Question about LG 22" FLATRON LCD Monitor
LG Flatron W2234S 22 purple tint problem
I have an LG Flatron W2234S 22" LCD monitor.
When I first turn on my monitor, the picture is fine. However, as it warms up to normal operating temperature, the screen will begin to flicker between normal and a purple "tint" or "haze" (as if there is not enough green to balance with the red and blue). For example, the tint will make gray colors look purple and yellow colors look red. The tint shows up against darker colors more than lighter colors.
Here is a picture of the monitor displaying a color test pattern (notice the drop in green):
http://img706.imageshack.us/img706/4199/badmonitor.jpg
Eventually, the flickering between normal and purple tint gets worse, until purple haze mode takes over and it won't flicker back to normal, unless I turn off the monitor and let it cool off for several hours.
  • 2 more comments
  • jayce_cruel May 10, 2010
    Yes. In fact, I tried a second VGA cable just to make sure that wasn't an issue. The problem continued witht he second VGA cable.
    I also tried using a second monitor to ensure that it wasn't a problem with the video card itself. The other monitor worked fine with either VGA cables.
    I believe this narrows the problem down to the monitor itself.
  • Bud Martin
    Bud Martin May 11, 2010
    Did you check the VGA cable plugs at both ends?
  • jayce_cruel May 12, 2010
    Yes. I checked to make sure both VGA cables, and associated plugs, worked correctly. I even hooked up a different monitor, using each of the two cables, to ensure that the problem was with the monitor and not the cables or the video card. The different monitor worked fine, with no tint, and no problems.
  • jayce_cruel May 14, 2010
    Well, I checked the capacitors, and none of the capacitors had bulging or broken caps.
    Unfortunately, in getting to the circuit boards to check the capacitors, I destroyed one of the plugs, so I guess this ends this problem...Thank you for your help!
  • 109 Answers
Your LCD monitor has bad ccfl lamps or inverter circut..
Posted on May 09, 2010
  • profpat May 11, 2010
    this really looks like a failing ccfl lamps or inverter circuit, maybe also power supply section...as budmrtn suggested, some capacitors are bulging due to overheat.. best is to bring the unit to a qualified monitor repair center...
    Scholar:
  • 34 Answers
When it does off picture after sometime and then back again. It's due to the 'power transistors' in the VGA card part overheating after becoming a bit old, or the one's in the panel. It's not really economic to buy a replacement panel at 70% of a new LCD. Can buy a replacement VGA card for 30%. The parts number are Manufacturer Part Number EBU59489401 Board Numbers 791501300700R For a replacement card
if no warrenty, $50
search google/ebay.
Else the W2234s is very easy to dissassemble from it's cases. And put a house fan at the back @ to provide the extra cooling to keep it going, if it's not to bad. Keep fingers to the sides of the boards else !
Posted on Jan 16, 2011
  • 145 Answers
I had flickering, then it went black. little blue led would then blink. solution was alittle barbaric but did the job. a swift slap to the back of the monitor and disable screen saver/standby. havent had a problem in 30 days so far.
note: I sent this unit to LG 3 times for warrenty repair. Issue was never resolved and warenty expired.
Posted on Sep 13, 2010
  • 11,361 Answers
Inspect the caps in the Logic/LCD driver board and in the power supply/inverter board, look for caps with bulging tops. See example here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 10, 2010
Lg w2234s-bn Monitor Cycling randomly through Light View Modes/Power Button turning It's self on and off.
On and off cycleing could be caused by a bad power supply or a low battery on your remote. Check them both out. Good luck.
Apr 28, 2012 | LG 22" FLATRON LCD Monitor
Lg w2234s keeps turning itself off, all cables ok so is video card, any ideas
try pressing on source key, the monitor has two input sources one digital and one analog maybe it's on the wrong input (digital connected while monitor on analog or vice-versa)
Oct 14, 2011 | LG W2234S 22" LCD Monitor
I have a LG FLatron Wide monitor worked for 3 years but now is got this pink tint that I can not remove???
A pink tint is an indication that the CCFL lamp/s is about to fail. The CCFL lamp/s provide the back light.
For replacement parts go to this WEB site.
www.lcdparts.net
Apr 20, 2011 | LG 22" FLATRON LCD Monitor
When I turn off the computer or restart the computer or put it in a sleep mode, my LCD monitor LG Flatron W2234S always turns black but the LED stays blue instead of yellow and the monitor does not react...
Try changing the Resolution for the lowest one, if it works it will see the letters and everything very big. I have same trouble, specially since I change the original Vista Starter for the new Windows 7, I have not found a free controler that helps me and I have seen many people with same the problem. Sorry for my english.
Dec 11, 2010 | LG 22" FLATRON LCD Monitor
Lg w2234s lcd sudenly lost power and wont go back on
power cord connection may be loose at both end tight it
Aug 22, 2010 | LG 22" FLATRON LCD Monitor
Color is off,i have a blue tint to screen cy
mcdevito75 here, You should have an AUTO button on your monitor that when pressed or pushed it"ll automatically adjust your monitor picture. If this doesn"t help you can try the menu button to adjust manually.
Jul 07, 2010 | LG 22" FLATRON LCD Monitor
Doese not want 2 go on !!
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Jun 21, 2010 | LG 22" FLATRON LCD Monitor
Lg 22' monitor was widescreen now has black bars!! Cant remove ?
the grpahics from wowc burnd the sides of your monitor. your pretty much screwed if you keep playing that game
Aug 16, 2009 | LG Flatron L1710S 17" LCD Monitor
No picture lg flatron w2234s blinking blue light
Hi My screen developed exactly the same problem. It appears to be a hardwear problem associated with the screen it's self. continuity test is ok on the lead so I took it back to the shop under warranty and hey presto, the replacement works. I don't know what the problem is but there are a number of other folks on another thread with the same problem and their entries are dated May 09 too.  Dave
May 26, 2009 | LG Flatron L1750S 17" LCD Monitor
LG 22" FLATRON LCD Monitor Logo
1,875 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
