Question about Kenmore 23613 Progressive PowerMate Bagged Canister Vacuum
How do i separate the pipe,suction from the holder,suction pipe
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
My dc41 stopped all suction. the beater bar spins fine, but no air is moving. as in, is there a separate motor that just croaked?
If your motor is making it's normal sound, it most likely is working. Check for clogs by removing all removable pipe bends and examining visualy, check the hose by running a long broomstick through it. Clean, wash and dry all filters. Check for suction at the port closest to the motor.
Oct 18, 2015 | Vacuums
How do I fix the suction on my Dyson vacuum?
check the pipe is saying that is clogged with something who knows lots clock that pipe make sure all pipes from your vacuum is is unstuck are clogged.
Nov 29, 2014 | Dyson DC65 Animal Complete Bagless Upright...
Why has my vax power VX2 hoover now lost it's suction ? I have noticed that the roller has limitied brushes on it now and was clogged with hairs . I have removed this now and the brushes are still min
Sounds like something is clogging up the pipes between the head and suction pipe. Have a poke around with some wire to see if it's full of hair or fluff, maybe even a sock?
Sep 16, 2014 | Vacuums
Why has my dyson dc50 have no suction on the pipe
If you did put it together as it should, the only thing I can think of, is something got stuck in the pipe. Check this.
Old vacuums you could put the hose and or pipe to the other end of the vacuum, to blow it out. Now you have to be a little inventive to check a blockage.
Aug 02, 2014 | Dyson Dc50 Ball Multi-Floor 2-Tier...
Plenty of suction from the hose pipe itself but no suction when vacuuming the carpet
Hello Can,
Go through this guide to help find the issue www.builtinvacuum.com/flowchrt.html. You should have suction without a filter. The bottom is on the unit, right? It needs to be air tight.
Apr 21, 2011 | Vacuums
When we plug in the hose the motor in garage runs but no air or suction comes out of the outlets. we cleared all the lines too.
Check to see if you have suction at the unit. If you have suction at the unit, your pipes are stopped up. If you don't have suction, you have a pipe loose under the house. Also you could just have a stopped up hose
Apr 29, 2010 | Electrolux Centralux Vacuum
EF 1750 has lost suction power. There is a noticable decrease in suction power even at the power unit inlet.
Disconnect the actual pipe where it meets the vac. Then test the intake for suction. If you have poor suction still, check the intake itself from inside the vac body for blockage, then check the gasket on the pail for mis-alignement.
If you have suction at the actual intake, your issue will be in the house piping. Look for any damaged inlet doors which are ajar, also look at any inlets you may have recently removed for painting or renovation work. Each inlet has an o ring seal which must be properly aligned. If not aligned you will hear a hiss at the inlet when the door is closed.
Last check where any exposed pipe or pipe joint could have been jarred loose or damaged, basement , garage, etc. Post back to advise what you find
Nov 06, 2009 | Easy Flo EF1750 Central System Vacuum
Nutone 353 central vacuum....all of a sudden, poor suction at all house outlets.. Checked hoses and pipes for obstruction...none found
I think this unit has a utility valve on the front. If so, do you have good suction at this valve? If not, disconnect the inlet piping and check the suction directly from the inlet. Make sure the utility valve is closed while checking the suction on the inlet. If you have good suction, you have an open pipe or valve somewhere in the house. If you have any vacpans, check these first. Next, turn the unit on and walk through the house and listen for air whistling. If you do not have good suction from the inlet at the unit with the utility valve closed, replace your bag and look for a secondary filter that may be plugged. Good Luck!
Nov 26, 2008 | Broan-NuTone CV353 Central Vacuum
Central vacuum not sucking
Usually when there is no suction, and the main unit is running, then either the hose or somewhere in the piping there is a clog. If you move the hose to another location, is there suction? If not then the hose is clogged. You can unhook the pipe at the unit, flip the switch to manual, if it comes on and there is suction there, then there is a clog in the piping, If in the piping, tear up small strips of paper and mark them by number and insert one in each inlet, run the unit on manual to suck them up, and which ever numbered strip isn't there in the bucket, then that is the inlet that is clogged.
Nov 23, 2007 | M&S Systems AirVac AVP1200 Platinum Series...
Kenmore 23613 Progressive PowerMate Bagged Canister Vacuum Logo
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
