Question about Crosley CAWC529JQ Top Load Washer
Replacing drive belt on Cosley Washing Machine
I am trying to replace the drive belt on a Crosley washing machine model cw9500w. I have removed the three torx headed bolts which attach the pump mechanism to the bottom of the motor but the pump will not come off the drive shaft. How do I get the pump off so that I can get the belt on to the drive pulley?
  • Crosley Master
  • 8,220 Answers
You must get it off with out damaging the pulley or motor, You may have to cut it off with a hack saw. Don't beat on it or you might ruin the motor.
Posted on May 08, 2010
Whats tricky about the remover and replacement?
How to Replace a Washing Machine Belt: 12 Steps (with ...
www.wikihow.com > ... > Washing Machines and Dryers
wikiHowLearning how to replace a washing machine belt can be tricky, but will save you from.... specifics of the location and method for removing and replacing the drive belt. ...your washing machine, then your model has what is called a direct drive.
How to Clean a Washing Machine Inlet Screen ' The Family ...
www.familyhandyman.com/...repair/washer...repair/...washing-machine...
A washing machine that takes forever to fill may have an inlet screen clogged with mineral deposits and tiny ... How to Repair a Leaking Washing Machine ... The onlytricky part is removing the screens without wrecking them (Photo 1).
Speed Queen & Amana Washing Machine Repair Manual ...
www.appliancerepair.net/washing-machine-repair-8.html
Online washing machine repair manual CHAPTER 8 - written ESPECIALLY for do-it-yourself ... Belt driven pumps are replaced by simply removing the pump mounts. Tension ... Pump or belt changing on a direct drive machine is a little trickier.
How to Remove Mold and Mildew from Front-Load Washing ...
www.todayshomeowner.com/how-to-remove-mold-and-mildew-from-fr...
Jan 10, 2016 | Washing Machines
Whcandy washing machine grand go f 662 stops mid cycle and the cold wash light flashes and the softener isnt usedat's your problem?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
TOOLS NEEDED TO SOLVE PROBLEM ARE BELOW.
Bucket and rags,Screwdriver,
New drive belt (if necessary),
New drive motor (if necessary).
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Thanks.
Nov 08, 2011 | Washing Machines
Candy washing machine grand go f 662 stops mid cycle and the cold wash light flashes and the softener isnt used
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your selfer can fix it; here's how.
TOOLS NEEDE TO SOLVE PROBLEM ARE BELOW.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reset the agitator.
Thanks.
Bottom rotor is not working
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-yourselfer can fix it; here's how.
Bucket and rags,Screwdriver,New drive belt (if necessary),New drive motor (if necessary)
Thanks.
Drain line clogged on Whirlpool model ET1CHMXKB09. How do I access the drain line?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with most old washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
Thanks.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Fills up but doesn't start turning but starts buzzing a solid buzz
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel. 2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator. 3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor. 4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt. 5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring. 6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch
Feb 15, 2011 | Speed Queen ATSA5AWN Front Load Washer
Washer fills with water but does nothing after that
5
6
Feb 05, 2011 | Whirlpool Washing Machines
Washtub will not move
5
6
Feb 04, 2011 | Washing Machines
My washer had stopped spinning about two weeks ago, we replaced thecoupler and it worked fine but today it stopped spinning again
5
6
Read more: How to Fix Washing Machine Spinner ' eHow.com http://www.ehow.com/how_2092465_fix-washing-machine-spinner.html#ixzz2JXhQRhyW
Feb 03, 2011 | Washing Machines
The spin on the washing machine is not working.It turns but very slowly Machine is A Siemens WM16S38368 2 years old
it may be your agitator
5
6
Jan 31, 2011 | Siemens Washing Machines
Crosley CAWC529JQ Top Load Washer Logo
291 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
