Question about Whirlpool LSR5132PQ Top Load Washer
Linking water ... need to take off cover. from underneath loo
Looks like it's leaking from water pump. Whirlpool no model number. Single control knob right side.
  • Whirlpool Master
  • 8,220 Answers
Here are some videos that might be of interest to you:
TOP LOAD NOTES
Posted on May 08, 2010
Water Leaks Underneath
You really need too look underneath and see where water is coming from that means raising the machine off floor washing machine quite heavy so need to know what your doing
Nov 09, 2015 | Whirlpool WFW9050XW Washer Front Load...
I have a jacuzzi whirlpool tub in my home that has started to leak at the three button control panel. Flooded out the bathroom so I cut a hole in the tile surround and when the pump is running it leak
First thing you need to do is remove some skirting so you can actually see where the water is coming from.
The 3 position control panel would only leak if the water was above it or covering it if it is located in the wall of the tub. That solution would only require the bather to NOT fill the tub quite so full.
IF however the water is coming from another location then that will be noticeable when you are checking for the water leak.
Dec 07, 2014 | Jacuzzi Home
Whirlpool washer leaking from underneath from white discharge and motor area. Is there a teflo
It would mean that the water pump is bad. I have them in stock but i need the model number i can ship them out to you tomarrow.
Mar 13, 2011 | Whirlpool Washing Machines
Leaking whirlpool washer
Probably the pump seal - you need to replace the pump, which is located at the front.
Apr 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
My Amana lw4302 has developed a ;eak. Is this
more than likely the leak is from your water pump,, tip unit back and look underneath seee if u can notice the leak,, this is repairable if its ur pump just need to contact a parts suppplier or company and get correct pump with model number hope this helps
Feb 08, 2010 | Amana Washing Machines
WATER LEAK WHEN FILLING
IS your leak in the front or the back? front could be the pump seal is broke and back would be you water inlet valves. Pump tilt it back and look underneath for leaky seal and water inlet valves you need to take the back off this is a tricky but doable process. post model numbers from now on please
Mar 09, 2009 | Roper RAS8445KQ Top Load Washer
Washer is leaking from underneath....
lean washer back against wall ck pump under front in center for leaks or dark gray area in pump face remove hoses remove clamp top and bottom of pump slide forward off shaft
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Regarding those Cabrio washers that are leaking, while I own the WTW6600 model and have never experienced any leaking, I was told by the service repairman who came out yesterday that there was a flash bulletin sent out by Whirlpool that the fix is in the form of a new inner plastic section. I don't know the technical terms but I saw the bulletin on his computer screen. He mentioned that some people had reported that water was on the left side front of the floor and was being caused by when the water flows through the top section where you pour the liquid detergent, on some models, the water would splash over. He was able to show me the redesigned piece that was being put in to replace those that have the problem. If you are experiencing a problem with water leaking from the unit, and it appears to be in the front, left side area, this could be something covered under that service bulletin.
Sep 01, 2007 | Washing Machines
Whirlpool LSR5132PQ Top Load Washer Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
