Question about Kenmore 62602 Electric Dryer
My kenmore dryer series 70 is not heating, i replaced igniter, thermo sensor, and still does not heat....there is no glow from inside please help....
  • Kenmore Master
  • 8,220 Answers
Check the fuse Note: Gas dryer thermofuse is linked to the gas assembly and blows whenever the temp exceeds 350f rapidly. Remove all air restrictionsmy kenmore dryer series 70 is not heating, i - 15f9d55.jpgbefore replacing that fuse or you will just need to keep buying em.65c991e.jpg
Posted on May 08, 2010
I have a Kenmore 70 series electric dryer that won't heat. I replaced the heating element (replaced it in September with thermal fuse and it fixed the problem then), but it still won't heat. I've tried...
check the wireling harness / clip. also that the two thermo switches are working.
after that it could be the actual main switch on the top of the machine.
Jan 09, 2018 | Kenmore 63942 Dryer
Kenmore 70 series gas dryer does not ignite I chenge the coil still not heating
Check for burnt out glow ignitor. If okay then check thermal fuse and all other thermostats with ohm meter..... all must be in closed position.
Mar 21, 2010 | Kenmore 73952 Gas Dryer
Kenmore 70 series gas dryer (Whirlpool model) will not ignite!!!!
>> Do you know where the flame sensor is located? I figure the ignitor is where the "glowing" occurs and the gas line feeds to. Thanks for your help!<<
The flame sensor is right next to the ignitor. Also see this link for what it looks like:
http://www.apwagner.com/index.php?main_page=index&cPath=7_96
Mar 18, 2010 | Kenmore 73952 Gas Dryer
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
Heating element or coils not glowing and getting no heat model is a kenmore 70 series and is electric
Bad Thermal High limt,
Bad Thermistor,
Bad heat element.
Need model number, located on inside of door, usually.
Oct 01, 2009 | Kenmore 62882 Electric Dryer
Kenmore dryer not heating
Check the following-- Gas valve coils Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Jun 05, 2009 | Kenmore Dryers
THE DRYER STOPPED PRODUCEING HEAT.
Check the following to address the non heating issue
1. Gas valve coils
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 01, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 series dryer wont heat up and wont stop running
For a gas dryer, check the following
1. Gas valve coils
2. Thermal fuse
3. Igniter
For a electric dryer, check the following
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Jun 01, 2009 | Kenmore 63942 Dryer
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Kenmore 62602 Electric Dryer Logo
668 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
