Question about Kenmore 64802 Top Freezer Refrigerator
Need to change the direction of the doors
How do i do this
  • 4,793 Answers
Tip unit on its back and underneath the front you will see the bottom hinge,undo the bolts and slide door down and off repeat with upper door.
it is then a simple matter of changing over from one side to the other.
make sure that door seals are touching all round before standing upright and switching on.
Posted on May 08, 2010
DOOR WILL NOT LOCK TO WASH
The door lock has failed & needs replacing. The attached link will take you directly to the part you need. DC64 00519B DOOR LOCK I have also attached a step by step video on how to change a samsung door lock. Washer Door Latch Replacement Samsung Washer Repair part DC34 00024B
Jun 14, 2015 | Samsung 4.5CuFt White Front Load Washer -...
I need a manual for the Frigidaire FAFS4272LW Front Loading Steam Washer
Hello Ann Todd - I located the manual on the Frigidaire website. Here is the manufacturer link and according to your model it seems like the direction of the door swing cannot be change. If you have difficulties pulling up the requested information, I recommend taking off the last letter of the model number so you can pull up the data.
Feb 16, 2013 | Frigidaire ATF6000ES Front Load Washer
Does anyone have directions on how to change a left door handle on a 1995 Buick Regal 2 door?
PULL DOOR PANEL IN SIDE HANDLE ON WITH RIVITS AND OUT SIDE BOLTED FRON THE INSIDE TO DOOR
Feb 16, 2013 | 1995 Buick Regal
Can u change the door direction on a maytag washer
It is possible with little drilling work on the body. But it requires skill and patience. Wirings to the door lock has to be re-routed etc. It is not worth the trouble!!
Apr 05, 2010 | Maytag EPIC MFW9700S Front Load Washer
Have a genie garage with two doors and need to change one to open, one of the doors that use to open another door. Other door is opened by bluetooth by autmobile. How do you change code on unit on ceiling...
Go to this site and follow the directions under "Replacing a lost or stolen remote" Then you will need to program your bluetooth.
http://www.aaaremotes.com/gegadooptr1.html
Feb 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Can you change the door direction on a Maytag
Unfortunately, you can only change front loading dryer door directions on some models. Washing machines do not allow this. If the units are stacked i may be easier to switch loads, otherwise the dryer door may be able to have the door swing direction changed but without the Dryer model # I couldn't say for sure.
Dec 29, 2009 | Maytag EPIC MFW9700S Front Load Washer
I want to change the direction the freezer door opens ?
You didn't mention whether this is a combination freezer/refrigerator but I'll assume it is.
If you inspect the areas opposite where the hinges currently are mounted, you should see some small, cosmetic plugs that can be pried out. These are the mounting points for changing the opening direction of the doors.
On most units however, doors would both have to be moved since the center hinge is normally a single piece with hinge pins pointed up as well as down. The hinge mounts should have holes slightly larger than needed so that the closure of the doors can be slightly changed to correct alignment.
Oct 27, 2009 | Hotpoint Refrigerators
Need directions to remove driver door interior panel 1997 deville
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls
Apr 21, 2009 | 1997 Cadillac DeVille
1986 s10 blazer changing rear view mirrors from
Hi there. The mirrors should have everything you need mounted to them if they are for an s10. There will be three screws on the external faceplate, under that three larger screws that go through the mirror directly to the door.
Mar 15, 2009 | 1986 Chevrolet S-10 Blazer
Kenmore 64802 Top Freezer Refrigerator Logo
74 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
