an RCA RCR312W remote and lost my manual, request the steps needed to program my JVC tv / I have the codes, just need to know the steps to take ... Thank you
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
Thank you
Jan 16, 2011 | RCA RCR311B Remote Control
The lock is installed need to know how to program
First make sure you have the door handing set properly. Retract the bolt manually if extended. Now press the lock button... If the unit extends the bolt, then you're good. If not, switch the jumper position on the control board. If it's covering pins 1&2, move it to cover 2&3 or vice versa.
To program code #1..
Push the program button on the control board once. Enter your 4-8 digit code. Push the lock button to end the entry. The unit will emit a 2-second long beep. If it doesn't beep, you were too slow. Try again.
To program code #2, press the program button on the control board TWICE. Enter your 4-8 digit code. Push the lock button to end the entry. As before, the unit will emit a 2-second long beep when a successful entry is made.
Test your codes with the door open just to be sure.
Dec 16, 2009 | Weiser Lock Powerbolt 1000 Lock
Need to know how to program rca universial remote to sanyo 27inch
First off. What kind of RCA remote. and second 1.Turn on the TV 2. Press and hold the TV button 3. Enter the 4 digit code *1004,1048,1049,1050,1080,1107,1108,1162,1169,1180
4. Press the on off button (may need to press twice) 5. if nothing works try entering another code.
Note: your remote may only need a 3 number code. but most require 4
Mar 10, 2009 | Sanyo DS27510 27" TV
Need code to program ge remote control and dvd player
Go to the following page to get information on how to program your GE remote:
http://www.jascoproducts.com/support/download-files/GE-Universal-Remotes-Instructions.pdf
Codes for 4 digit remotes:
PHILIPS ............. [0371] [0344] [0345]
Codes for 3 digit remotes:
PHILIPS ............. [734] [743] [744] [745] [755] [814] [823] [824] [825]
Thank you for using Fix Ya!
Good Luck!
If you have any other questions, just let me know!
Don't forget to rate the overall satisfaction of this solution.
Feb 02, 2009 | Philips Magnavox Learning Universal Remote
Need new 4 digit manufacturers codes
I have the 4 digit codes. Let me know how to get them to you or post them here. Let me know if you figure out how to insert them into the SUR-20. When I press 2 digits, the Sima beeps like it is finished and goes back to remote control mode. Thanks.
Jun 01, 2008 | Sima SUR-20 LCD Touchscreen Remote Control
Need codes for comcast remote to ilo tv
When programming your Comcast universal remote for your TV, the programming guide states that you should enter the 4-digit code provided for your equipment, and if you did it correctly, the TV button will blink twice.
What you have to do is put a "1" in front of your 4-digit code, making your code a 5-digit code. For instance, the code for my Panasonic is listed as 0250. I tried and tried. Then I entered 10250 and it worked perfectly the first time. I did it again to make sure I wasn't seeing things, and it worked.
Good luck.
Apr 10, 2008 | Audio Players & Recorders
One For All URC-3021 Remote Control Logo
540 people viewed this question
Top One For All Televison & Video Experts
S. Gontko
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
