Question about Nokia 6101 Cellular Phone
My fone screen froze and wont open on menu it keeps asking to calibrate touch screen
  • 343 Answers
Restore to factory settings
Posted on May 08, 2010
My screen is froze up
I suspect the calibration of the screen is out of adjustment. Take it to a professional but don't let them replace the screen or motherboard before asking them whether they tried to re-calibrate the screen.
Mar 19, 2014 | Husqvarna Designer I
Touch problem
Nokia designed the N97 with a touch-screen calibration program to remedy problems with the touch screen. Opening the touch-screen calibration program requires you to use the touch screen, which can prove difficult. You're forced to judge where to tap the screen because the screen isn't recording the precise location of your taps. To find the touch-screen calibration program, open the main menu, select "Settings" and then "Touch Input." The program provides on-screen instructions to help you finish calibrating the screen.
Oct 23, 2012 | Nokia N97 Cell Phone
I have an lg350, touch screen. It is very temperamental at times. When i try to open up the phone by sliding the screen it wont open. been at it now for ten mins please help
Hello there,
The problem is that the screen is weak and needs to be calibrated. You wont be able to access the calibration settings unless the phone is opened. Try to remove the battery and insert in back in, then the turn on the phone, try to go to the menu and select the settings of the phone, then you select calibrate screen, and follow the rest of the instruction from there on, that way the screen will be able to work well.
If you eventually do not have access to the phones menu, you will have to replace the sensor board of the phone.
Hope this helped.
Goodluck
Elect_Comp
Aug 09, 2011 | Cell Phones
How do i callibrate the screen for my samsung i5510i galaxy android phone?
If you are asking about the touch calibration
Goto Settings (in the program menu) > Language & Keyboard > Touch Input
Here you can calibrate the touch settings.
If you are asking about Display Calibration
Goto Settings (in the program menu) > Display Settings. Here you can calibrate settings for Animation, Brightness, Screen Timeout etc
Jul 01, 2011 | Samsung Cell Phones
WHen I touch contacts, dial or menu nothing happens. When I go to my call list and touch a contact it opens the contact 3 or 4 rows up.
try and reset the fone's calibration.. go to settings and in their check phone settings u will find a thingy called calibration select it and follow instructions...
Sep 02, 2010 | Samsung SGH-A877 Impression Cell Phone
My Leapster 2 comes on, shows the name on screen & ask to touch my name w/ the pen; however when I touch the name, nothing happens. It keeps asking to touch a name or "guest".
Answer
I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
Jul 28, 2009 | LeapFrog Leapster 2 Learning System
I just got a new i68 and it wont unlock.
try calibrating your touch screen. Please use the stylus to calibrate!
The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until
"Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions
on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first
see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and
eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen,
immediately press the side volume button in the down position. A white calibration screen should now
show & you can calibrate the touch screen using the stylus. Try to tap as close to the center of the little
pulsating icons as possible, as this will more accurately calibrate your touch screen. If the calibration
screen didn't come up using that method, then you can get to it from the Main menu screen.
Select "Settings", then select "Pen calibration", & follow the previous instruction.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
May 07, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
The screen has frozen, it starts up but the screen fails to respond..
Try calibrating your screen. Please use the stylus to calibrate!
May 02, 2009 | Dual Electronics CECT P168 Cellular Phone
Nokia 6101 Cellular Phone Logo
42 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
