Question about Mitsubishi VS-70709 TV
Something buning back of tv red lines going off
  • Mitsubishi Master
  • 8,457 Answers
Ur tv have convergence problems,it dead.Ur 2 STK convergence ICS are defective,and all or some of it supporting resistors.The shop will cost u $300-350 for parts and labors.
Posted on May 08, 2010
My vizio 42 inch just made a very loud pop and the screen went black (off), the vizio leters at the below the screen stayed lit white as if the tv was still on. 5 minutes later a very loud pop then came...
Is it possible that it was storming when this happened? It could have been a power surge. If you are still covered under the manufacturers warranty, you should give them a call. Even if you aren't covered it wouldn't hurt to call to see if they can help or offer a discount to have it checked out and/or fixed.
Oct 04, 2014 | Televison & Video
FHD 40" LCD RED VERTICAL LINE CENTRE OF TV
Try changing the input device to something you are sure will work and see. Look for loose contacts in jacks and sockets. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Televison & Video
I have a red line going accross my tv screen. Its
Do you have speakers next to your tv sometimes the line on your tv will be from your sound to close to your tv also the red line could mean your tv tube is going out there about 300 to replace but i ould check frist on your sound are something close to you tv that is maken the red line in the middle of your tv
Dec 09, 2009 | Sony KP-51WS510 51" Rear Projection...
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Red line on screen
something going on w/ the convergence take to tv shop before it will cost lot more good luck shad
May 03, 2009 | Hitachi 43FDX01B TV
Red shadows of words on screen of projection TV
you have to go into the menue, and go under video settings, under advanced, then into convergence, when you get the white lines all over the screen, follow the directions and adjust the red so it lines back up, other wise , take the front bottom panel off the tv, look for the 6 little nobs, look at the ones on the left, they should agjust the red, thrn the top one untill the red is focused back in.
Nov 27, 2008 | Sony KP-46WT500 46" Rear Projection...
Lines in picture
I had this problem around the time my TV was 3 years old. I ended up having to get it repaired at a TV repair place, it cost me $375.
Sep 24, 2007 | Toshiba 57H83 57" Rear Projection HDTV
How to adjust picture on projection tv
i have a 52" rca projection , and the screen looks like this ") (" on the sides can i do something to straiten it back out?
Aug 28, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Red lines on Sony KP51HW40 Rear projection TV
cold solder on yhe red crt drive.u can find it at the back of red crt try to solder cold joint..or much better if u can refresh all the solder joint. also ,a corrosive terminal of red yoke might also be the culprit. hope this help u...
May 10, 2007 | Sony KP-51HW40 51" Rear Projection...
Lines on the screen
i have a samsung rear projection , and it has red lines going across the screen. i put it in the back of my cuboard and went out to buty a new tv . now a few months on i got it back out to have a play with it and i coverd up the red bulb with something fireproof and now the picture is great again just that there is no red anything that is red looks a bit darker. its not great but a least its some use now and i use it in my bedroom. it mite not be much help but a least i dont have to keep it in a cuboard anymore.
Mar 15, 2007 | Toshiba 53H71 53 in. Rear Projection...
Mitsubishi VS-70709 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
