Question about Samsung WEP200 Headset
Won't pair with my Samsung mobile phone
My phone states ""no bluetooth device found " when I search for the bluetooth. any suggestions?
  • 2 more comments
  • Anonymous Jun 16, 2008
    wont pair my nokia 6288 with samsung wep200 headset
  • bschool Jul 15, 2008
    My Hue will not locate my WEP200.
  • jamiejeffk Jul 19, 2008
    won't pair w/my blackjack 2
  • sk8punk27 Oct 18, 2008
    i have the same darn problem...very frustrating to have bluetooth and not even work
I too had trouble pairing with my phone. Here's what worked for me:
Just make sure when you're first syncing this to your cell phone, hold the main button for a REALLY long time. NOT till it flashes (keep on holding it). It will eventually go from flashing to a SOLID blue light, and that's when you sync. It'll probably take like 30-60 secs of holding.
Posted on Jul 19, 2008
Thanks!!! It works :-)
Posted on Sep 15, 2008
How do I pair a Samsung bluetooth headset model HM1000 to my Nokia C7-00 phone?
1.first on samsung bluetooth device
2.press& hold call answer button in bluetooth device now light is on ,not blinking
3.and then search your bluetooth device by your phone and pair.
Apr 11, 2012 | Samsung HM1000 Bluetooth Headset
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
My samsung sgh-t139 cannot connect be found on bluetooth
To Turn Bluetooth On or Off
This option allows you to turn Bluetooth On or Off.
1. From Idle mode, press Menu ? Settings ? Bluetooth.
2. Make a selection and press the Select soft key or the OK button on your keypad.
My Devices
This option allows you to search for new Bluetooth devices. Highlight the Search new device option and press the Select soft key or the OK Button on your keypad. The phone searches for available devices.
Sometimes cell phones and bluetooth devices become problematic when trying to pair them together. If you've followed the directions correctly but are still not able to get them to pair, take them to your cellular company's store and let them pair the devices. They can show you step - by - step how to correctly do it.
Jan 26, 2011 | Samsung Cell Phones
NOT CONNECT TO MY MOBILE PHONE
you have to check the compatiblity of this device with yout cell phone.
Connectivity Bluetooth version
  • 2.1 with enhanced data rate (EDR)
Bluetooth profiles
  • Handsfree profile (HFP) 1.5
  • Headset profile (HSP) 1.1
if your cell phone has the above features then follow the undermentioned steps.
you need to search for the device by starting a new search after switching on the bluetooth and make sure that the bluetooth headset BH-104 is switched on.
once the search is completed and your device is found then pair it.
after pairing the device you can use it.
Dec 26, 2010 | Nokia BH-104 Bluetooth Headset
How do I put this bluetooth (ant Z9i)into pairing mode? please be detailed as possible...
Pairing Procedure (This is an example only and may differ from your phone, but the process will be the same.)
1. First turn the phone OFF and then back ON again to refresh its memory.
2. Bring the mobile phone to about 30cm from the Z9i Dual Microphone.
3. Find the Bluetooth menu in your mobile phone. Turn Bluetooth ON. (Check your mobile phone user guide if necessary)
4. With the Z9i OFF, Press and Hold the MFB for about 6 seconds. The LED will appear a solid Blue, and then will start fl ashing. The
Z9i is now in Pairing mode and ready to be found in searches by other Bluetooth devices. Pairing mode will be active for 2 minutes.
5. Perform a Bluetooth device discovery on your mobile phone to add a new device. (It takes a few seconds to search for
and fi nd other Bluetooth devices around you).
6. When Bluetooth devices are found, the phone will display “BlueAnt Z9i”. Scroll to it and press OK to confi rm that you
want to Pair with it.
7. Enter Passkey “0000” when your phone prompts you. The phone and Z9i will now Pair.
8. An additional security setting in your phone may be needed to allow the headset and phone to connect automatically
without confi rmation each time you connect your Z9i. Generally in the options for the BlueAnt Z9i, it will be referred to as
“set as authorized”, “add to trusted devices”, ‘’allow connection’’ or similar.
9. If required for fi rst time connection, select the BlueAnt Z9i to connect with your phone. OR, Click the MFB on the Z9i,
to connect with the phone.
You can get the manual on link below. page 9 tells you how to pair.
http://myblueant.com/downloads/manuals/Z9i_manual.pdf
good luck and please rate 4 thumbs for the free answer
Mar 28, 2010 | Blueant Z9i Bluetooth Headset
Cant pair my wep 500 with my phone
passcode = 0000 (4 zeros) USER GUIDE
The first time you turn on the headset it will enter "Pairing" mode. In this mode you can connect your headset with your phone or other Bluetooth enabled device. If you have already connected one device to the headset, you can enter Pairing mode by holding the multi-function button turns solid blue.
Once in pairing mode, set your phone or other Bluetooth enabled device to search for the headset. While each device is different, the setting is often found in a "Settings" or "Bluetooth" menu and the "Search" or "Discover" Bluetooth devices option. On the list of discovered devices, choose "Samsung WEP500" and select "Yes" or "Ok" to connect to the device. When asked for the passkey, enter 0000.
Feb 05, 2010 | Samsung WEP500 Wireless Headset
Sending things
no way possible if your computer doesnt have a bluetooth device attached....
Sep 02, 2009 | Samsung SGH-J750 Cell Phone
I have samsung sgh-a707 phone cannot pair plantronics 521
I have samsung sgh-a707 phone cannot pair my new plantronics 521blue tooth.I search but get "no devices found".is it the phone or bluetooth?Help
Dec 23, 2008 | Plantronics Hama Voyager 520 Bluetooth...
Pairing my bluetooth with my new samsung..
switch on the bluetooth on both the device and then select option "shown to all "now starts searching from any one mobile.now you will see the name of other mobile ,now select option button and then it will ask you to pair..just select pair option and then it will ask you for a code type any code like 0 ,1 ,2 ,now other device will get a message that mobile no1 wants to connect .click on to accept and now it will ask you for a code, here you have to enter the code which you typed at mobile no1 .enter the code in mobile no2 and your mobiles will get paired
i tried my level best to resolve the issue.it was not my problem that i was not getting reply message from you........but anyway ...if you want further help let me know........i am still online to assist .........
thanks for using fixya technical support.you have a wonderful day
Jun 23, 2008 | Samsung SGH-D900 Cellular Phone
Samsung WEP200 Headset Logo
128 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
