Question about LG enV VX9900 Cellular Phone
Change wap settings to page plus - LG enV VX9900 Cellular Phone
Will not connect to wireless network
I suspect Mac Filtering is the problem
see page 37 and 38 of Cisco administration Guide on Mac Filtering.
https://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/csbap/wap4410n/administration/guide/WAP4410N_Admin_Guide.pdf
page 37 and page 38
"Connection Control The Wireless > Connection Control page is used to exclude or allow only listed client stations to authenticate with the access point. Depending on how the WAP is configured, the WAP device may refer to a MAC filter list stored on an external RADlUS server, or may refer a MAC filter list stored locally on the WAP device. Enabling Local Connection Control To refer to a MAC filter list stored locally, follow these steps: "
see link above page 37 for the steps -
I Do not want to be accused of breaching Cisco Copy Right
Oct 30, 2017 | Philips 40PFL7705DV/F7 - 40 LED HDTV with...
Tip
Bsnl 3g manual settings,tv settings,bsnl wap settings,bsnl portal settings,bsnl...
TO get settings directly to your phone visit this link http://218.248.72.246/msp/html/authenticate.jsp
this settings for connecting internet from mobile to pc,
setting name : bsnlnet
access point name : bsnlnet
homepage: www.bsnl.co.in
authentication : normal
user name : leave blank
password : leave blank
WAP SETTINGS
setting name : bsnlwap
access point name : bsnlwap
port : 9201 for wap 1.0 device,8080 for wap 2.0 device
home page : http://wap1.cellone.in
PORTAL SETTINGS
setting name : bsnlportal
access point name : bsnlportal
port : 8080 for wap 2.x device & 9201 for wap 1.x device
proxy ip : 10.220.67.131
home page : http://wap.cellone.in
MMS SETTINGS
setting name : bsnlmms
access point name : bsnlmms
port : 8080 for wap 2.x device &9201 for wap 1.xdevice
proxy ip : 10.210.10.11
uere name : leave blank
home page : http://bsnlmms.in
BSNL LIVE PORTAL SETTINGS
settings name : bsnllive
access point name : bsnllive
port : 9201 for wap 1.0 device & 8080 for wap 2.0 device
username : leave blank
home page: http://bsnllive
BSNL MOBILE TV STREAMING
Setting Name : bsnlstream
Access Point Name : bsnlstream
Homepage : None
Authentication : Normal
User Name : <leave blank>
Password : <leave blank>
CP MOBILE STREAMING
Setting Name : bsnlmobiltv
Access Point Name : bsnlmobiltv
Homepage : None
(Open Real Player: Options-> Settings-> Connection-> Network->default)
APN (Should be "bsnlstream")
Minimum Port: 5001, Max Port: 32768
2. APN "bsnlwap" (Not Required for Sony Ericsson Sets)
- Set proxy IP: 10.147.4.131
- Port: 8080
And check all wap sites with this APN.
With this APN, On the handset download the MobiTV Application (3PP Application).
to get settings directly to your phone http://218.248.72.246/msp/html/authenticate.jsp
Send SMS “MY3GTV” to 55447.
And you will receive the WAP Push from Apalya TV. Click on the link and download the application.
Once Application is downloaded on the handset, you can watch live TV from the Applications on the
handset using httpnorth3g.bsnlmobile.in.
For TV
1. After Receiving WAP push, Click on the link and download the application.
2. For Sony Ericsson sets, click on “Get Activation Key”Link & Press “Submit”. After receiving the
activation key, put the activation key and press “Purchase”.
3. Pl. check the compatibility list of handsets, whether the set is supported by the Apalaya server.
on Mar 19, 2010 | Cell Phones
My browser returns "web page
check the wap settings...
if you are not able to figure it out then contact the mobile operator for wap settings
Mar 14, 2011 | Samsung Galaxy Tab Tablet PC
Can you send reliance gprs setting to my mobile nokia 5130 please my no is 9022808844
Reliance GSM GPRS Settings
__________________________________________
Reliance GSM WAP Setting
( Required to run RWorld )
( Postpaid and Prepaid )
APN: rcomwap
Login Request Required : off
Authentication : PAP
Data Compression : off
Header Compression : off
Settings Name: Mobile World
Home Page / WAP Page: http://wap.rworld.co.in
Proxy: Yes
Proxy Server Address : 010.239.221.005
Port : 8080
Full Address in case of Windows Phone : 010.239.221.005:8080
User Name = leave it blank
Pass word = leave it blank
Reliance GSM MMS Setting
( Required to to Send and Receive MMS)
APN: rcommms
Settings Name: Reliance MMS
Proxy: Yes
Port : 8080
MMS Server Settings
Server URL: http://10.239.221.47/mms/
Ip Address: 10.239.221.5
Apn: rcommms
IDRISH 911
Nov 11, 2010 | Nokia 6300 Cellular Phone
Browser is not set up. how do i set it up?
WAP settings are carrier specific. You will need to contact your carrier (is this Page Plus by chance) for the exact settings required.
Jun 22, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Wireless G Plus MIMO (F5D9230-4) Router (1010835): can I set up WAp or Wap2 securety on win 7....
