Question about Campbell Hausfeld PW2102 Gas Pressure Washer
Lose of pressure on Campbell washer
Washer pressure stopped suddenly. What is needed to repair, get repair kit OR where can it be taken for restoring?
Briggs 6 horse good shape.. what about purchase new pump?
David
  • Campbell Hau... Master
  • 5,603 Answers
Usual cause is the pressure valve sticks closed and doesn't admit more water to be pumped. Usually needs new O RIngs and cleaning the bore... ABout a 15 minute job at most. Get an O Ring kit for it.
The valve is held shut when pressure on the output is high. When you open the trigger, the pressure drops and the valve opens letting more water come in from your garden hose.
The O RIngs dry out and bore gets dirty. Polish it with crocus cloth on a dowel rod. Lube the O Rings with lube intended for O RIngs.
Posted on May 08, 2010
Testimonial: "You hit the exact problem. After many discouraging information from repair people I got pump to repair in Springfield TN. He took back to shop - 10 minutes back with repair. Man what a releaf .. in a throw away, buy a new world. Thank you... you are great!"
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
Have a honda gvc 160 power washer. It works ok for a while then loses all pressure. It seems as though when it is not running and the water is attached there is not as much water coming through. Is there a...
Sounds like the machine is not getting enough water.
Please check your water pressure to the machine and also the water inlet filter in case its a little dirty.
Jun 16, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
Gun
Replace the wand (Gun) The valve is not repairable.
Jun 16, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
Low Pressure
Sounds like you may need new pump seals.
Jun 04, 2010 | Campbell Hausfeld PW2575 Pressure Washer
Hausfield Campbell pressure washer 2300 psi .Water not flowing through hose to gun
hi try statring the machine with no hose on, if ok add the hose to the machine without the gun and lance. then try the gun on its own WITHOUT THE NOZZEL in the lance. just elimate things regards
Jan 23, 2010 | Campbell Hausfeld PW2575 Pressure Washer
Pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
the unloader valve is deffective , this has a small metal rod which activates a microswitch to turn the machine off , replace the unloader valve
Nov 18, 2009 | Campbell Hausfeld 1,350 Psi Electric...
Stops running after a few min. of spraying and won't start up . campbell hausfeld 1300 pressure washer
hi sounds like the rong nozzel in the lance and it's pulling to many amps so it overloading the motor and tripping out, take the lance off then try regards
Oct 25, 2009 | Campbell Hausfeld Tools 1300 Psi X 1.4 Gpm...
How do you get the cleaning solution to be incorporated into the water stream
One end of pick-up hose is in bottle of cleaner the other end is attached to the "T" connection of the Washer. The spray head is set for low pressure by sliding in or out. Dispensing only happens at low pressure.
Jul 24, 2009 | Campbell Hausfeld 1,350 Psi Electric...
Campbell Hausfeld PW1380 Pump won't run when water hose is connec
http://www.ppe-pressure-washer-parts.com/campbell-hausfeld-pw138000-pressure-washer-parts
Hope this helps. I have the same problem. It's not the switch but the mechanism that slides inside the switch, which activates the switch to go on and off. I fnally found it so hopefully they have the part in stock. It's not a clogged wand trust me I have torn it completley apart and found out it is the mechanism in the switch is plastic and breaks.
May 19, 2009 | Campbell Hausfeld 1,350 Psi Electric...
Campbell Hausfeld PW2102 Gas Pressure Washer Logo
816 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
