Question about Sony Playstation 3 (PS3) Console
Ps3 console will not power on
I have power to the ps3 console. when I press the power on button in front, the green light will come on for a 2-3 seconds..then turns a quick yellow..then powers off
  • Sony Expert
  • 311 Answers
When the lights do this that means that the playstation is broken
on the internet it is called yellow light of death (ylod)
what i recomend you do is call sony even if your warnenty is run out they might replace it for free
fixing it your self is not easy and i do not recomend it
Posted on May 08, 2010
My PS3 isn't working. I put in Madden 2011 and it just shows a blue and green light in the front of the console but nothing comes up on my tv screen. What could this issue be?
Your video settings may be scrambled. Have you recently tried using different cables?
Press and hold the power button until the systems shuts off. (wait 2 seconds) Press and hold the power button again until you here 3 beeps. Let go. It should ask you to connect your controller via usb and press the PS button in the middle of your controller. There will be a menu with 6 options. Try 1-5. If you do not see this menu, chances are, your motherboard has gone bad and will need to be sent in for service.
Be sure to try using HDMI cables and AV (component) cables.
Jan 19, 2011 | Sony Playstation 3 (PS3) Console
I can't play with my partner wiyh the second controller I bought. How to connect so I can with my partner? Second one: I'm struggling to connect to internet. It keeps on sayinf timed out when I search?...
You don't say which console you are using. You need to reset second controller so the console can locate it.
If xbox 360 there is a very small round button on back edge of controller. You need to press this button and then also press the small round button on the front of the console. The lights will start flashing and after a few seconds the console should recognise second controller and you will have 2 green light lit up in the circle round the consoles power button.
If PS3 you need to press reset button inside a small hole on back of controller. YUou need to use a paper clip or something that will fit inside the hole. You may have to plug the controller into the PS3 using the USB cable and press PS button on the controller too.
Dec 17, 2010 | Video Game Consoles & Games
When i turn my ps3 on the green light comes on turns yellow then turns off which it then has a flashing red light how do i fix this problem?
hello try a reset press and hold the standby button on the front of the ps3, you hear 1 bleep the 2 short bleeps after the short bleeps release the button it should reset good luck
regards
shaun
Oct 01, 2010 | Sony Playstation 3 (PS3) Console
Play station three will not turn on on then off when power button is pushed.
First, old PS3 or new slim PS3?
The old models have a power switch on the back that must be on. You'll know its on if you have a red light on the front of your console.
To turn the PS3 on, press the power button. A light should turn green, and you're good to go.
To turn off the older PS3's, you must hold the power switch down for several seconds. For the new slim model, just press the button quickly.
May 02, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 the light on the front goes green white red
Send it in for service at a Sony playstation service center.
It is possible you have a hard drive problem, but you will basically need to buy a hard drive and install it to find out.
Apr 21, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
Turn power on press swich at front red goes to green ie on 2 seconds turns off red
Its called the red light of death, turn it back off then hold down the button, it should beep once then beep twice quickly. It takes a few tries
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
2 LIGHTS ON CONSTANTLY WON'T LOAD GAMES
make sure there is no disc inside first as stupid as it sounds people do do it, when you go to turn the ps3 on hold down the eject button b4 you press the power one then turn the power on whilst stil holding the eject button, if this does nothing when you turn the ps3 off hold down the power button this should reset its settings which can be the cause of no display on your tv
Jun 22, 2009 | Sony Playstation 3 (PS3) Console
Cant get picture
Turn the power on at the back of the PS3 and the red light will apear at the front, press the on button on the front and the light will then go green, then press and hold the power button on the front until the PS3 beeps at you and this should reset the PS3 from HDMI to standard Scart Cable...
Let me know if this is helpful to you :)
Mar 30, 2009 | Sony Playstation 3 (PS3) Console
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
77 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