You can set up wireless security on the router.
If you have Windows 7 computer, you can use WPA or WPA2 security on the router.
It is better if you set up WPA. that will work with windows Vista anbd windows XP also.
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Apr 28, 2010 | Belkin Computers & Internet
Cingular WAP settings
Hi..i am providing you with the WAP and other settings,but still if you need any help,then please contact Cingular at 866.CINGULAR(866-246-4852)
For CSD (Wireless Internet)
Function Setting
Settings Name: Cingular Wireless Internet
Home Page: http://device:home or http://device.home
Session Mode: Permanent
Connection Security: On
Dial-up Number: 14152441012
Gateway IP Address: 66.209.11.61
Authentication Type: Secure
Dial Type: ISDN (on network)
Analogue (off network)
Login Type: Automatic
User Name: WAP@CINGULAR.COM
(All upper case)
Password: CINGULAR1
(All upper case)
For GPRS (Wireless Internet Express)
Function Setting
Settings Name: Cingular Wireless Internet Express
APN: wap.cingular (lower case)
PDP_Type: IP
User Name: WAP@CINGULARGPRS.COM
(All upper case)
Password: CINGULAR1
(All upper case)
Now to set up MMS (Multimedia Services)
Homepage: http://mmsc.cingular.com
Gateway IP 1: 66.209.11.61
Port 1: 9201
Domain 1: (blank)
Service type 1: WAP
Gateway IP 2: (leave alone)
Port 2: 9201
Domain 2: (blank)
Service type 2: WAP
DNS 1: (leave alone)
DNS 2: (leave alone)
Timeout: 10 minutes
CSD No.1 14152441012
Username 1: WAP@CINGULAR.COM
password: CINGULAR1
Speed(bps): 9600
Line type 1: ISDN
CSD No.2: (blank)
User Name 2: (blank)
Password 2: (blank)
Speed(bps)2: 9600
Line type 2: ISDN
GPRS APN: wap@cingular
Username: WAP@CINGULARGPRS.COM
Password: CINGULAR1
Good luck :-)
Apr 22, 2010 | Computers & Internet
NEED TO CONFIGURE THE INTERNET SETTING,
To get your Glo 3G internet settings, you will send SMS activate to 444 using a 3G mobile phone. Save the internet settings in your mobile phone. To get Glo WAP settings, SMS your phone name and model to 927. e.g, to activate Nokia 2630, SMS Nokia 2630 to 927. Save the internet settings in your mobile phone.
Glo manual 3G/3.5G internet settings
Service name: Glo 3G
IP Address: 10.100.98.22
Port: 3130
Username: wap
Password: wap
Access point name (APN): glo3gvideo
Authentication: Normal
Home page: http://cms.gloworld.com
Jan 27, 2010 | Samsung Gravity SGH-T459 Cell Phone
I9 wap/gprs & mms settings for O2
First you have to make 2 data accounts,
1 for wap,
1 for mms.
Press service,
Data account,
GPRS, ok,
Pick any one of the settings because you are going to change it,
Press edit.
account name edit to O2 WAP GPRS,
APN to payandgo.o2.co.uk,
user name to payandgo,
password is password,
authentication type normal,
after each one if done is the option press it. this is the setting for wap internet.
You have to do the same again to make a new data account for the mms. the settings for this is
account name O2MMS,
APN payandgo.o2.co.uk,
user name payandgo all others same as before.
Now you have 2 new data accounts you need to set up wap.
press service, wap, settings, edit profile, sim 1 or 2 which ever you are using,
select the O2 WAP GPRS account that was made earlier,
press ok. press edit profile,
rename profile is ok it is O2 WAP GPRS,
edit home page to http//wap.o2.co.uk,
set data account to O2 WAP GPRS,
connection type wap, IP address 193,113,200,195
user name payandgo,
press back and activate profile.
you should be able to get on to o2 homepage now.
To get mms
press text, mms, mms settings, server profile, sim which ever you are using 1 or 2 ,
select the O2 MMS made earlier, edit profile, rename profile is 0k should be O2 MMS, home page is http//mmsc.mms.o2.co.uk:8002,
data account is the O2 MMS you made before,
MMS IP address 193,113,200,195
user name payandgo,
select back when all settings are entered and select activate profile. this should be it.
This works OK for me.
Mar 23, 2009 | Dual Electronics CECT P168 Cellular Phone
Att wap settings for sumsung sgh- g600
Samsung SGH-G600
MMS Settings:
Menu>Settings>Message Settings>Multimedia Message Profile>Profile 1
You can then change the profile name or keep it default at "profile 1"
Server Url: http://mmsc.cingular.com
Proxy: Enable
Version: 1.2
Then click on GPRS setting
IP Address: 66.209.11.32
Port: 8080
APN: wap.cingular
Login ID: WAP@CINGULARGPRS.COM
Password: CINGULAR1
Then click save
Hypothetically....the settings should work the same for WAP
only thing is change to Server URL: http://device.home
Mar 19, 2008 | Cell Phones
LG enV VX9900 Cellular Phone Logo
1,001 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
