Question about Audiovox PPC 4100 Pocket PC
Ppc4100 I realllly need some help. My phone did a master reset some how yesterday and now my phone function doesn't work and I can't access the internet. When I try to make a call it automatically hangs up. When I try to go settings and choose phone it does a soft reset. I can't seem to download the zip file I found on a pda website. Also there is no rilgsm.dll file in my phone anywhere so how can I replace it. Can you help pleaseeee and let me know if it needs to be unlocked again or if its' something else. I'm loosing business b/c I can't get phone calls.
  • Audiovox Master
  • 2,075 Answers
It's something else. Do a factory reset on your own
Posted on Mar 27, 2017
SOURCE:
  • 4 Answers
SOURCE: Stop PDA from resetting itself
You need to Hard Reset your device to the deafult manufacter setup. This is easy to do, just open the user manual and read how to preform a ahard reset. Doing so should return the device to its initial factory setup where the on going resets should not happen.
Posted on Nov 13, 2006
SOURCE: Can't use phone
simply replace "rilgsm.dll" in the "windows" carpet, soft reset, enjoy! [email protected]
Posted on May 19, 2007
SOURCE: No sound is coming out my PPC 6700
I had this happen too. The problem was with the headphone jack in my case. I reinserted the headphones a few times and the sounds started working again.
Posted on Jan 09, 2008
  • 91 Answers
SOURCE: USB not recognising Audiovox PPC4100
first download activesync 4.5.0, then try again, try uninstall the device from the device manager and install it again.
Posted on Mar 17, 2008
casouzaj
  • 1118 Answers
SOURCE: it doesnt allow me to
I wonder if you already tried to go to 'Start > Settings > Connections tab > Wi-Fi > Network Adapters tab' and set the 'My network card connects to:' dropdown menu to 'The Internet'.
Just my 2 cents...
Hope you are able to sort your problems out.
Regards, Carlos
Posted on Jun 13, 2010
Hi, a found my old phone in draw but forgot unlock phone code, can anyone help please? emei 354847/01/258856/8
The default phone lock code for Nokia mobiles are 00000 or 1234 . You can try with them. If it doesn't work, You can get the master reset code from www.Wickedunlock.com at affordable cost. master resetting would change your phone to default factory settings.
May 05, 2012 | Nokia 6110 Cellular Phone
Cant unlock key pad on a nokia c3. was working
If you forgot the security password, then you need to master reset the phone. We recommend you to contact your service provider to get the master reset code.
Jul 15, 2011 | Nokia C3 Cell Phone
Why am I being required to type a secret code when the Motorola i1 needs a master reset? Any clue?
Any branded phone is required to enter your code if they wish to reset the phone setting for security purpose. other user can't access,erase or reset your phone if you put a code on it.
if you doesn't know the phone code of yours,
* phone or unlock code is set in 4 digits,for locking some features like message,photo,video and other data you wish to lock up, 1234 will be the default.
* for security code is set in 8 digits,for securing the entire phone settings, 00000000 will be the default.
If you wish a "master reset" ,be sure to back up all necessary data because everything will be gone.
thank you for visiting FixYa..
Jun 16, 2011 | Motorola Mobility i1 Smartphone
Cnt unlock or reset mater code on the motorola rokr for metro pcs
Here is how to do a master clear or master reset on most Motorola cell phones.
If you have a Motorola cell phone and want to clear all numbers out of the address book and reset factory settings you need to use the master reset function.
First you need to go to the main menu, settings, setup, master clear option and enter six zeroes, 0000000
This works on most phones. If that does not work call your carrier's technical support
by dialing 611.
Master Reset Codes and Master Clear For Motorola Cellular Phones.
var dc_AdLinkColor = 'blue' ; var dc_PublisherID = 90892 ;
Sep 09, 2009 | Motorola Mobility ROKR E1 Cellular Phone
Samsung
there's no reset button for cellular phones
try this code, be advised that all information on your phone will be lost or deleted
*2767*3855#
Jun 29, 2009 | Samsung SGH-X680 Cellular Phone
Need Master Reset Instructions
The same exact problem is happening with my phone right now. if you need to use it immediately then turn it on and quickly go to the settings menu to turn off auto-lock and try to avoid pressing the side buttons, don't let the phone lock by itself before you get to the settings otherwise you have to take the battery out and try again.
Aug 25, 2008 | LG Prada KE850 Cellular Phone
I forget the autolock code for my N73
I can't garantie it but this might work.
The default security code for Nokia is 12345
If the default security code doesn’t work, I need the IMEI (International Mobile Equipment Identity)
type *#06# on your phone to get it. I will then calculate the Master Code for your phone.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Apr 03, 2008 | Nokia N73 Cellular Phone
Can't access msg inbox!
you should master reset the phone then try it again and if that does not work you can have the mobile reflash that should correct the issue.
Feb 20, 2008 | Motorola Mobility RAZR V3
Can't use phone
Sep 08, 2006 | Audiovox PPC 4100 Pocket PC
Audiovox PPC 4100 Pocket PC Logo
48 people viewed this question
Top Audiovox Computers & Internet Experts
Rick
Level 1 Expert
Ekse
Jaagoo
Level 1 Expert
Are you an Audiovox Computer and Internet Expert? Answer questions, earn points and help others
