Question about GE JKP27 Electric Double Oven
I have a GE Double Wall Oven Model number JKP27BOA2BB serial number TZ625663Q and the temperature setting is off in both ovens. In addition, after about 1 hour of use the top oven displays F7 and it constantly beeps. Can it be repaired and if so how much should it cost?
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Double GE wall oven - F7 code
You either have a stuck touch pad button or a bad clock.
Push all buttons several times to try and clear.
If not successful repair is a new clock.
Posted on Feb 22, 2009
localwonder
  • 6784 Answers
SOURCE: F7 beeping an cannot stop it... any solutions?
HI, if this error code cannot be canceled, this will confirm a touch pad issue. the membrane is damaged and, this will require you to replace the ERC.
Replacing the Electronic oven control will fix this issue.
Posted on Jun 24, 2009
  • 56 Answers
SOURCE: F7 appears on GE double oven JT950SA
f7 is a stuck keypad or overlay all you can do is replace it
Posted on Jun 30, 2009
  • 5 Answers
SOURCE: 326B1230P001 GE Double oven that displays ?F7? and beeps
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
Posted on Aug 01, 2009
Have a ge truetemp double oven model jkp27boa2bb. The control panel does not work. Turn the temp knob for lower oven and upper oven lite comes on. Is the control panel bad? Lower oven heats up only
The heating element on the top part off oven might be bad or a fuse that's located on back of oven either on or behind back panel.
Mar 16, 2016 | GE Ovens
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Seal on Tappan wall oven came off, what to do?
Hey friend, I appreciate your post!
I understand that seal on your Tappan wall oven has come off. In order to provide you additional information regarding the seal I would need your model number and serial number. You can locate the serial tag (which has your model number listed) on the front of the oven on the left side. With that information I could provide you additional assistance. I look forward to your response. -Matt
Aug 03, 2014 | Tappan Ovens
GE Wall Oven JKP13GOTBB Touchpad is "too sensitive"??
I don't see that exact model number listed. Check the model / serial number again. If the unit is not too old, you can probably get a replacement key panel which should solve your problem.
Aug 12, 2009 | GE JTP45 Electric Double Oven
Bottem Oven Over Heats
GE announced a recall for some of its wall ovens this week for an overheating problem. Have you contacted a GE dealer yet?
Nov 20, 2008 | GE JRP24 Electric Double Oven
Oven low heat
Did you try going to the GE website to pull up the Use and Care Manual? It does have a section re: how to adjust the temperature by as much as 35 degrees either way. Although it is not the 100 degrees you mentioned, you could try it and see if it helps...
The main GE website is: http://www.geappliances.com/
At the top of the web page is a SEARCH section. You can click on the blue down arrow in the first box and select Use & Care Manuals, then put your model number in the empty box to the right of that selection box, ie. JT952 is my oven.
If you are having a problem locating your model number/serial number, you can go to the FAQ (frequently asked questions) section to see how to find it.
Jul 05, 2008 | GE Profile JT952 Electric Double Oven
Ovens Logo
191 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
